As my buildings and my layout get more developed I have started to wonder about bases for the buildings. I have some bricks buried in the ground that are being used as bases for 2 buildings, I don’t think I will be letting all my buildings sit out all year due to the inferno that is Peoria AZ, a record 50 days over 110* this year. I am hoping to get some good discussion on this as I really want to see what everyone else does and how they handle this.
Do you use a base for your building on your layout?
What do you use for a base if you do use one?
Is the base attached to the building or is the base set in the ground?
If the base is permanent on the ground, Do you have a way to solidly attach the building to the base or does it just set on the base.
Topic #2 what do you use to model roads on your layout, I have seen carpet squares, concrete, rolled roofing and asphalt and wonder what the more modern railroad era modelers use to simulate roads. Looking forward to what all y’all have to say, suggest about on these topics. Thanks, Pete
Edited to clarify a sentence for my thought process behind the question
