And we're back . . I resolved to get this done as there isn't much to do besides paint. Add footboards, attach ducketts and battery boxes, and clean the windows.
The battery boxes needed a bit of trimming and the truss rods needed adjusting. (The blue painters tape is marked with the positions of the center of the frame, and where the rods fit.)
As the boxes are hanging down, I decided they needed proper support - i.e. a screw. (The pieces of rail is actually the frame reinforcement along the center.)
These coaches have a long "footboard" as there is no corridor inside. In an emergency, the passengers may be required to get out through the compartment doors. I had some basswood and a long strip of 1/32" x 3/32" brass so I made a little jig for bending so the 8 pieces would be close to the same size.
I also decided that the footboards needed some positive reinforcement, so the top was drilled #74 for some 1/2" pins that I have.
Here's the footboard support with a pin and glue, and a metal rod lying on top while the glue dries. The pin on the right needs replacing.
With everything the right way up, I tried the footboard strip.
Looks OK, so out with the glue (gorilla, clear,) and some clamps. While that was setting, I made some similar supports for the footboards on the trucks. Glue and a pin and clamps, again.
Unfortunately, as you can see, the supports are far too short. As soon as I picked it up, the boards fell off! So longer ones were fabricated (bottom left.)
That's better. It did occur to me that getting the wheels out might be tricky.
And here's the result after the glue dries. They don't seem to line up perfectly! Maybe I'll have to do something about it, or maybe not. Shouldn't bee too difficult to raise the center boards.
