Forums Modeling Tools and Tips
  • Topic: Corrugated Tin Roller
    Back To Topics
    (0 rates)
    • February 8, 2020 10:20 AM EST
      • Farmington, New Mexico
      • Posts
        2,576
      • Thanks
        22
      • Thanked
        639
      Dan.....   what metal, or stock do you plan on using to make the panels from...?
      New Mexico­ Northern ­Railroad
      D&RGW ­315 Crew ­member, Fireman
      RRR #4
      Board Memb­er, Durang­o Railroad­ Historica­l Society
    • February 8, 2020 3:04 PM EST
      • Waverly, Alabama
      • Posts
        2,021
      • Thanks
        786
      • Thanked
        793
      I've been using 0.002" steel shim stock with the paper crimper with success.  I also have 0.003 aluminum and 0.002 brass I am going to try.  I've discovered through testing that the roller profile must be a little more aggressive than I originally thought.
    • February 8, 2020 3:12 PM EST
      • Waverly, Alabama
      • Posts
        2,021
      • Thanks
        786
      • Thanked
        793
      Pete Lassen said:
      Dan are you at all concerned with the plastic flexing and not giving repeatable results, and will the plastic rollers wear out quickly?
      Pete, I don't think the PETG filament I am using will wear out or flex.  The paper crimper I have been using is all plastic including the rollers and I have seen no issues with it other than I can't control the profile.  Should the rollers wear out prematurely, I can print new ones or make them out of a different filament such as carbon fiber or even some of the newer filaments that have various forms of metal in them.  I have used the carbon fiber before and it works well, but I've never used the metal infused filaments so there certainly would be a learning curve.  This whole thing may be an experiment in what not to do but at least we'll all know in the end.
    • February 8, 2020 3:23 PM EST
      • Dunstable, MA
      • Posts
        2
      • Thanks
        0
      • Thanked
        1
      Dan - chipping in here.  I was looking to do something very similar, but then I found a press tool on eBay in the G Scale section.  You've probably seen it.  It makes sections about 4" x 7", which would be on the order of 96" x 168" in full scale if you were modeling in 1/24.  This is larger than most real-life sheets would be, so I think the smaller pieces actually seem more realistic.  He designed this for 36 gauge aluminum, but actually, using a cut-up pop can works pretty well.  Search on "Make your own G or O scale roofing" and you can see what it looks like.  Added bonus is the sheets come out flat!
      Trent
      This post was edited by Trent at February 8, 2020 4:14 PM EST
    • February 8, 2020 4:22 PM EST
      • Waverly, Alabama
      • Posts
        2,021
      • Thanks
        786
      • Thanked
        793
      Trent, I've not seen that particular press.  it looks like it produces a form of standing seam roofing.  I've consider something similar, kind of a hybrid between the press and the rollers I am attempting to use.  Make a bed similar to what is shown on ebay, but instead of using a press, have a roller with a mating profile as the bed and let the roller move on a rack and pinion mechanism along the bed.  The press is probably much easier sinc its less moving parts, but it would take a long time to make a large quantity of roofing.  Thanks for the information.  If this experiment fails, I may look at going the press route.
    • February 8, 2020 6:37 PM EST
      • West Glocester, Rhode Island
      • Posts
        571
      • Thanks
        152
      • Thanked
        238
      I'm wondering how this works?  The seller doesn't specify.  The plates look like they are clad in oak so I imagine you could just pound it with a mallet but there are the screw holes so I'm thinking you use bolts and ratchet it down.  The holes are missing from one side probably to facilitate loading/unloading.
      Dan, I believe this roofing is just corrugated "sinewave" type.  Although it does look more "fanfold" than most.  Standing seam has the edges raised high and the panels lock into each other rather than overlap.  Just so happens I'm looking at putting a metal roof on my home now.  Also, what crimper do you have?  The only one I've seen is the one I have made by Fiskers and has metal rollers.
      Thingiverse Icon Instagram Icon
    • February 8, 2020 10:32 PM EST
      • Waverly, Alabama
      • Posts
        2,021
      • Thanks
        786
      • Thanked
        793
      Dan, I have one made by Marvy and it definitely has plastic or some type of resin rollers.  To lite for metal and I sliced a piece off with a hobby knife just to be sure.
    • February 14, 2020 7:20 PM EST
      • Waverly, Alabama
      • Posts
        2,021
      • Thanks
        786
      • Thanked
        793
      More progress on the crimper.  First tin has come off the rollers with some success.  Still need to work on the profile to get where I want to be and I must perfect the feeding technique, but it works.  Here is the first four pieces of .002" steel shim stock hot off the press ..... uh, mmmm ....... rollers ...
      As you can see the profile is a little out of scale but you can see the rounded peaks and valleys vs the v shaped ones that come off the various paper crimpers.  One benefit of this method is, at least in theory, you can make the pieces as long as you want, width is limited to the width of the rollers.
      Here is the prototype tool as of now.
    • February 14, 2020 9:02 PM EST
      • Peoria, NW of Phoenix, Arizona
      • Posts
        1,508
      • Thanks
        269
      • Thanked
        348
      Nice you want to sell some? Looks way better than the paper crumpets and probably easier?
      Butt Modeler #2
    • February 15, 2020 1:29 AM EST
      • Missouri, It's like Floodsburg, man
      • Posts
        2,813
      • Thanks
        331
      • Thanked
        367
      Layers of creativity:
      "You know, I could make some."
      "You know, I could make a tool with which to make some."
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
