COAL FIRED ACCUCRAFT RUBY LIVE STEAM LOCOMOTIVE - HERGET BUILT
COAL FIRED LIVE STEAM RUBY. CUSTOM BUILT BOILER WITH WET SIDE FIRE BOX. FIRE BOX MEASURES 1 1/2" x 2". HAS BETWEEN THE FRAME ECCENTRIC AXLE PUMP. (NOT THE DRIVER PIN PUMP SEEN ON OTHERS). ENGINEERS SIDE TANK IS USED FOR WATER STORAGE AS WELL AS WATER RETURN.
FEATURES:
REVERSED ECCENTRICS
GOODALL VALVE
150 PSI PRESSURE GAUGE
POP VALVE SET AT 65 PSI CURRENTLY
BYPASS VALVE ON ENGINEERS SIDE OF CAB
SIGHT GLASS WITH BLOW DOWN VALVE
SPRING LOADED FIREBOX DOOR
BLOWER CONTROL
SLEEVED STEAM OIL RESERVOIR FOR REDUCED OIL CONSUMPTION
SEALED SMOKE BOX
COMES COMPLETE WITH: COAL PICK, SHOVEL, SUPPLY OF WELSH COAL, REAL CHARCOAL, FLUE TUBE BRUSH AND INSTRUCTION SHEET FOR PRIMING THE AXLE PUMP INCLUDED… SUCTION FAN AND PUMP BOTTLE FOR GOODALL VALVE ARE NOT INCLUDED.
Asking $1350. + Shipping
Contact [email protected]
YouTube Link: https://youtu.be/KrSqtSsNKHo
