Forums Power and Sound Electronics
  • Topic: Mounting SMD LEDs
    Back To Topics
    (0 rates)
    • February 7, 2019 8:58 PM EST
      • Becker, Minnesota
      • Posts
        91
      • Thanks
        15
      • Thanked
        18
      Mounting SMD LEDs
      Curious what others use to mount SMD LEDs? I've tried CA glue, works ok but takes awhile for the LED to take and the glue to dry. Suppose to be 10 second CA but that never works out. I'm using the SMD LEDs for headlights, ditch lights, step/truck lights and so on.
      - Eric
      Greater Minnesota Railroad (GMRR)
      "An Adventure in Garden Railroading"
    • February 7, 2019 9:34 PM EST
      • Sherwood Park, Alberta
      • Posts
        400
      • Thanks
        56
      • Thanked
        261
      Eric,
      I've been using epoxy. I tape the wires to hold it in the location I want, and then carefully epoxy around the edge of the LED. I've only used these for my step lights. I've been using 5mm LED's for my headlight and ditch lights.
      Shane
    • February 7, 2019 9:42 PM EST
      • Becker, Minnesota
      • Posts
        91
      • Thanks
        15
      • Thanked
        18
      Shane-
      5 minute epoxy?
      - Eric
    • February 8, 2019 6:29 AM EST
      • KENILWORTH, WARWICKSHIRE UK. (Just up the road from Stratford-Upon-Avon)
      • Posts
        753
      • Thanks
        28
      • Thanked
        59
      I always advise my customers to use just a spot of  silicon adhesive  (the non vinegary smell type if there are PCBs around)...)
      Rubber solution works ok as well.
      Easy to remove when required.
      Cyano or Epoxy is rather permanent! or you damage something trying to remove it.
      This post was edited by Ross Mansell at February 8, 2019 3:12 PM EST
    • February 8, 2019 1:03 PM EST
      • Becker, Minnesota
      • Posts
        91
      • Thanks
        15
      • Thanked
        18
      Thanks guys for the tips!
      - Eric
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
