M.E.K. "subsititue"
Not sure if anyone cares about this but I will throw it out there in case. So I have misplaced or lost my container of M.E.K. I bought a quart of it like 10 years ago and now I have no idea what I did with it. So I went to replace it and my local ACE didn’t have M.E.K. they had some stuff that said M.E.K. substitute “works any where M.E.K. does”. . . Well it does not work as a plastic welder. So before you buy it to try it don’t, atleast not as a plastic solvent.
Devon Sinsley said:
Not sure if anyone cares about this but I will throw it out there in case. So I have misplaced or lost my container of M.E.K. I bought a quart of it like 10 years ago and now I have no idea what I did with it. So I went to replace it and my local ACE didn’t have M.E.K. they had some stuff that said M.E.K. substitute “works any where M.E.K. does”. . . Well it does not work as a plastic welder. So before you buy it to try it don’t, at least not as a plastic solvent.
Yep. Years ago (about 8) M.E.K. was removed from the shelves and replaced with the “safer” substitute stuff. Since then, M.E.K. has returned to the shelves in the big box stores when enough folks complained it didn’t work nearly as well. I believe the same thing happened with TSP.
-Dan
The glue that Plastruct sells is pretty good, also model power works well and Tamiya wicking glue works great for gluing thin cracks actually wicks into the crevice, Bill
Not sure about the other brands listed but the Plastruct stuff is M.E.K. or at least partially so, or it was 10 years ago. The only reason I switched to straight M.E.K. was I realized I was spending as much for a 1oz bottle of Plastruc as I could buy a quart of M.E.K. and get the same thing. I tried it after buying it and it worked just as good as the Plastruc stuff, maybe even better, and I figured I had a quart so it would be a life time supply. Until you loose the can.
The only real issue I have with straight M.E.K. is the container. So either save a plustruc bottle, or some similar, or some other smaller glass bottle with a lid and then get a paint brush and your off and running. That is until you break the lid on the plastuc bottle and spill the rest and then can’t find the big container.
If I were really smart I would just drill a hole in a piece of wood that I can stick my plastruc bottle in and keep me from spilling it. For every ounce I use on plastic I spill 60 oz. If I could keep from spilling it all the time I wouldn’t need so much and a bottle of plastruc would last a life time. As is I am lucky if the bottle last one project.
I use IPS Weld-On 3 Acrylic Plastic Cement as my Plastruct and MEK replacement. So far it has worked well for me for my indoor projects and I do most of the application with a brush.
Acetone will work almost as well as MEK. I have used acetone in a pinch. Chemically they are similar compounds. But real MEK is the good stuff.
I never tried substitute MEK. I did try the substitute TSP. What a waste of good money that was.
Devon,
I get my MEK at the local Ace hardware store. I keep it in 1 oz. needle tip plastic bottles (really, they don’t melt). We kept MEK in plastic bottles at work too [Northrop/Grumman].
Here is a link to similar bottles on Amazon…Needle tip bottles
Our big box stores (Lowes & Home Depot) both carry MEK in quart cans. If you can’t source it in your state I could grab you one and send it UPS to you (https://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-wink.gif)
Over on MRH, Joe F has come up with a healthy substitute for MEK. I will have to search for it and post here. I haven’t tried it yet, but will when the MEK runs out.
https://model-railroad-hobbyist.com/node/8083?page=6
I second the needle bottle.
While the use of MEK in our modeling is probably limited, it is a nasty organic solvent with adverse health effects both short and long term
https://www.epa.gov/sites/production/files/2016-09/documents/methyl-ethyl-ketone.pdf
Just so you take care when using it
Regards
Jerry
The needle bottles can be picked up at Hobby Lobby. I used MEK at work for years. it was a carrier for automotive window primer and we used it to clean up spills or drips. The primer we applied to the glass flange on the car body was brushed on out of a measuring cup that we held in front of us. Can’t tell ya how many times I about hit the floor from the fumes gassing off from the open cup…
I like using Ambroid Pro Weld Professional plastic welder when gluing plastic together. I have used it on a couple of scratch built freight cars and it does a good job.
Re-hashing an old thread. But the continuing saga of acquiring the real M.E.K seems to be getting worse. Now not only does my local ACE not carry the stuff but I couldn’t get it at Lowes or H.D. either. My local Fastenal can order it in gallons but I was told since it was not a fast mover I would have to buy all 6 gallons that is their minimum purchase. Now I love the stuff but I really don’t think I need 6 gallons of it. Although with as hard as it is getting to acquire I may do it and have a life time supply. Especially given that Craig has turned me onto buying 4X8 sheets of styrene.
But anyway I called my local Marine supply outfit in Spokane, West Marine, and they are still selling quarts of it.
I throw this out there in case others are having a hard time finding it. Its at least another place to look.
Devon,
Glad you found some. I bought out all three quarts the West Marine had locally!
Crossing my fingers once these three quarts are gone I can find more.
I am half tempted to place a 6-1 gallon order but I would have no need for 6 gallons of the stuff. Maybe if I do we can work out a deal
Do you have a Sherwin Williams close by? They have MEK too. Mine only had it in 5 gallons, but that’s one less gallon… :joy:
Sherwin Williams also advertises on line for single gallons. :sunglasses: YMMV
Now I must have a hole in my head. Not once did I even consider an actual paint store. Duh. Good call David
I personally prefer 4 but I’m glad folks listen to my useless posts
