  • Topic: 2020 Challenge By Dennis Rayon.... Denray Machine Welding Supply
    Back To Topics
    (0 rates)
    • February 1, 2020 11:07 PM EST
      • Mount Vernon, Missouri
      • Posts
        905
      • Thanks
        92
      • Thanked
        366
      IMG_4872 by Dennis Rayon, on Flickr
      I painted the inside of the bottom and glued and pinned it in place.
      The loading dock/Side sidewalk
      I want a loading dock in the front that leads to a sidewalk around the side, this dock will hold a few gas/oxygen bottles.
      I will be using redwood lumber. I cut all my lumber on a table saw.
      I start with a larger piece as the beam, two in the front to hold the joist., then nail the floorboards to the joist.
      IMG_4873 by Dennis Rayon, on Flickr
      IMG_4874 by Dennis Rayon, on Flickr
      IMG_4875 by Dennis Rayon, on Flickr
    • February 1, 2020 11:13 PM EST
      • Posts
        905
      • Thanks
        92
      • Thanked
        366
      The floorboards are being nailed on
      Using a wire brush mounted on a cordless drill, wire brush the redwood boards, giving them extreme weathering features.
      IMG_4876 by Dennis Rayon, on Flickr
    • February 1, 2020 11:20 PM EST
      • Pleasanton, CA
      • Posts
        1,137
      • Thanks
        1,309
      • Thanked
        877
      The variety of textures and colors is so typical of your builds and is just great. Nice job!
    • February 1, 2020 11:23 PM EST
      • Posts
        905
      • Thanks
        92
      • Thanked
        366
      Thanks Jim
    • February 3, 2020 5:05 PM EST
      • Posts
        905
      • Thanks
        92
      • Thanked
        366
      Thanks Dan, David and Devon, I Appreciate you compliments
      Dennis
    • February 4, 2020 11:00 PM EST
      • Post Falls, Idaho
      • Posts
        8,275
      • Thanks
        2,364
      • Thanked
        1,298
      Dennis what technique are you using for your chipped paint. If you said I missed it. It looks very good. A lot like the hairspray technique
    • February 4, 2020 11:18 PM EST
      • Posts
        905
      • Thanks
        92
      • Thanked
        366
      Devon , Easy, the doors are 3D printed in white
      spray painted in green
      wire brushed with Brass brush in a dremel slow speed
      2-3 coats of light  brown, watered down, washed on with paint brush, set a few minutes
      then rubbed down with paper towel.
    • February 4, 2020 11:31 PM EST
      • Waverly, Alabama
      • Posts
        2,021
      • Thanks
        786
      • Thanked
        793
      Dennis, I agree with Devon, the doors look very realistic.  Your painting technique gives a lot of depth to the layers of paint.  Great job.
    • February 5, 2020 10:58 AM EST
      • Posts
        905
      • Thanks
        92
      • Thanked
        366
      Thanks Dan, Brand new paint jobs are so easy, compared to old looking, but surprisingly this was quite simple, I had never done this type before.
      Dennis
    • February 5, 2020 11:02 AM EST
      • Post Falls, Idaho
      • Posts
        8,275
      • Thanks
        2,364
      • Thanked
        1,298
      Dennis you are one of the masters of "old" looking
    • February 5, 2020 11:05 AM EST
      • Posts
        905
      • Thanks
        92
      • Thanked
        366
      Thanks Devon
      I just copy what I see in the mirror every morning
    • February 5, 2020 12:51 PM EST
      • Post Falls, Idaho
      • Posts
        8,275
      • Thanks
        2,364
      • Thanked
        1,298
      Dennis Rayon said:
      Thanks Devon
      Lol,
      Good one.
    • February 10, 2020 10:52 PM EST
      • Posts
        905
      • Thanks
        92
      • Thanked
        366
      My chimney needed to be made smaller, it is not easy to cut the parts down SAFELY. I used my table saw with a sled, set for 45 degrees cut, with a special hold down to
      hold down the part safely, then sliding through the blade.
      The finished chimney can be viewed in the finished models
       IMG_4888 by Dennis Rayon, on Flickr
    • February 10, 2020 11:11 PM EST
      • Waverly, Alabama
      • Posts
        2,021
      • Thanks
        786
      • Thanked
        793
      Ingenious, Dennis.  Thanks for sharing.
    • February 10, 2020 11:13 PM EST
      • Posts
        905
      • Thanks
        92
      • Thanked
        366
      Here is the rafters for the lean to shed. I cut them out of acrylic 1/16" thick, with the perlins out of 1/8". I notched the rafter to accept the perlin with
      a locked in feature. The complete rafter display uses no glue, the joints fit quite snugly.
      IMG_4963 by Dennis Rayon, on Flickr
      The next picture shows what I use sometimes for my roof. I either use a 20Gage carbon steel or a thin aluminum. I use a foof that will turn the water regardless
      how well the roofing (shingles or tarpaper ect) turns the water. This one is the 20 gage steel, I know most people do not have access to equipment to do this procedure.
      This works very well for long lasting roofing systems that will endure all extremes of weathers.
      IMG_4961 by Dennis Rayon, on Flickr
    • February 10, 2020 11:18 PM EST
      • Waverly, Alabama
      • Posts
        2,021
      • Thanks
        786
      • Thanked
        793
      Nice looking roof structure, Dennis.  Do you use a laser or CNC to cut the acrylic?
    • February 10, 2020 11:19 PM EST
      • Posts
        905
      • Thanks
        92
      • Thanked
        366
      The bolt in the center will hold the roof down, the building does not show the board yet, I will fasten a board something like a ceiling, the front doors open
      so i can put my hand inside to access the wingnut holding the roof on.
    • February 10, 2020 11:20 PM EST
      • Posts
        905
      • Thanks
        92
      • Thanked
        366
      Thanks Dan
      Laser
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
