Marilyn likes to pick up buildings at the craft store. They are rarely usable as-is so most of them have never seen the light of day. When she brought this one home a few years ago I saw promise…
The plan all along was to raise it by extending the walls to make a scale door opening. Before it was primed I took one course of logs from each of the three openings. It has sat like that on my indoor railroad until last week when I picked up some of the stone tiles that have been seen in projects here recently by Jake and Shawn.
The stone needs a substrate to support it. I have lots of PVC foam board scraps laying around. I made this foundation from 19mm and 3mm PVC board…
Here is a sneak peak at what it might look like…
So part of the weekend was spent applying the stone to the PVC foundation using Loctite PowerGrab I chose the indoor type only because of the dispensing tube,. Hopefully it wont be exposed to much water when I’m done.
Heres the first wall going on…
Then a side…
Tonight I finished up the front wall including a door sill. The figure is a 1:20 person about 6 foot tall…
I have two more changes I want to make. First I’ll add a redwood cap to the stone all the way around before attaching the birdhouse. This will dress up the transition line and protect the stone from direct water run off. Next I think I’m going to cut away the last two course under the window and the logs between the door and windows. I’ll build a front on a sheet of clear acrylic to fit in the void. Oh, and I think that chimney has to go. It will be replaced with a stove pipe.
