  • Topic: Tim's Mik Challenge - Orthodox Shrine
    Back To Topics
    (0 rates)
    • January 20, 2020 1:04 AM EST
      • Kenai, Alaska
      • Posts
        162
      • Thanks
        42
      • Thanked
        75
      http://www.largescalecentral.com/FileSharing/user_6912/Tim's%20Indoor%20Layout/walls%202.jpg
       The fiasco continues. Thus far, I have had (supposedly) securely glued pieces come apart, had to break apart other glued sections because they were upside down or wrongly oriented, measured thrice, cut twice and botched the cuts both times.  (doesn't count gluing my fingers together twice.) Still, progress of sorts is being made.
      no stranger to mistakes, I made plenty with the last two buildings, but this is a bit out of hand.
      The yellow inside the structure is construction paper - much of the wood is salvage from even more spectacularly failed projects, and I'd used ordinary construction paper as mock carpet and wall paper.
      This post was edited by Tim at January 20, 2020 1:13 AM EST
    • January 20, 2020 1:11 AM EST
      • Denver, Colorado
      • Posts
        2,283
      • Thanks
        345
      • Thanked
        644
         Tell me about it. I had to completely start over from scratch. (Fortunately I was able to make something out of the abandoned start.)
    • January 20, 2020 1:15 AM EST
      • Kenai, Alaska
      • Posts
        162
      • Thanks
        42
      • Thanked
        75
      Shout out to Pete Lassen for the info on posting photos. It's a bit different on my computer, but you did identify the 'missing step.'
    • The following users say thanks to Tim for this useful post:
    • January 25, 2020 1:08 AM EST
      • Kenai, Alaska
      • Posts
        162
      • Thanks
        42
      • Thanked
        75
      The disaster continues.  Decided against using the LEMAX stone mat as a foundation, instead said 'screw it,' and started cutting and gluing the scribed siding in place.  Botched a couple cuts, ended up having to piece together the far wall (fortunately, that will be out of sight from casual observation).  The siding has an annoying tendency to curl once glue is applied,
    • January 25, 2020 1:10 AM EST
      • Kenai, Alaska
      • Posts
        162
      • Thanks
        42
      • Thanked
        75
    • January 25, 2020 2:08 AM EST
      • Vail, Az
      • Posts
        5,397
      • Thanks
        1,877
      • Thanked
        1,350
      Maybe a contact cement would prevent the water based glue warpage...  or a gel CA.
      Mistakes are learning aids.
      John
    • January 25, 2020 3:09 AM EST
      • Kenai, Alaska
      • Posts
        162
      • Thanks
        42
      • Thanked
        75
      well, the siding is on the church now...though that still leaves the priests quarters.  Might try different glue there.
      trim should hide the really visible flaws...after all, that's what its for, right?
      This post was edited by Tim at January 25, 2020 3:11 AM EST
    • January 26, 2020 2:04 AM EST
      • Kenai, Alaska
      • Posts
        162
      • Thanks
        42
      • Thanked
        75
      Drat.  I KNEW I shouldn't have done it.  I KNEW...but I went and tossed that chimney on my workbench last week...and the mess is such I can't find it.  Guess I'll systematically sift through the whole pile tomorrow...
      found it.  but how did it migrate to the bottom of the pile?  I really do need to clean that table off....
      This post was edited by Tim at January 26, 2020 2:17 AM EST
    • January 26, 2020 5:13 PM EST
      • Cape Cod,
      • Posts
        3,048
      • Thanks
        157
      • Thanked
        267
      Your build is coming along.
    • January 26, 2020 5:46 PM EST
      • Kenai, Alaska
      • Posts
        162
      • Thanks
        42
      • Thanked
        75
      Just starting to do the math for the roof...
    • February 2, 2020 8:02 PM EST
      • Kenai, Alaska
      • Posts
        162
      • Thanks
        42
      • Thanked
        75
      slow painful progress continues.
