Forums Modeling Motive Power
  • Topic: Body mount Kadee Coupler for B'mann Climax
    Back To Topics
    (0 rates)
    • May 26, 2020 11:15 AM EDT
      • Ottawa/Nepean, Ontario, Canada
      • Posts
        4,784
      • Thanks
        242
      • Thanked
        359
      What is the number of the Kadee Coupler, for body mounting on the B'mann Climax …#1 scale coupler...
          Fred Mills
      This post was edited by Fred Mills. at May 26, 2020 11:17 AM EDT
    • May 26, 2020 12:53 PM EDT
      • Posts
        4,784
      • Thanks
        242
      • Thanked
        359
      Thank you, Mark....
        Fred Mills
    • May 26, 2020 1:14 PM EDT
      • Posts
        13,754
      • Thanks
        1,489
      • Thanked
        1,095
      That entire kit from Kadee looks like it is designed to prevent or reduce coupler droop in the pin pocket which is good. For my Shay, which uses a similar pocket, I simply modified a coupler to pit snugly in the pin pocket by adding some styrene on the shank then drilling for the pin. It droops a little, but not enough to cause issues.  I used a Bachmann drop coupler, but similar might be done with a normal Kaydee coupler...
      www.cvsry.com www.cvsry.com
    • May 26, 2020 1:42 PM EDT
      • Posts
        4,784
      • Thanks
        242
      • Thanked
        359
      Jon;
       I was looking for a more prototype coupler.  The offset shank is not very prototypical, although it can be said that there is a prototype for anything....!!…...I use the Kadee #1 scale couplers as the standard on the railroad, so I want as little "Slop" in the mount as possible.
          I studying the Kadee information, pointed out by Mark; I find that their #1782 coupler will be just fine. It isn't a "Shake the box" application, but should not be any problem.
        Thank you, Jon, for your contribution....and again, thank you Mark.
        Fred Mills
    • May 26, 2020 6:27 PM EDT
      • Posts
        13,754
      • Thanks
        1,489
      • Thanked
        1,095
      No problem Fred. I wasn't suggesting that you duplicate mine, only offering a way to "do it on the cheap" with couplers most people throw away. The Climax may have a lower pin box. With the Shay I need the drop coupler even when using the lowest pocket in the pin box.
      At least no one suggested you do it like this guy did and trying to sell on Facebook for $400!
    • May 27, 2020 6:29 AM EDT
      • Posts
        4,784
      • Thanks
        242
      • Thanked
        359
      ….Jon....I like "On the cheap", but I really dislike "Offset shank couplers"...!!
          On the Shay, the recommended method, which I have often used;  is to move the  "Pin box" down.  I did this, and added an extra strip of wood to the bottom of the end beam.
        Thanks again, John...it is good conversing with you...and sharing ideas.
            Fred Mills
      This post was edited by Fred Mills. at May 27, 2020 10:13 AM EDT
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
