Forum Sponsorsss
Forums General General Discussion
  • Topic: Real crossing gates
    Back To Topics
    (0 rates)
    • September 29, 2021 7:28 AM EDT
      • Naples, Fl
      • Posts
        10
      • Thanks
        0
      • Thanked
        0
      Real crossing gates
      Good morning, not sure where to post this, we have a set of rea crossing gates and lights, lights function, gates have no gears and are controlled by pneumatic pressure supplied from a portable air compressor which runs a small Bima Piston,  piston forces the gate arm down and a counter weight raises it, we need a more reliable set up, any thoughts?
      Thanks
      Geo
      Geo
    • September 30, 2021 9:06 AM EDT
      • Central, Kansas
      • Posts
        153
      • Thanks
        4
      • Thanked
        32
      If you're asking about the activation method (what actually moves the arm) I don't think you're going to find anything more reliable than pnuematics. I set up some crossing gates using some water-proof servos (which I then sealed in plastidip) and all potted electronics in a waterproof enclosure and they lasted less than three years. Electronics outside--at least anywhere it isn't dry and warm--aren't super reliable. If you're triggering the gates with electronics, the same holds true: even potted electronics in a water-tight container will corrode over time.
      If you tell us exactly what problem you're having, we might be able to offer ideas... do the gates not open or close as expected, or is there something else going on?
      This post was edited by Dan Hall at September 30, 2021 9:07 AM EDT
    • September 30, 2021 4:36 PM EDT
      • Curmudgeon at Large, Lynn Haven, FL
      • Posts
        2,328
      • Thanks
        91
      • Thanked
        333
      George, please help me out here. I am a bit confused, are we referring to a 1:1 set of gates or a model scale set of gates? It will help to know what we are evaluating and possibly providing advice on.
      We don't stop playing with trains because we grow old, we grow old because we stop playing with trains.....
    • October 5, 2021 9:18 PM EDT
      • Naples, Fl
      • Posts
        10
      • Thanks
        0
      • Thanked
        0
      Hi, gates are controlled by pneumatic actuators ,problem is that the gates bounce up when in the down position, counterweights were determined with the gate arms balanced in the 45 degree position, is this correct? Actuators are 1” Dia +/- . I tried to include some pics but it was confusing.
      Thanks
      Geo
      Geo
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