      The priest figure arrived - technically he's closer to 1:32 than 1:24...but it's a background structure.  I keep telling myself that.
      Botched the cuts for the main roof section twice, (after measuring thrice), decided to use the pieces anyhow.  Holding off for a bit before setting the next two pieces in place.  Grey cardboard shingles should cover the flaws.  Still trying to decide just where to put the chimney, which is why the clerics quarters are roofless. (I think he's upset about that.)
      Anyhow, the shrine as it stands now, with the priest surveying his dominion...
    • February 3, 2020 3:14 AM EST
      • Kailua, HI
      • Posts
        790
      • Thanks
        506
      • Thanked
        558
      The priest is wearing red! It's Epiphany!  Send him back him back to seminary immediately!   His liturgical shortcomings aside, the building is coming along great.  I had a hard time getting stuff to stick to our bakery, too, without it warping.  I used TiteBond III and weighted objects with some success.  Note the word "some."
    • February 3, 2020 5:02 AM EST
      • Kenai, Alaska
      • Posts
        162
      • Thanks
        42
      • Thanked
        75
      Hard to see in the pic, but the priest has the sort of wide eyed goofy grin some people get when they're pretending really hard to be pleased.  As this is envisioned to be a rundown church in a seedy part of town...yeah, that's understandable.
      That said, this project has been definitive proof of Murphy's Law - the measures never seem to match the cuts, the wood is warped, the glue don't want to stick...background structure...I keep telling myself that.  Just today I broke my exacto knife cutting some trim.
      This post was edited by Tim at February 3, 2020 5:03 AM EST
    • February 3, 2020 6:23 AM EST
      • West Grove, Pennsylvania
      • Posts
        11,142
      • Thanks
        743
      • Thanked
        1,129
      Welcome to the world of model building. ..............
      "Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." --Martin Luther King Jr
    • February 3, 2020 6:42 AM EST
      • Not one of the WannaBe's,
      • Posts
        5,822
      • Thanks
        1,488
      • Thanked
        711
      Tim, even with the trials you are being put through the build is looking good.
       I must say that with owning one myself, I do believe that worm drive saw may be a bit heavy for our building purposes.
      just saying
    • February 3, 2020 11:15 PM EST
      • Kenai, Alaska
      • Posts
        162
      • Thanks
        42
      • Thanked
        75
      Got the roof base glued on, along with the base for the steeple...with surprisingly few mishaps...
      Put the chimney together, decided it needed a fireplace to sprout from even though the priests quarters will be...extremely hard to glimpse.  Played around with damaged 1/24 dollhouse stuff and bits and scraps...now he has a fireplace, wardrobe, and a bed.  Not all that great, and in need of fine tuning, but...
      and...
      This post was edited by Tim at February 3, 2020 11:57 PM EST
    • February 4, 2020 2:29 AM EST
      • Kailua, HI
      • Posts
        790
      • Thanks
        506
      • Thanked
        558
      Tim,
      Every project I apply my conservative measure 45 times and cut once rule.  If two pieces come out the same, it is by accident!  You are way ahead of me here!
    • February 8, 2020 11:11 PM EST
      • Kenai, Alaska
      • Posts
        162
      • Thanks
        42
      • Thanked
        75
      despite ongoing calamities, I might actually finish this project by the deadline.
      mostly trim, figuring out how to fix the steeple (white paper, pen, and brown magic marker), and the last bit of roof for the priests quarters.   And the cross atop the dome.
      Barring unusual circumstances, these pics show the sides that will be casually visible.
      This post was edited by Tim at February 9, 2020 2:07 AM EST
    • February 8, 2020 11:27 PM EST
      • Waverly, Alabama
      • Posts
        2,021
      • Thanks
        786
      • Thanked
        793
      Nice job, Tim.  I like the use of the Christmas ornament.
    • February 9, 2020 10:43 AM EST
      • Post Falls, Idaho
      • Posts
        8,275
      • Thanks
        2,364
      • Thanked
        1,298
      That Christmas ornament worked out great
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
