The dwarf Alberta spruce (Picea glauca “conica”) is a conifer found naturally in the harsh conditions of the Northern Rockies near Lake Laggan, Alberta. Unlike other conifers, it does not produce any cones or seeds, so the only method of propagation is by planting cuttings, a method that requires time and patience, as the plant will not be as large as a nursery plant for a few years. Still, if you want a large number of trees, this is a very inexpensive method of supply.
This is the method that I use, and it works fairly well. Not every cutting will survive to be planted, but I figure that if I get half of my cuttings to survive their first year in the ground, I am way ahead of the power curve.
I stole a lot of this information from various sites, but, then this is the method that I used, so I’m really just being lazy, not wanting to reinvent the wheel.
In December, or June if you are in the Southern Hemisphere, take 4- to 6-inch cuttings from stems that are firm and slightly flexible but not hard and woody. Cuttings from young trees less than six years old root best. Before taking cuttings, sterilize a sharp knife or pruners by wiping the blades with a mixture of one part chlorine bleach to nine parts water. Use the cuttings immediately, for best results. If you can’t use them right away, wrap them in a moist paper towel and place them in a Zip-Loc baggie.
Remove the lower third of needles from the cutting, and dip the end in rooting hormone. I score the end of my stems (about an inch) to help the plant absorb the rooting hormone.
Fill 3 inch diameter, sterilized planting pots with a good quality potting soil, mixed with pearlite to hold the water, and place the tip of one cutting at least 2 inches deep in each pot. Tamp the soil around the cutting to remove air pockets. Another method is to place a pinch of general-purpose, slow-release fertilizer in the bottom of the pots, then fill the pots with equal parts fine bark and peat moss. I add some pearlite to this mix, too. Both methods work equally well.
Place each pot into a saucer filled with water and wait for the pearlite to absorb enough water so that the top of the soil is moist. This method of initial watering prevents the rooting hormone from being washed away from the cutting. Wrap the pot in a plastic bag ( a bread bag will do the trick), seal with a rubber band, and cut three or four holes in the bag to allow for air circulation. The bag keeps the mini-climate humid, and the holes allow the plant to breathe.
Place the pots in a warm (>60F), sunny place, but not where they will be in direct sunlight. A location on top of a warm appliance such as a refrigerator speeds rooting.
Rooting typically takes 6-8 weeks, so be patient. You can test the cutting at 8 weeks by very gently tugging on the cutting. If it resists, the cutting took root, if it comes out without any resistance, the cutting failed and you need to start over, or move on to the next pot.
Check the cuttings every week. Water lightly if the potting mixture feels dry. Remove the plastic when new growth appears – typically in about three months – indicating the dwarf Alberta spruce cuttings have successfully rooted.
Transfer each cutting to a 6-inch pot filled with two parts garden soil, one part sand and one part peat moss. I still add a bit of pearlite to this mix. Place the pots in partial shade for five to seven days. Then move the pots to bright light.
Allow the new dwarf Alberta spruce to mature at least until all danger of frost has passed the following spring, then plant the tree in full to partial sunlight. If possible, let the plants mature for an extra year in that 6 inch pot. A larger tree with a well-developed root system is more likely to survive outdoors.
Continue watering newly planted spruces, if nature doesn’t provide soaking rains, right up until the ground freezes hard for the winter season. Established plants are relatively drought tolerant.
Alberta Spruce like an acid, well drained soil. My soil is mostly sand, so I meet the first criteria, but it is fairly alkaline. Rather than fuss with expensive soil conditioners, which limit root growth to where the conditioner is, I just save my coffee grounds and give the soil around each tree a dressing of coffee grounds once or twice a year. Mulching helps retain moisture.
After the trees reach 12 or so inches in height, I remove the lower two inches of branches. This make the tree look better ( I think), and helps prevent spider mite infestation since those critters travel from tree to tree by using the ground.
I find that, over time, planting the new trees at least 18 inches apart works best, especially when they’ve been in the ground for several years.
Browning of needles can be due to spider mites. If you shake a branch over a white piece of paper you may see the tiny moving bugs. DO NOT use horticultural oils or chemical insecticides. Dwarf Alberta spruces are sensitive to oils and many pesticides. You may treat a small infestation by spraying with water, and this is good to do a couple times a week as a prevention. You can also use an insecticidal soap solution, once a week for several weeks. I lost several trees last year to those critters, and saved many others by just using a soapy spray. The mites haven’t come back, so I guess I “done good.”
Pruning the tree to imitate other conifers in the forest is high art. I don’t start pruning my trees until they have had a year to adjust to their new home. I prune mine in spring after new growth has started. Dwarf Alberta Spruces are easy to take care of. They do not flower and always have green foliage. This spruce attracts many types of birds. It is resistant to deer.
I suppose that this method can be used on other conifers like the juniper and cypress, but I haven’t tried that, yet.
The dwarf Alberta spruce (Picea glauca “conica”) is a conifer found naturally in the harsh conditions of the Northern Rockies near Lake Laggan, Alberta. Unlike most conifers, the dwarf Alberta spruce does not produce any cones, so it cannot be propagated through seeds. Instead, the simplest way to grow a dwarf Alberta spruce is through a technique known as cutting. Cutting is the process of placing a tree branch into a potting medium, triggering the branch to sprout roots. Using cutting as a propagation technique takes time and patience, as the plant will not be as large as nursery plants for a few years.
Read more : http://www.ehow.com/how_8748196_grow-miniature-alberta-spruce-cuttings.html
s & Herbs
How to Grow a Miniature Alberta Spruce From CuttingsBy Steven White, eHow Contributor
Cuttings of Alberta spruce can grow their own roots to start a new tree.
