NCE DCC and siding track control
I have the NCE DCC system to control locos through the rails (not wireless to the cabs - i.e. not G-wire).
NEED: I want to be able to alternate 2 trains on 2 sidings with trains operating in opposite sidings while operating in DCC.
Not sure if there is a DCC solution or if I can use something like the RRConcepts Trainmaster/Stationmaster solution. (http://rrconcepts.com/images/pdf/alternate2differentDirections.pdf) As far as I can tell, DCC will not work with the RRConcepts solution.
Would converting to complete wireless (G-wire) allow the NCE DCC to work with RRConcepts Trainmaster/Stationmaster solution?
Any help would be appreciated.
Thanks, Dan
Dan, if you have assigned a unique address to each engine, you should be able to operate each independently.
Yea, you lost me. One of the big advantages with DCC is being able to independently operate multiple locomotives on the same track(s)
google DCC automation… there’s lots of DCC compatible products…
