Forums Modeling Modeling
  • Topic: Bachmann Connie Bash Thread. Post your pictures here.
    Back To Topics
    (0 rates)
    • June 10, 2012 1:07 PM EDT
      • Parts Unknown,
      • Posts
        1,429
      • Thanks
        17
      • Thanked
        11
      Hopefully this can be turned into a sticky so everyone who has bashed their Bachmann Connie can show it off. Post a few of your pics and a brief description of the work done. Here's mine The Lakeville Amboy & Conneaut Railroad's #4. Typically it's job is to haul the varnish but once in a great while it gets pressed into freight service.
      It has been fully converted to battery power with Airwire controls and a phoenix P8 sound card. The smoke unit and smoke box flicker lights have been removed and the orange LED front and rear lights were replaced with incandescent lamps. I added a real coal load, lettered it for the LA&C RR installed an engineer & fireman, detailed and weathered with paint, added a 'rope' to the bell and whistle, raised the headlight on a new bracket, made a new smoke box door, installed kadee couplers with chains attached to the cut levers and installed a Barry's big train Drive. I'll edit and post a better picture when I get it outside.
    • June 10, 2012 1:36 PM EDT
      • Posts
        2,861
      • Thanks
        0
      • Thanked
        5
      The major mods were swapping for a Big Hauler cab and tender, and shortening the domes, etc. to resize it to work in 1:24 Abbreviated build log here: http://www.the-ashpit.com/mik/connie.html Also, for those who can't afford Barry's great gearbox, here's a basic primer on how to change the problematic axle gear yourself. http://www.the-ashpit.com/mik/gear.html
    • June 10, 2012 3:53 PM EDT
      • Posts
        1,090
      • Thanks
        0
      • Thanked
        1
      Here's the one of my two that's been physically altered. (Thanks Bruce for the photo...)
      Pilot deck, beam, smokebox plate, headlight raise, smokebox graphite treatment, all new. The tender has new steps, but that's no big deal.
    • June 10, 2012 3:57 PM EDT
      • Posts
        46
      • Thanks
        0
      • Thanked
        0
      Terry, is that my new loco? Thanks!
    • June 10, 2012 8:04 PM EDT
      • Defending the State of Exile! ,
      • Posts
        12,928
      • Thanks
        1,233
      • Thanked
        826
      OK.....I know very little about steam modeling or prototype for that matter....but intrigued ...what are the the levers/cams above the valve rods that are connected to the center driver? It's the mechanic's and the timing thing that suck me into the steam .....I blame Bart for sucking me into half of this stuff....
    • June 10, 2012 8:49 PM EDT
      • Burbank, CA
      • Posts
        1,192
      • Thanks
        110
      • Thanked
        134
      I believe that's the Baker valve gear.
    • June 10, 2012 9:27 PM EDT
      • Posts
        1,090
      • Thanks
        0
      • Thanked
        1
      Gary's right... the B'mann 2-8-0 has Baker valve gear, which was designed to be an improvement on the more common Walshaerts valve gear, by removing the sliding components in the reversing mechanism. This will help you with the basics ... though the drawing is the Walshaerts.
      Compare to Baker gear (no animation, but the diagram is good) http://en.wikipedia.org/wiki/Baker_valve_gear Matthew (OV)
    • June 10, 2012 9:36 PM EDT
      • Posts
        1,090
      • Thanks
        0
      • Thanked
        1
      The other thing that should be mentioned here ... this locomotive is an OUTSIDE frame design ... the rods, cranks, and counterweights are outside the frame while the wheels are inside. On this one, the counterweights (the D-shaped pieces on the axle ends) balance the rods directly, while on some models (notably the C-25) the weights are integral parts of the wheels themselves, and not visible on the outside of the frame with the valve gear.
      On an INSIDE frame, the wheels and gear are both outboard of the frame, and the weights are normally part of the wheels themselves (usually a solid piece on the side of the spoked wheel opposite the rod cranks) The idea is to balance the extra weight the rods, cranks, and gear add to one side of the wheel so that it turns smoothly and doesn't jump up and down on the rails, or surge.
