Forums General Gardening
  • Topic: Drip Irrigation
    Back To Topics
    (0 rates)
    • May 17, 2019 2:44 PM EDT
      • People's Republic Of Maryland, USA
      • Posts
        2,227
      • Thanks
        1,539
      • Thanked
        1,139
      Great thread!
      FWIW, here's what I use.
      • Mr Mister lines & sprinklers like Ken mentioned, very fun and easy to install, adjust and make changes / additions to.
      • Two Rainbird anti-everything zone valves, which worked perfectly for a whole year.
      • My controller is an Orbit "4-Station Indoor/Outdoor Swing Door Timer." This thing is highly programmable, allows 2 programs per day, time settings for up to 4 zones per program, accepts rain sensor input for user-selectable rain delays, etc. Runs off 120vac input, which you have to supply from a GFCI; but has an internal battery to keep its clock & programs going when power goes out (which we experience a lot of). A lot of functionality foe only $35 from Lowes (when I got it about 4 years back).
      • I run the system from a tee and check valve from my main house water line.
      Here's the "control panel, with (from the right) shut off, filter, valve manifold and drain-vent cock.
      I'd like to replace my control valves and put something simpler in -- like basic solenoid valves, without any diaphragms to stiffen or bust. But that would force me to a more robust BFP, and I haven't seen cheap versions of those.
      So like I said, great thread, thanks for starting it Devon, and I appreciate the knowledgeable responses.
      Cliff
      This post was edited by Cliff Jennings at May 18, 2019 7:35 PM EDT
    • May 17, 2019 5:46 PM EDT
      • Burke, Virginia
      • Posts
        7,426
      • Thanks
        221
      • Thanked
        828
      This just strikes me as one of those "drip" "drip" kind of threads...
      Bruce
      http://jbrr.com/
    • May 17, 2019 6:49 PM EDT
      • Posts
        14,675
      • Thanks
        2,642
      • Thanked
        1,539
      Mr. Mister "Healing Waters"
    • May 17, 2019 9:22 PM EDT
      • Marysville, Kansas
      • Posts
        917
      • Thanks
        954
      • Thanked
        371
      Lame attempt Rooster!
      This is how you do it:
      This post was edited by Chris Kieffer at May 18, 2019 7:49 AM EDT
    • May 17, 2019 11:42 PM EDT
      • Vail, Az
      • Posts
        5,388
      • Thanks
        1,862
      • Thanked
        1,343
      John
    • May 18, 2019 8:11 AM EDT
      • Posts
        14,675
      • Thanks
        2,642
      • Thanked
        1,539
      Not really Chris.....Did you read the system that Cliff installed? I don't see how CCR relates to Mr MISTER ??
    • May 18, 2019 11:10 AM EDT
      • Post Falls, Idaho
      • Posts
        8,275
      • Thanks
        2,364
      • Thanked
        1,298
      See I like cliffs system. That looks like it the necessary level of over complication I require.
    • May 18, 2019 12:54 PM EDT
      • Posts
        9,393
      • Thanks
        249
      • Thanked
        861
      If you need a more complex solution, just let me know:
    • May 18, 2019 3:16 PM EDT
      • Santa Ana, CA
      • Posts
        1,688
      • Thanks
        2
      • Thanked
        141
      Devon Sinsley said:
      Hey all you gardeners.
      All of this run off a single timer located in my yard cabinet which has power to it.
      Does anyone see in inherent problems with this simple design. And suggestions/improvements I am not thinking of. I know little to nothing about drip systems. And when I say drip I am including the little sprayer nozzles possibly also. But mainly just the little soaker/drip type stuff.
      Yes,
      The first time it rains when your system is programmed to come on and you have to make your way through the rain to put the system in "rain delay" mode at the timer.  We have an attached garage and our irrigation timer is located within right next to the house door.
    • May 18, 2019 5:27 PM EDT
      • Posts
        2,227
      • Thanks
        1,539
      • Thanked
        1,139
      Captain Overthink here, at your service!
