Does anyone know of a place to buy the little black plastic washers that are used to fasten LGB 2 axle trucks? They must be 3/8th inch diameter to fit into the truck frame…see the photo.
Looks like M3 or maybe M4. You could get an assortment https://www.amazon.com/Nylon-Plastic-Washer-Assortment-350pcs/dp/B06Y3XFQY4
Tom contact Joan at TrainLi and tell her you need parts # 4067-13 and see if she can get them for you
http://lgb.vanelten.nl/Database/explosietekeningen/4067-1.pdf
X
Ace Hardware
I would ask if user is restoring to original parts. Then the LGB part is needed. Otherwise anything that fits would be OK. Computer motherboard hardware comes to mind.
Like Greg said, Ace Hardware or I think I have picked up similar at Lowes.
There’s always McMaster-Carr (My “goto” place). Plastic, polycarbonate and UHMW (whatever that is :)). .375 OD by .170-.190 ID (depending on the material and other factors. .050 to .075 thick. 7 bucks + for 100.
Gary, Ultra High Molecular Weight, think of it as compressed plastic very heavy and slippery, used as a low friction surface on some equipment. I know thread drift!!!
Thanks Pete .