      If I'm being overly elementary here, I apologize ... but if you're really new to steam things, that'll get you off to a decent start.
      Matthew (OV)
    • June 11, 2012 4:48 AM EDT
      • West Grove, Pennsylvania
      • Posts
        10,496
      • Thanks
        360
      • Thanked
        531
      I shortened the pilot and front truck by about 1", raised the headlight and added class lights.
      Also managed to fit a snow plow to it:
      "Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." --Martin Luther King Jr
    • June 11, 2012 12:19 PM EDT
      • Posts
        1,173
      • Thanks
        0
      • Thanked
        1
      Excellent Idea Terry. Modifying my Connie is in the works. This thread gives me some ideas.
    • June 11, 2012 12:28 PM EDT
      • Your Host in Littleton, MA
      • Posts
        7,607
      • Thanks
        429
      • Thanked
        779
      I'll sticky this, but if it degrades into insanity, Ill unsicky it.
    • June 11, 2012 12:50 PM EDT
      • Posts
        7,607
      • Thanks
        429
      • Thanked
        779
      Here's my connie, recently brought into the backshop for new batteries, and some repairs. I've heavily modified it. Moved the cab back a couple inches, shuffled the domes and bell around, lowered the tender. Ive lost track of what Ive done to it.
      • Posts
        7,607
      • Thanks
        429
      • Thanked
        779
      • Parts Unknown,
      • Posts
        1,429
      • Thanks
        17
      • Thanked
        11
      Thanks Bob! And everyone behave!! Post ur pics and discuss the mods, I know I've seen some beauties out there.
    • June 11, 2012 3:49 PM EDT
      • Spokane Valley, Washington St.
      • Posts
        5,343
      • Thanks
        221
      • Thanked
        163
      The only thing I did to my two (besides a Barry's drive) was convert the tenders to oil.
    • June 12, 2012 12:13 AM EDT
      • Southern Oregon
      • Posts
        1,437
      • Thanks
        11
      • Thanked
        278
      Hi all, Here is my Connie after many trips to the shop through the years. Some of the things that I can remember that were done are listed below. On the locomotive as a whole there is new paint and decals, AirWire, Battery, Phoenix sound And a Barry’s Drive. The details are; corrected front suspension, shortened pilot deck, lengthened smoke box, relocate headlight, remove cab back wall, add deck plate, move the cab back, added additional boiler and cab piping, add wooden pilot beams, new number boards, Pilot tool box, air lines and hoses, relocate sand dome and bell, rebuild pilot truck to outside frame, add washout plugs, and a curved front smoke box grab iron. The tender changes included; lower tender body on trucks, add oil tank, add air tank, change rear pilot beam and steps, raise rear side steps, add KD’s and cut levers, add water piping, add rear ladder, change all lights to bulbs from LED’s, add air tank piping, add oil tank piping and steam heater, add oil tank railing, add hinged water hatch lid. There are probably a few other changes but I don’t remember them just now. Thanks for this thread Rick
    • June 12, 2012 10:29 AM EDT
      • Posts
        1,173
      • Thanks
        0
      • Thanked
        1
      Thats a lot of work on your Connie Rick.
      I want to shorten the pilot deck on my Connie. How much has everyone cut off and how difficult was it to do?
    • June 12, 2012 10:41 AM EDT
      • Posts
        10,496
      • Thanks
        360
      • Thanked
        531
      I cut a little over an inch off mine. Wasn't much to it. Removed the plastic deck and cowcatcher then cut the metal frame. Then cut the deck to fit. Did the same to the pilot truck.
    • June 12, 2012 10:43 AM EDT
      • Posts
        7,607
      • Thanks
        429
      • Thanked
        779
      How does the coupler mount change? Any issues? Id want it to be nice and solid, still.
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
