Forums » For Sale/Trade
List of newest posts
    • June 9, 2020 10:28 AM EDT
    • John Lenheiser said:
      Since I just joined the forum today and couplers are of interest to me I would like to know how you rate the knuckle couplers by brand. I've been in G scale for some 30 years and have always used the LGB Knuckle couplers, true they are probably the most over sized one on the market, but they have always worked well for me. I did purchase most of my coulpers (LGB) some 25-30 years ago and at a cost of around $5.00 a pair. When I look at what it would cost me to change all them out for a more to scale coupler today I sometimes wonder if it's worth the cost, were talking 40 pair here.
      trainman
      If they are working well for you, why would you consider switching?   What are you looking for in a coupler?
    • June 9, 2020 10:10 AM EDT
    • Since I just joined the forum today and couplers are of interest to me I would like to know how you rate the knuckle couplers by brand. I've been in G scale for some 30 years and have always used the LGB Knuckle couplers, true they are probably the most over sized one on the market, but they have always worked well for me. I did purchase most of my coulpers (LGB) some 25-30 years ago and at a cost of around $5.00 a pair. When I look at what it would cost me to change all them out for a more to scale coupler today I sometimes wonder if it's worth the cost, were talking 40 pair here.
      trainman
    • June 8, 2020 8:26 PM EDT
    • How many couplers do you want, Lou ?    Are they only for your use ?
        Fred Mills
    • June 8, 2020 7:23 PM EDT
    • I would be interested FR. Fred. I have seen them sell for anywhere from $4 a pair to a ridiculous $20 a pair.
    • June 8, 2020 5:02 PM EDT
    • I used to give mine away to someone. I don't remember who it was at this moment.
    • June 8, 2020 2:57 PM EDT
    • Following.  Me too.
    • June 8, 2020 2:51 PM EDT
          What demand is there for Aristo Knuckle couplers ?    What prices are being asked for them ?
          I'm considering a possible clearance of some...
            Fred Mills
              There are also some Bachmann couplers in the pile....even the odd metal one...
    • June 9, 2020 7:37 AM EDT
    • I have 2 or 3 ASM turnouts in code 250 brass
      Ty
    • May 29, 2020 1:39 AM EDT
    • Hey all,
      I know some of you have some of these boards laying around.
      Let me know because I want to buy!
      Thank you,
      - Colin
    • May 28, 2020 8:03 AM EDT
    • Rick Marty said:
      Dennis,
      I have about a dozen packs of "Marker lights w/jewels and brackets"
      None of the packs are marked OM34
      they are marked
      OM 34120
      #1028
      #1030
      The products were renumbered several times through the years depending on product movement and other things.
      The biggest shift in numbering came when  1:20 scale took off.
      Near as I have been able to determine no matter the numbers used the parts are the same.
      Take a look at OM's page under 1:20 scale detail parts for the marker light kits.
      If interested in some contact me.
      Thanks Rick
      Thanks, have to figure out which one will look right on the caboose.
      I have a "17th National Garden Railway Convention" Caboose made by HLW. I lost one of the marker lamps.
      HLW does not have any stock on this marker lamp.
      Dennis
    • May 27, 2020 2:42 PM EDT
    • "Marker lights w/jewels and brackets"
      It's amazing how many different ones they sell.
    • May 27, 2020 11:15 AM EDT
    • Dennis,
      they are marked
      OM 34120
      #1028
      #1030
      Thanks Rick
    • May 27, 2020 9:45 AM EDT
    • Dennis Cherry said:
      I am interested in one OM-34 package.
      Dennis
      Sorry, Dennis. They were the first thing to go.
    • May 27, 2020 7:50 AM EDT
    • I am interested in one OM-34 package.
      Dennis
    • May 26, 2020 8:29 AM EDT
    • Nice group of parts Pete.
    • May 26, 2020 7:54 PM EDT
    • Rick:
      Thanks.  Since this is new it is way too shiny so at worst case I'll mess it up trying to get it apart before aging and rusting it up.
    • May 26, 2020 7:12 PM EDT
    • Mark,
      The one I obtained was broken in two pieces and crusty.  I could find no way to get it apart for really good cleaning so just wire brushed it and used a couple sizes of brass tubing
      and epoxy to extend the tower.  Not much help I know but something to consider.
    • May 26, 2020 5:29 PM EDT
    • Jason, Rick or anyone else:
      I finally received a MTH Water Column from an ebay purchase after canceling my repeatedly delayed order from a "real" seller.
      So, before I totally mess something up can someone enlighten me on how to remove the column so I can replace it with a taller one?  It appears to be held together by the finial on top and the base shroud on the bottom.  I can remove the giant Phillips screw on the base but that only removes the base from the column. It appears that the 5/16 column is possibly glued, painted in or somehow attached to the finial and shroud and my attempts to twist them apart has failed.  So I thought I'd ask before I apply more draconian methods.
      Thank you for whatever assistance you can provide.
    • May 25, 2020 8:09 PM EDT
    • still Available. I have a combine, vista dome and coach $65 ea plus shipping, or local pickup.
