Forums General Prototypes
  • Topic: obssesed with little locos
    Back To Topics
    (0 rates)
    • May 21, 2016 8:08 AM EDT
      • South Central , PA
      • Posts
        15,338
      • Thanks
        3,310
      • Thanked
        1,873
      Yes.... Cumberland Valley
    • May 21, 2016 8:59 AM EDT
      • Cape Cod,
      • Posts
        3,131
      • Thanks
        198
      • Thanked
        358
      Dave Taylor said:
      On the second little 2-2-0 ( the one from the book )  Did anyone notice the size of the steam dome?  Its huge, as big around as the boiler.  Maybe it doubles as a storage drum, or something.
      Maybe it is more like a "T" boiler ?
      Devon  Go for the Garratt !
      Seeing photos of all these cool little engines with the built on passenger cars I'm looking at a spare Stainz I have and thinking that if I take off the cab and replace it with a small euro passenger car body keeping the rear truck on that it would make a cool little loco.
      Could it be that easy?
    • May 21, 2016 9:51 AM EDT
      • Pittsburgh, Pennsylvania
      • Posts
        11,160
      • Thanks
        129
      • Thanked
        931
      I still want to build a Railmotor.
      One of the guys on LSOL told me that he could trust me to find a prototype of a steam powered RDC. But I think the board of directors would like to tour the railroad in style, in an Americanized Railmotor.
      Yes Devon, its on the "someday list", meaning it may never get built. But I can dream.
      Rooster, ok, I will. I will shut up, for now.
      Shannon car Shops
      Home of the infamous leg lamp
      I.A.R.R.R. Member #12
      and King Butt Modeler
    • May 21, 2016 7:10 PM EDT
      • Posts
        15,338
      • Thanks
        3,310
      • Thanked
        1,873
      Dave,
       I think the pics Vic posted are the same loco but not sure. If that is the case it appears as you are correct that it probably doubles as a sanding dome as well judging by the lines and what has been removed under the bell.
    • May 21, 2016 7:15 PM EDT
      • Posts
        15,338
      • Thanks
        3,310
      • Thanked
        1,873
      My favorite is still the CVRR 2-0-2
    • May 21, 2016 8:17 PM EDT
      • Vail, Az
      • Posts
        5,439
      • Thanks
        1,982
      • Thanked
        1,368
      Easy Peasy...
      John
    • May 21, 2016 8:25 PM EDT
      • Posts
        11,160
      • Thanks
        129
      • Thanked
        931
      Well, if its going to have a rear truck, like the unit pictured above, then the power unit either has to be able to swivel, or the rear truck needs to be able to slide side to side. The sharper your curves, the more movement you would need.
      So, yes its that simple.
      So, no, its not quite that simple.
      This post was edited by David Maynard at May 21, 2016 8:26 PM EDT
      Shannon car Shops
    • May 21, 2016 8:58 PM EDT
      • Posts
        15,338
      • Thanks
        3,310
      • Thanked
        1,873
      Perhaps,
      However at this point it is only pure speculation as many threads are!
    • May 22, 2016 5:28 AM EDT
      • Posts
        11,160
      • Thanks
        129
      • Thanked
        931
      Shannon car Shops
    • May 22, 2016 8:01 AM EDT
      • Hendersonville, North Carolina
      • Posts
        312
      • Thanks
        93
      • Thanked
        117
      I kitbashed a steamcoach using a Bachmann combine and a Porter kit from Northeast Narrow Gauge.  I too was enamored with small locos and unusual modes of RR transportation.
      To overcome the issue with turning tight radii, I designed the 0-4-0 driver portion to pivot as David pointed out.
      Here's is what the portion looks like separated from the chassis.
      I ended up removing the drive system that was part of the kit and replaced it with a Magic Carpet Drive from NWSL.
      Doc Watson
      This post was edited by Don Watson at May 22, 2016 8:03 AM EDT
    • May 22, 2016 8:33 AM EDT
      • Burke, Virginia
      • Posts
        7,754
      • Thanks
        503
      • Thanked
        1,087
       It's not steam, but I used a motor block from an RS-3 and some brass to make this little critter.
      Bruce
      http://jbrr.com/
    • May 22, 2016 11:02 AM EDT
      • Cape Cod,
      • Posts
        3,131
      • Thanks
        198
      • Thanked
        358
      Nicely done Don.
      I hadn't thought about the pivot of the rear truck and motor block.  I was thinking if the body was short enough I could get away with having only the rear truck pivot.  As Rooster said it is only speculation right now.   This one is way down on the To Do list.
      So many projects so little time.
    • May 22, 2016 11:08 AM EDT
      • Posts
        11,160
      • Thanks
        129
      • Thanked
        931
      Todd, I wonder, on a short enough body, if you used a single drive axle, if you could get away without it swiveling.
      Shannon car Shops
    • May 22, 2016 11:30 AM EDT
      • Vail, Az
      • Posts
        5,439
      • Thanks
        1,982
      • Thanked
        1,368
      Load the boiler with depleted Uranium and have the back end float, use a long draw bar to the truck to allow a pivot under the floating body ... Easy Peavy
      John
    • May 22, 2016 1:23 PM EDT
      • Posts
        11,160
      • Thanks
        129
      • Thanked
        931
      Oh yea. Sure. Now where did I put that paper bag full of depleted uranium?
      Shannon car Shops
    • May 22, 2016 4:13 PM EDT
      • Vail, Az
      • Posts
        5,439
      • Thanks
        1,982
      • Thanked
        1,368
      I would have suggested lead,but the State of California knows it causes cancer.
      John
    • May 22, 2016 8:15 PM EDT
      • Posts
        11,160
      • Thanks
        129
      • Thanked
        931
      John, breathing, and just being alive, causes cancer in California.
      Shannon car Shops
    • May 23, 2016 8:01 AM EDT
      • Phippsburg, Maine
      • Posts
        1,225
      • Thanks
        61
      • Thanked
        506
      Some of the early Forney s (0-4-4T) had a pivoting rear truck and flange less rear driver... Later ones had both drivers flanged and a pivoting and swinging rear truck.
    • May 23, 2016 10:21 AM EDT
      • Post Falls, Idaho
      • Posts
        8,788
      • Thanks
        2,937
      • Thanked
        1,685
      I am already trying to figure out how to do this on my 0-4-4 I get the concept but I have to start building the rear frame and make it so the truck pivots and slides.
    • May 23, 2016 12:31 PM EDT
      • Phippsburg, Maine
      • Posts
        1,225
      • Thanks
        61
      • Thanked
        506
      I mount the rear truck on a bar which pivots under the cab.   The truck has to be sprung to deal with ups and downs on the track.
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
