With the number of cars in our two fleets, and the handling the rolling stock experiences, the “Tails” on the Kadee couplers are a great indicater that a coupler is in good adjustment. If it is low, it indicates that the coupler is not at the correct height…if it was mounted correctly, and checked in the first place. There have been the odd coupler that came with the tail a bit low, but it w3as caught in the checking prosses when it was mounted.
The tails also represent air hoses, and when cut off, the cars appear to be missing something. I’m not about to add air hoses to 4oo cars, and have something else to maintain…
When you start adding features to locomotives, then there often occurs the need to remove the tails…but then it just involves one pair of air hoses, to be added, if you care to do it.
One model of the B’mann Annie, has a pilot that extends too much, if you are mounting a Kadee coupler to it, and using the Kadee set suggested for it. The trick there is to order another pilot for it…there are several to choose from. The Annie/Big Hauler with the diamond stack, and wood load in the tender, is the one that suffers from the extended pilot.
I have been requested on occasion, to nip off the tails of a car belonging to a visitor. They claimed the tail was catching on the switches.
I always check with my trusty Kadee coupler gauge, when asked to do that surgery…sure enough, in 99% of the cases, the coupler is mounted too low…
I hope this helps , for anyone contemplating the “Drastic” surgery…!!!
I too use the screw driver uncoupling method. What works best is a long shafted Phillips #2 screw driver…if anyone can find a bunch of the correct size in a “Dollar Store”, I’d like to hear of it. I don’t want a high quality driver, just a cheapy, at $1-$2 each…
Fred Mills
