  • Topic: Crest 10 amp supply to train engineer hook-up
    Back To Topics
    (0 rates)
    • July 31, 2019 1:09 PM EDT
      • Milwaukee, Wi
      • Posts
        167
      • Thanks
        85
      • Thanked
        40
      I’ve gone through a fair share of them already. This new roadbed has fixed a lot of issues already.
    • July 31, 2019 6:55 PM EDT
      • Milwaukee, Wi
      • Posts
        167
      • Thanks
        85
      • Thanked
        40
      I think I will go with the meter box or circuit box route for the receiver. I just need something that will keep the receiver dry and makes it so I don’t have to keep taking it up/down the stairs whenever I want to run. If I can make the Ultima fit, even better.
      Sean McGillicuddy said:
      On my two units I use this wire from the TE unit to the track..
      Image result for garden lighting wiresome put an inline fuse as well .My units are in an old metal meter cabinet ..Image result for meter cabinet
    • August 1, 2019 12:38 AM EDT
      • Be Nice or STFU
      • Posts
        9,371
      • Thanks
        248
      • Thanked
        858
      another idea is the sealed boxes for camera equipment, I found one on sale for an obsolete gopro camera and it works fine.
      something like this: https://www.amazon.com/Monoprice-Weatherproof-Shockproof-Hard-Case/dp/B00JVA7UGM/ref=pd_sbs_421_7?_encoding=UTF8&pd_rd_i=B00JVA7UGM&pd_rd_r=373a09b2-700b-4757-9ee1-1161dc401a49&pd_rd_w=gJkI3&pd_rd_wg=WGLpz&pf_rd_p=43281256-7633-49c8-b909-7ffd7d8cb21e&pf_rd_r=FS5BA56T6P1MDMCE7Z3V&psc=1&refRID=FS5BA56T6P1MDMCE7Z3V
    • August 1, 2019 6:52 AM EDT
      • Eastern Massachusetts
      • Posts
        1,165
      • Thanks
        7
      • Thanked
        100
      Walmart has good fuse prices, better than auto supply shops and from amazon prime I got fuses in 10 packs for really low $$$$
      25 of the 10 amp fuses for $5.90 on Amazon Prime plus free delivery!!
    • August 1, 2019 7:56 PM EDT
      • Santa Ana, CA
      • Posts
        1,676
      • Thanks
        2
      • Thanked
        137
      Bill Sakalaucks said:
      The Ace store near me has them on hand. I don’t mind replacing them as it‘s a relatively easy part to get to.
      Hint :  make sure you get a good supply of these Image result for 10amp blade fuse
      Or, get one of these and the first time you pop the fuse, scrape away some of the plastic and solder this to it (in 10 amps of course).  That's what I did for my three TEs.  Real quick and easy to reset, never "looking" for one, and cheap too.  You may even be able to find one with the same pin spacing/size as the fuses.
      This post was edited by Todd Brody at August 1, 2019 8:00 PM EDT
    • August 2, 2019 6:32 AM EDT
      • Posts
        1,165
      • Thanks
        7
      • Thanked
        100
      A circuit breaker is not a fuse.  There is a time factor in how long it takes the fuse to blow vs the circuit breaker to open.
      I do not know if this makes a big difference but it may if something is in warranty which the TE no longer would have.
    • August 2, 2019 1:57 PM EDT
      • Santa Ana, CA
      • Posts
        1,676
      • Thanks
        2
      • Thanked
        137
      I've only used them for 15+ years and they've always functioned as designed.  Sure, I've had derailments and burned out the small traces on circuit boards in engines, but it doesn't take anywhere near 10 amps to do that and it happened as much with fuses as it did breakers.  If one were concerned, about any differences, one could always get a bit smaller breaker, if you can find it.
      When I burn a trace, I put polyfuses in the engine when repairing it to avoid this happening again.  It is easy to tell when a polyfuse opens and doesn't require a short to open it..., dirty track can do it and my U-boat track cleaner with added polyfuses does this quite often.
      If one never used more than two engines and some lighting at a time, a 5 amp breaker (or fuse) may be the better choice and may save some of those traces.
      This post was edited by Todd Brody at August 2, 2019 2:06 PM EDT
    • August 2, 2019 2:17 PM EDT
      • Milwaukee, Wi
      • Posts
        167
      • Thanks
        85
      • Thanked
        40
      I went and got a 60a hot tub box to store the receiver in. Gutted the electrical components and the dang thing fits fine.
    • August 2, 2019 2:22 PM EDT
      • Rio Linda, Cal.
      • Posts
        1,688
      • Thanks
        3
      • Thanked
        114
      Don't know what others use but,  we have use these for over 10 years or so on all of our TM's.  We use the 5 and 8 Amp reset able Breaker by soldering a small formed Copper wire to spades off of old used 10 amp fuse.   That way they just plug in to the Fuse slot.
