Forums General Problem Solving
  • Topic: Usatrains nw2 motorblocks
    Back To Topics
    (0 rates)
    • March 13, 2019 8:31 PM EDT
      • Deer Park, Washington
      • Posts
        12,410
      • Thanks
        422
      • Thanked
        276
      What size brass tubing is used for the collar?  I've forgotten.
    • March 13, 2019 9:12 PM EDT
      • San Mateo, California
      • Posts
        217
      • Thanks
        42
      • Thanked
        68
      K & S Brass Tube #9828
      Steve,
      Scroll back and you can see illustration that shows:
      K & S #9828 (10mm dia. x 0.45mm wall thickness) Brass Tube
      -Ted
      This post was edited by Ted Doskaris at March 13, 2019 10:48 PM EDT
    • March 13, 2019 9:57 PM EDT
      • Santa Ana, CA
      • Posts
        1,560
      • Thanks
        1
      • Thanked
        110
      IIRC, I just bought a 3 foot length of 3/8" OD from the big box hardware store and it is like the bunny, it just keeps going and going and going...
    • March 13, 2019 10:47 PM EDT
      • Posts
        12,410
      • Thanks
        422
      • Thanked
        276
      Thanks, Ted.
      • Posts
        12,410
      • Thanks
        422
      • Thanked
        276
      Thanks, Ted.
    • March 13, 2019 11:36 PM EDT
      • Posts
        217
      • Thanks
        42
      • Thanked
        68
      Tubing vs Pipe Diameter
      Caution!
      When deciding to use what size tubing to make repair collars for the USA Trains split plastic gear axles, keep in mind that tubing is measured by outside diameter, whereas pipe is measured by inside diameter, therefore, it's critical to know the inside diameter of the tubing when using it to make the collars to slip over the USA Trains split plastic gear axles.
      Expecting 3/8 diameter tubing to work in this regard, as with any tubing, is consequently dependant on its wall thickness.
      For the K & S #9828, its inside diameter (expressed in English units of inches) is 0.018 inches for wall thickness, thus, x2 = 0.036 inch (doubled to account for the circular surround) and then subtracted from the K&S tube outside diameter of 0.394 inch yields  0.357 inch.  That is the target value applicable for the repair collars to fit over the plastic gear axles for the USA Trains F3, GPs and NW2 - there may be others.
      -Ted
      This post was edited by Ted Doskaris at March 13, 2019 11:38 PM EDT
    • March 14, 2019 1:55 AM EDT
      • Santa Ana, CA
      • Posts
        1,560
      • Thanks
        1
      • Thanked
        110
      The walls on my tubing appear thinner than in the photos.  As I said, I flare the end a bit and these push right on in the vice.
    • March 14, 2019 8:05 AM EDT
      • Posts
        9
      • Thanks
        0
      • Thanked
        0
      Ted Doskaris said:
      Caution!
      -Ted
    • March 14, 2019 8:09 AM EDT
      • Posts
        9
      • Thanks
        0
      • Thanked
        0
      So, Ted and all involved here, I am looking to invest in a press, Eric’s die , and tubing to fix my many axles on the many old USA ENGINES I own and run . You mentioned in detail K & S #9828 tubing , I had captured another size somewhere in these threads so is #9828 exactly what I need to press on my axles ?
      thanks
    • March 14, 2019 1:09 PM EDT
      • Posts
        217
      • Thanks
        42
      • Thanked
        68
      K&S #9828 Tubing Split Axle Applications
      thanks
      Yes, K&S #9828 tubing is what I used on the USA Trains F3 / GPs and NW2 2 axle locos.  I have yet to do an SD40-2 or SD70 3 axle loco, so I can't say if the K&S #9828 tubing is good for those at this time.
      I have Eric's die, and it makes it so easy to get the wheels in gauge whilst assuring the gear is center as needed for the 2 axle locos. It's used with a device to press the wheels on, which could be a dedicated press, drill press or vise. Prior to getting Eric's die, I had improvised a method to press the wheels on so the gear would be centered.
      My thanks to Eric for such a great product.
      -Ted
    • March 14, 2019 3:58 PM EDT
      • Carlsbad, CA
      • Posts
        8,122
      • Thanks
        133
      • Thanked
        621
      It's good for all USAT diesels, although there are slight variations.
      again, here is a link: https://elmassian.com/index.php/large-scale-train-main-page/motive-power-mods-aamp-tips/usat-motive-power/split-axles
      I recommend getting Eric's spacer blocks.
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
