RRAmpmeter IV Question
Not sure if this is the correct location for this question.
I plan to buy the RRAmpmeter. I see they now offer a version 4. It says it handles DCC of 18-20A. Usually I see ranges of 1-20A or up to 20A. I am running 10A Brutus. Does anyone have the version 4? Will it read down below 10A?
My best recommendation is to check with Greg Elmassian here https://www.elmassian.com/
Perhaps you should recommend searching LSC first ?
I have searched here.
Then perhaps you should go with Bob Copes recommendation ?
bump
I pull 4 amps on my Crest Elite running what I run as the analog meter shows it.
However it works
Well, I got an answer from Tony’s Trains tech. Said it does go down to 0.1A. I figured but for $100 I wanted to be certain. Didn’t want to have to ship it back.
Glad you got an answer for your question.
Hi Derailed - You received your answer. I do have the RRamp V.4 and find it a great tool. Let me know if you have any questions after you start using it. Keep in mind that your DCC’s track power voltage drops about 1.5 volts on the outputs in your DCC decoder. This is a good data point to consider when you’re adjusting your DCC decoder’s outputs for things such as lighting, smokers, etc. Also, when measuring voltage outputs on your decoders, do so under “load”, i.e., have the device connected to the decoder’s output, e.g., light, motor, smoker, etc.
Thank you. I have to wait until next month as I bought a new Pustefix car for a price I couldn’t pass up. Need to replenish my Train Stipend. :wink:
“Keep in mind that your DCC’s track power voltage drops about 1.5 volts on the outputs in your DCC decoder.”
Is this due to a bridge rectifier inside the decoder? 1.5v is pretty close to the voltage drop across the 2x diodes in a BR. I assume the decoder has some form of BR for accessories such as lights and smoke.
One of these days I will take an electronics class at the local college.
Derailed - I’m not an electronics engineer so can’t answer your question. Someone like Greg Elmassian will need to chime in on that one.
I install a lot of Massoth XLS DCC/DC Sound Decoders. Massoth Technical Department informs me that the outputs on these decoders is not DC or DCC Voltage. Instead it’s pulse modulation with 25 volts (peak voltage) and smaller for lower voltage. So, they advised me to use an RMS Multimeter in AC mode with load to measure the voltage outs from their decoders. So I don’t use the RRamp to measure these decoder’s outputs; I use the RRamp to measure the DCC voltage from my Command Stations to the track…and amps.
I’d be curious if Greg or others know whether this approach is used by other DCC Decoder manufacturers, such as ESU, Soundtraxx, etc.
Tom
Its not a bridge rectifier, at least not for the motor output, its an H bridge. For lights and such it would be a rectifier circuit of some kind. Also, on the switchable outputs (lights, smoke), there is also a switching transistor in the circuit. So yes, your actual voltage output would be reduced by the forward bias voltages of these components.