    • May 18, 2019 7:12 PM EDT
      • Saint Helena, CALIFORNIA
      • Posts
        432
      • Thanks
        36
      • Thanked
        106
      There are number of rain sensors available for irrigation systems that will automatically delay or skip a cycle.
    • May 18, 2019 9:50 PM EDT
      • Post Falls, Idaho
      • Posts
        8,275
      • Thanks
        2,364
      • Thanked
        1,298
      Todd,
      Hadn't even crossed my mind about having it off in the rain and as a water guy it should have been top on my list. It's one of my pet peeves when I drive around and see sprinklers on in the pouring rain and then have to listen to customers complain about overage charges on their bill.
      One nice thing about many of the controllers they do allow for a rain gauge. There is no convenient place to put a controller in doors without drilling into my house. My garage is unattached and on the other side of my property.
      This is something to consider. A rain gauge would be the best solution.
    • May 19, 2019 12:57 AM EDT
      • Santa Ana, CA
      • Posts
        1,688
      • Thanks
        2
      • Thanked
        141
      Something else to consider, though it may not be a problem for you.
      My system has a transmitter that lets me control the stations remotely.  This is nice when you work on the system (e.g., clean out dirt from a fitting) and you want to try it without continually running back and forth to the panel.  They only have a certain range.
    • May 19, 2019 3:22 AM EDT
      • Posts
        9,393
      • Thanks
        249
      • Thanked
        861
      mine is controlled via my home network, available anywhere home or away, from computer, phone, tablet, helps debugging, adjustments..
    • May 19, 2019 9:12 AM EDT
      • Post Falls, Idaho
      • Posts
        8,275
      • Thanks
        2,364
      • Thanked
        1,298
      Greg,
      You're such a nerd, and I like it. Lol. Smart sprinkler systems. Who'd have thunk it. I might have to look into this just so I can geek out on it.
    • May 19, 2019 10:34 AM EDT
      • Peoria, NW of Phoenix, Arizona
      • Posts
        1,503
      • Thanks
        269
      • Thanked
        347
      overthinking it. controller, simple as can be , 2 stations and use the hose to water the tree, barely turn it on and let it run for about an hour filling the well around base of the tree root system. 2 stations to water all the plants, 1/2 g an hour drippers and small 1/4" line sprayers. Get the round adjustable sprayers and dial according to plant needs. Quit thinking it 97 ways from sideways!
      Butt Modeler #2
    • May 19, 2019 10:51 AM EDT
      • Port Orchard, Washington
      • Posts
        2,389
      • Thanks
        96
      • Thanked
        305
      I've got a even simpler solution. Take a bucket, fill with water. Walk to plant, dump water. Repeat. Or make it automatic by making your kids do it for you.
    • May 19, 2019 1:44 PM EDT
      • Santa Ana, CA
      • Posts
        1,688
      • Thanks
        2
      • Thanked
        141
      Pete Lassen said:
      overthinking it.
      Happens.  For example, who wants to be out in the garden, digging in the mud, working on a line with water spraying everywhere, and have to drag their smartphone or tablet out there where it will get wet and covered in mud.  My transmitter is waterproof with a membrane keypad.
    • May 19, 2019 2:10 PM EDT
      • Posts
        9,393
      • Thanks
        249
      • Thanked
        861
      Devon, that system "Homeseer" controls interior and exterior lights, sprinklers, drip systems and fountain pumps. It changes schedules according to the length of the days. I have not automated the system to turn off if the ground is wet, but it's a simple $30 sensor. Oh, it even supplies power to the train layout.
      I have it to put everything on a single system, instead of having many different systems that have to be set. Also burglar/intrusion alarm, and camera system integrated.
      Overall, very flexible, like one program turns on the hall and kitchen lights at 6am only if it is a work day and it is dark (before sunrise), so lights are on in the morning if needed.
      So, all I had to add for the sprinklers was a panel with 16 relays to directly control the water solenoids. Even the filling of the fountains is automated.
      Overall, less time to mess with stuff, and I can control it from anywhere in a secure manner, none of my stuff is in the cloud.
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
