Well after thinking on this and with Pete’s offer to part with that little motor block I might be back in business. I also got to thinking that I might be able to replace the drives on the current motor block and that would help.
My problem is two fold. First the gauge of the wheels falls in a terrible spot and the flanges fall basically at the body line. I started cutting and filing the framing to fit the motor and wheel and was successful only to find that the body also needs to be cut out. If you are a hot rodder think tubbing the tires. I need to tub this in order to get those big drivers in there. So not only is the model too narrow but also doesn’t have the wheel well depth it needs. Just not the right motor/driver combo for this model.
Now what I had originally planned when I got this little model was a much smaller drive wheel on like a flea drive. Pete’s is about perfect for what I originally was thinking. But now I am wondering if I can take off the drivers from my current motor and put on another set of wheels a set of spoked ones would be great.
The other issue is still the size of the motor itself. It does fit up inside the body now that I have opened it up. But still leave no room for anything else, hence the trailer idea. I am not at all against the trailer and no matter what might include it as a novelty but even with Petes little motor i won’t have room for electronics and batteries so I am thinking a trailer is a must.