      There on E-Bay
      https://www.ebay.com/itm/Car-Manual-Reset-125-250V-AC-3A-50A-Push-Button-Switch-Thermal-Circuit-Breaker/163559130470?hash=item2614e24566:m:m_IDDKvmm9mFB8Etl0sJvpw
      Least it will save your receivers and and we found out that they work almost just as fast as a Fuse for us.
      Just an idea.
      This post was edited by Noel Wilson at August 2, 2019 2:33 PM EDT
      Little Rio feather says...One leave train running here and takes a coffee break, may find Koi fishes checking out how deep an Engine can swim when the Swing Bridge is left open. It happen to Big Feather Tweedledum.... Burnt finger Nbr. SA#49
                 Our Video's
    • August 2, 2019 3:51 PM EDT
      • Be Nice or STFU
      • Posts
        9,371
      • Thanks
        248
      • Thanked
        858
      You can look up the specs on the circuit breaker and that for a fuse.
      In the case of a fuse, it is heat that melts the "link" and how quick it blows is dependent on the current.
      A breaker often trips once over a threshold.
      Properly rated, it's my experience that a circuit breaker trips sooner and more repeatably than a fuse.
      (of course a completely solid state breaker circuit is even better, like I have in my DCC system. There are also smart, microprocessor driven circuit breakers for trains like the DCC specialities stuff)
    • August 2, 2019 4:19 PM EDT
      • Pittsburgh, Pennsylvania
      • Posts
        11,026
      • Thanks
        123
      • Thanked
        883
      My TE has the fuse it came with from the factory. My MRC power supply has an automatic cutoff somewhere around 5 amps. The only time it trips is when I have a derailment, or it the track and ballast are very wet (leakage current through the wet ballast). I run 2 trains at a time, with sound (if they have sound) and smoke (if they have smoke). I don't usually see more then 3 or 3.5 amps on the ammeter with 2 trains.
      Shannon car Shops
      Home of the infamous leg lamp
      I.A.R.R.R. Member #12
      and King Butt Modeler
    • August 3, 2019 2:14 AM EDT
      • Tingewick, Buckinghamshire
      • Posts
        243
      • Thanks
        36
      • Thanked
        33
      I only see mention here of the 10 amp fuse mounted in the TE RX unit itself. I have always assumed that was only to protect the TE RX from a power supply overload (If you have the Crest 55465 20 amp unit that might be a consideration).
      Supplied NIB with my Crest TE RX was also a separate cartridge type 10 amp fuse, that was mounted in a clear spring loaded holder, in-line from the RX's output to the track. I have always assumed this was to protect the TE RX from any overloads emanating from the track. Never blown the red 10 amp fuse on the RX itself but I've blown a couple of the ones protecting it from the trackside with derailments and a 45mm long nail that found its way onto the line from a neighbour's fencing job.
      Just thought I'd mention it if anybody had thought of deleting this feature or bought 2nd hand where a previous owner had not kept it in place.
    • August 3, 2019 7:09 AM EDT
      • Posts
        1,165
      • Thanks
        7
      • Thanked
        100
      The inline fuses come in different versions, slow blow (not good for trains), fast blow.  Fast blow have a spring to make them open faster.
    • August 3, 2019 12:34 PM EDT
      • Be Nice or STFU
      • Posts
        9,371
      • Thanks
        248
      • Thanked
        858
      Actually, the spring normally indicates a slow blow fuse, the spring has some resistance, but adds to the thermal mass of the fuse itself, thus handling surges without blowing, but when finally heated "enough" pulls it apart.
      Having a spring usually guarantees a slow blow, but not all slow blow fuses have a spring. You cannot go by the width of the link since it has to vary according to the amps.
      The best thing is to look on the ends of the fuse itself to see the markings and look it up.
    • August 3, 2019 8:28 PM EDT
      • Posts
        14,460
      • Thanks
        2,439
      • Thanked
        1,457
      Good Lord ......with all this advice does anyone have any videos or possibly a vignette of THEIR TRAINS RUNNING which in turn "Blew the FUSE"
    • August 3, 2019 8:36 PM EDT
      • Posts
        14,460
      • Thanks
        2,439
      • Thanked
        1,457
      Steve,
       Rod Stewart models HO
    • August 4, 2019 3:03 AM EDT
      • Rio Linda, Cal.
      • Posts
        1,688
      • Thanks
        3
      • Thanked
        114
      Yup..Son ...We have.  laf.  See time line 1:51.  Michael Glavin was running his Train Batt. powered and I had track power to one of my Trains. He ran over a snail and he shorted out my trains by shorting out our TlM's Rec. fuse.  Ever try to replace or just find the fuse slots in the dark?
      "Added to next post."
      P.S.  Thanks Joe Z.
      This post was edited by Noel Wilson at August 9, 2019 3:11 PM EDT
                 Our Video's
    • August 7, 2019 8:37 PM EDT
      • Saint Johns, Florida
      • Posts
        4,497
      • Thanks
        482
      • Thanked
        697
      Nice Video.
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
