  • Topic: 2020 Challenge By Dennis Rayon.... Denray Machine Welding Supply
    Back To Topics
    (0 rates)
    • February 10, 2020 11:30 PM EST
      • Mount Vernon, Missouri
      • Posts
        905
      • Thanks
        92
      • Thanked
        366
      Fence made from Redwood all cut on tablesaw
      Drag thin boards backwards on a bandsaw makes a nice way to cut edges to look uneven/rotted.
      IMG_4911 by Dennis Rayon, on Flickr
    • February 10, 2020 11:33 PM EST
      • Posts
        905
      • Thanks
        92
      • Thanked
        366
      Finished Wall showing with light shining through
      IMG_4971 by Dennis Rayon, on Flickr
    • February 10, 2020 11:49 PM EST
      • Holt, MO
      • Posts
        11
      • Thanks
        3
      • Thanked
        6
      Hey Dennis.  I just happened on to your build.  Fantastic modeling (as usual).  Will using the PB replace your famous Magic-Sculp process of the past?  Just wondering.  And thanks for posting.
      • Holt, MO
      • Posts
        11
      • Thanks
        3
      • Thanked
        6
      Sorry, double post.
      This post was edited by Peter Lewitzke at February 10, 2020 11:52 PM EST
    • February 10, 2020 11:51 PM EST
      • Pleasanton, CA
      • Posts
        1,135
      • Thanks
        1,306
      • Thanked
        874
      Gad I learn a new valuable technique every time I look at one of your builds! I love it! Nice job Dennis!
    • February 11, 2020 12:26 AM EST
      • Posts
        905
      • Thanks
        92
      • Thanked
        366
      Thanks Peter
      Wont replace the magic sculpt, but it will reduce the use of it, this is quicker.
      Dennis
    • February 11, 2020 12:28 AM EST
      • Posts
        905
      • Thanks
        92
      • Thanked
        366
      Thanks Jim, I appreciate the compliments
      Dennis
    • February 11, 2020 3:20 PM EST
      • Ormond Beach, Fl. 32174
      • Posts
        1,040
      • Thanks
        3
      • Thanked
        505
      Dennis, super build!
    • February 11, 2020 7:35 PM EST
      • Posts
        905
      • Thanks
        92
      • Thanked
        366
      Making Redwood Shingles
      I am making shingles this time with the table saw. I have done them in different ways, I actually made a shingle splitter, that works
      very well, but I like this way the best. I purchased a thin kerf blade to save a little lumber. It cuts very nice, and smoothly. I will cut 3 different thickness, about .050-.060-.070, these will give a very authentic look .  Then I take a wire brush on a cordless drill and wire brush the wood as pictured. Quick and easy.
      IMG_4882 by Dennis Rayon, on Flickr
      Then I stack the three different thickness in no order, using masking tape and wrap it in a spiral as pictured. Then I set the fenceon the bandsaw  to 1" and crosscut the complete stick. So I end up with many pieces taped together measuring 1" long and 1-1/2" wide.
      These were cut from a 2'x6' redwood board.
      IMG_4886 by Dennis Rayon, on Flickr
    • February 11, 2020 7:52 PM EST
      • Posts
        905
      • Thanks
        92
      • Thanked
        366
      IMG_4976 by Dennis Rayon, on Flickr
      This is a couple packets of of cut shingles to be,
      IMG_4977 by Dennis Rayon, on Flickr
      I used a cutter because I have one, I also just split many with my fingers and thumbs. With the cutters i do 4-7 layers
      at a time.
    • February 11, 2020 7:57 PM EST
      • Posts
        905
      • Thanks
        92
      • Thanked
        366
      Start Laying Shingles
      I layout lines 1" apart for reference lines for me to follow how straight I am laying them.
      IMG_4889 by Dennis Rayon, on Flickr
      The rectangle hole for the chimney
      This side shingles all laid down
      IMG_4909 by Dennis Rayon, on Flickr
    • February 11, 2020 8:03 PM EST
      • Posts
        905
      • Thanks
        92
      • Thanked
        366
      Now the first layer of the steel shim stock rolled through the home made crimper, I use steel so I get REAL rust.
      This is my shear to shear the strips. can also be cut by a good pair of sizzors or tin snips could be used.
      IMG_4905 by Dennis Rayon, on Flickr
      Then the Crimper
       IMG_4906 by Dennis Rayon, on Flickr
    • February 11, 2020 8:17 PM EST
      • Posts
        905
      • Thanks
        92
      • Thanked
        366
      IMG_4953 by Dennis Rayon, on Flickr
      This is is Birds eye view of the roof, I treated the steel with a coating of Muratic acid and then spraying hrdrogen peroxide, that will activate rust affects immediately.
      Then over night it is at the limit of rust i want, then I remove rust in places as seen in the picture, with the drill and wire brush, then spray with a clear coat to slow down
      more growth of rust.
    • February 11, 2020 8:18 PM EST
      • Posts
        905
      • Thanks
        92
      • Thanked
        366
      Can see here the finished Chimney with a 3D printed chimney top
    • February 11, 2020 8:36 PM EST
      • Posts
        905
      • Thanks
        92
      • Thanked
        366
      Finished Model Pictures
      SIGNS
      IMG_E4930 by Dennis Rayon, on Flickr
      The signs are made from 2 layered acrylic lasered and cut on a laser.
      I used a dremel with a wire brush and fine sand paper , to slightly remove the top coating.
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
