Forum Sponsorsss
Forums General General Discussion
  • Topic: Aristocraft RS3 - How Many Amps?
    Back To Topics
    (0 rates)
    • November 20, 2020 10:43 AM EST
      • Bloomington, IL
      • Posts
        14
      • Thanks
        6
      • Thanked
        1
      Greetings!   I am working on a battery/protothrottle/DCC project going into an Aristo RS3, and I was curious how many amps it draws?  I figure load would be at most 20 cars and maybe up to 3% grade (if it will even do that).
      The root of the question is coming from decoder selection.  From other scales I am pretty invested in the ESU ecosystem, so it makes sense to get a LokSound L or XL for this project.  To that point I was wondering if I could save a little space and money by using the LokSound L (3A) or if I would need to use the XL (5A)?
      Thanks for any input!
    • November 21, 2020 8:50 AM EST
      • Fort Worth, Texas
      • Posts
        224
      • Thanks
        9
      • Thanked
        53
      I'm new to battery power, but everyone told me to get at least a 4amp decoder/receiver for my dual truck powered engines. In most cases on my layout I will be running just one engine at a time and doing switching moves with I think I could get by with a 2amp decoder, but I guess there could be a time when I would take my engine elsewhere and pull longer trains. I was told by Don at RCS of New England that I would just be better off in the long run with the 4amp decoder. I think for the way you will be running your engines that you best go with 4amp decoder and be safe and done with it.
      trainman
    • November 21, 2020 10:14 AM EST
      • Elverta, CA
      • Posts
        441
      • Thanks
        8
      • Thanked
        81
      Scott
      George Schreyer's Pulling Power Tractive effort test chart suggests a 5 Amp decoder would be suited for the RS3 pulling 15 cars consuming 2.3A. Georges test suggest the RS3 can hard stall at 4.2A. Note three test regimens were made, each with different configurations and results.
      http://www.girr.org/girr/tips/tips4/tractive_effort_tests.html
      Michael
    • November 21, 2020 10:46 AM EST
      • West Glocester, Rhode Island
      • Posts
        617
      • Thanks
        203
      • Thanked
        265
      Don knows best.  I use the 2 amp board in a Railtruck (powered by a single Hartland Mack power truck) and an Aristocraft 0-4-0 pulling 4 cars slowly around the xmas tree.
      Thingiverse Icon Instagram Icon
    • November 21, 2020 11:32 AM EST
      • Bloomington, IL
      • Posts
        14
      • Thanks
        6
      • Thanked
        1
      sd
      Great information, thank you guys!  I had forgotten about the girr.org pulling tests.  That's a good resource.
      Looks like I will be going with the XL, unless I decide to bail on ESU and get the TCS 501.  :)
      Thanks again!
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
