Forums » Reference
List of newest posts
    • August 31, 2019 10:38 AM EDT
    • Bob,
      A little over the top, isn't it?
      LSC won't and isn't responsible for members pics.
    • August 29, 2019 1:45 PM EDT
    • Gentlemen,
      PLEASE STOP POSTING COPYRIGHTED MATERIAL ON LSC!!!
      YOU ARE JEOPARDIZING THE FORUM.
      What you folks do back channel or off the forum is none of my business, but I enjoy this forum too much to see folks do what they know is ILLEGAL.
    • August 29, 2019 6:56 AM EDT
    • This is it
    • August 29, 2019 6:54 AM EDT
    • Found it, just need to work out the scaling
    • August 28, 2019 10:37 AM EDT
    • Iain Collingwood said:
      Any one have scale plans for a flange
      I believe
      NGSL Gazertte did an article with plan check their index.
    • August 27, 2019 10:32 PM EDT
    • Any one have scale plans for a flanger?
    • January 7, 2019 9:54 PM EST
    • You nailed it Cliff. After reading the patent description. You are correct in that ballast is dumped with side dumps on the shoulders and then the spreader pulls it into the center and then spreads it between the rails with excess being pushed to.the shoulders again.
      Very cool and economical design and I think with the drawings and the patent description it can be modeled. May give it a go after the challenge.
    • January 7, 2019 8:43 PM EST
    • Very cool MOW car Devon. Had to check out the plan view from your link,
      From the bracing and the shape / orientation of the blades, I'd say the car's operational direction was toward the left. The big blades scooped the loosely-dumped gravel toward the center, and the little vee-blade toward the right spread the ballast evenly over the ties, inboard and outboard of the rails.
      If so, maybe that's the opposite of how Jordan spreaders work, with their blades acting like a plow (vs a scoop).
      [edit]
      After some poking around, I found the additional patent figures; lot of detail! Would be a great model, Devon.
      The last figure shows how the gravel is scooped from outboard piles and distributed; figure 7 shows how the derrick is used to lift and stow the blades.
      Ballast-spreading car
    • January 7, 2019 4:40 PM EST
    • John Caughey said:
      OMG! A naked jordan spreader!
      Don't look Ethel!
    • January 7, 2019 12:24 PM EST
    • OMG! A naked jordan spreader!
    • January 7, 2019 11:25 AM EST
    • So came across this track ballasting car while looking for work train stuff. Pretty cool and a fun project to add to the work train. Patent Track Construction book
      * if you can't tell there are two links. The one that says Patent has the description and all the drawings of the spreader. The language of the patent does a good job of describing what it does and how the part work together. I think with some creativity a person could make this from the patent information.
      Scott Ballasting Car
    • January 1, 2019 4:49 PM EST
    • Well, this would be a cool little project, especially if you're looking for something for the "Challenge".
    • December 31, 2018 3:43 PM EST
    • Bob Cope said:
      Interesting design Fred. If my memory is correct, Bruce Chandler did a similar article here http://www.largescalecentral.com/forums/topic/17266/bucket-coaling-station.
        Thanks, Bob...don't know how I missed it, or whether I've forgotten, but I felt that build should be brought out of the archives for a second look.
    • December 30, 2018 8:36 PM EST
    • Thanks Fred, I am aware of CPR's light locos in a couple of provinces. Trains and later Classic Trains magazines have shown them.
      I also appreciate how much manual labor was used. I only saw the sand house to the left and weeds behind the stand, so here coal must be delivered by boxcar to keep it dry and neat.
    • December 30, 2018 8:00 PM EST
    • Yes, Bob; Bruce did build one which was similar in it's method of loading coal. It had more of a protective building around it, with a roof and 3 sides, if I remember correctly. He made a great job of it.
        Fred Mills
    • December 30, 2018 7:12 PM EST
    • Interesting design Fred. If my memory is correct, Bruce Chandler did a similar article here http://www.largescalecentral.com/forums/topic/17266/bucket-coaling-station.
    • December 30, 2018 6:39 PM EST
    • John;
         There was a bit of information with the pictures that didn't get included...
        The method of coaling, shown in the pictures  included a lot of manual labour, often involving maintenance of way workers, or any railroad labour handy at the time.  Labour was relatively inexpensive, even into the middle "50's"
        The box car in the photo, may have been used to bring the coal to the stage, after coal was manually shovelled into it from a coal pile, somewhere in the engine facilities. Its floor was at the correct height to match that of the coaling stage.
       The hand truck, in one of the pictures, being used by the "White suited" worker, was used to load the coaling buckets. Each bucket had a drop bottom.
           You must understand, that in Chipman, New Brunswick, at the time, there was seldom if ever, more than 2 4-4-0 locomotives in service. There were 3 of them that the CPR kept in service, just for the branch line, late into the 50's, due to the need of a very light locomotive, to cross a particular bridge. The locomotives were CPR numbers 136, 144, and 29. All were preserved at one time. 144 was possibly lost in a fire somewhere in Nova Scotia; 29, and 136 still exist...29 is in Ontario...I'm not sure where 136 is...
         There were a number of coaling stages such as this one.  There were at least 3 of them, not far from Ottawa, at one time, up until the end of steam in the very early 50's.
       Fred Mills
