Forums General Problem Solving
  • Topic: What's the best way to remove decals?
    Back To Topics
    (0 rates)
    • January 13, 2020 3:07 PM EST
      • Washington
      • Posts
        701
      • Thanks
        0
      • Thanked
        17
      I applied water slide decals to my loco a number of years ago and I would like to remove them and apply different decals.  What's the best way to remove decals?
      Thanks
    • January 13, 2020 4:18 PM EST
      • West Glocester, Rhode Island
      • Posts
        578
      • Thanks
        158
      • Thanked
        240
      That would depend on what you applied over the decals to seal them.  If you didn't do that, then Micro-set or 91% Isopropyl Alcohol should work quite easily.
      Thingiverse Icon Instagram Icon
    • January 13, 2020 4:43 PM EST
      • Pittsburgh, Pennsylvania
      • Posts
        11,130
      • Thanks
        127
      • Thanked
        919
      An overnight soak in water with a bit of dish-soap might work, depending on how well you sealed them. If you sealed them well, then you may have to lightly sand through the sealer to expose the decal, or remove the sealer with some solution.
      Shannon car Shops
      Home of the infamous leg lamp
      I.A.R.R.R. Member #12
      and King Butt Modeler
    • January 22, 2020 10:45 AM EST
      • Washington
      • Posts
        701
      • Thanks
        0
      • Thanked
        17
      Not sure how I would soak the engine overnight.  I've tried nail polish remover and also denatured alcohol. Nothing is removing the decals.  I did spray a clear coat over the decals after I applied them as I mentioned.  Perhaps I can spray paint over them?
    • January 22, 2020 11:07 AM EST
      • Vail, Az
      • Posts
        5,421
      • Thanks
        1,947
      • Thanked
        1,360
      Physical removal ... sand with a fine wet or dry sand paper on a sanding block so you can get a flat surface. Go slow with finer grits say 1200
      John
    • January 22, 2020 11:52 AM EST
      • Posts
        9,393
      • Thanks
        249
      • Thanked
        862
      I agree with John, if you paint over, the "bump" of the original decals will show through the paint.
    • January 22, 2020 1:32 PM EST
      • Southwestern, NH
      • Posts
        531
      • Thanks
        104
      • Thanked
        185
      The hint of an old number under the paint is very typical in the real world. many locos on the C&TSRR at one time had many layers of #s on their cab sides, same # yes, but evidence of repainting with slightly different position or size, you bet. it is up to you to decide what will look the best. maybe before sanding down, you might give it a fresh coat of paint in the area where the decal is.
    • January 22, 2020 2:37 PM EST
      • Posts
        9,393
      • Thanks
        249
      • Thanked
        862
      Just reinforces that there is a prototype for everything! Thanks Al!
    • January 22, 2020 3:39 PM EST
      • Posts
        11,130
      • Thanks
        127
      • Thanked
        919
      The WM F units I rode behind down in Elkins West Virginia had been in a whole nother livery at one time. The raised outline of that livery was clearly visible under the current layer of paint.
      Shannon car Shops
    • January 22, 2020 4:32 PM EST
      • Cleveland, , Mississippi
      • Posts
        401
      • Thanks
        0
      • Thanked
        23
      Polly S Easy Lift Off (ELO) works well to remove decals.
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
