Forum Sponsorsss
Forums General Track and Trestles
  • Topic: New life for an old bridge
    Back To Topics
    (0 rates)
    • January 10, 2019 10:17 PM EST
      • Southern Oregon
      • Posts
        1,540
      • Thanks
        38
      • Thanked
        366
      This bridge pan came from my old railroad and with a little modification I can adapt it to a location on the new line.  This is basically a sheet metal pan made to look a little like a girder bridge that I used at a "duck under" location so it had to be sturdy as everyone used it as a hand hold while ducking under.  It is also extra wide because the track was on a radius where it crossed this span.  It was/is about 48-52 inches long with both ends cut at a bias.
      First I cut the bottom out so I could narrow the bridge to 7 inches, leaving about 2 inches of bottom on each half to fasten to.  This work isn't quite so easy now that I can't just run down to the sheet metal shop and use all the power tools
      I had to cut some off both ends to keep the existing lettering centered and get it down to the finish length of 37 inches.
      I used siding boards primed and painted on both sides and sandwiched the bridge bottom pieces between them and bolted them together.  I am not to concerned with moisture as this bridge will be under the shed roof covering the yards.
      All finished up and ready to test fit. Of course I still have to install the hinging and centering pins after I get all the fine points of installation worked out.
      Test fitting to it's new location, it will hinge on the left.  A bit tricky trying to keep the walk through as wide as possible and still get the bridge to clear the roof framing when it is raised.  This view really shows the grade, it looks a lot worse than it is.
      Once I get it finished up I will post a final picture.
      Rick
    • January 11, 2019 7:03 AM EST
      • Posts
        13,068
      • Thanks
        857
      • Thanked
        598
      Looking good Rick. Always satisfying when you can re-use something you already have.
      www.cvsry.com www.cvsry.com
    • January 11, 2019 7:22 AM EST
      • Southern Illinois
      • Posts
        8,863
      • Thanks
        259
      • Thanked
        303
      Nice work!  Looks like a great place to while away an afternoon.
      • Southern Illinois
      • Posts
        8,863
      • Thanks
        259
      • Thanked
        303
    • January 11, 2019 7:47 AM EST
      • Marysville, Kansas
      • Posts
        753
      • Thanks
        569
      • Thanked
        205
      Nice Rick!
    • January 11, 2019 8:32 AM EST
      • West Grove, Pennsylvania
      • Posts
        10,568
      • Thanks
        386
      • Thanked
        568
      If you ever get that bus heading west, a stop in southern Oregon is a must. He has a neat railroad. And getting better all the time............
      "Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." --Martin Luther King Jr
    • January 11, 2019 10:24 AM EST
      • Nashville, IL
      • Posts
        5,075
      • Thanks
        296
      • Thanked
        305
      Tis a great re-work of a bridge..   Nice work...
    • January 14, 2019 11:29 PM EST
      • Southern Oregon
      • Posts
        1,540
      • Thanks
        38
      • Thanked
        366
      Hey, thanks for the nice words Ken!  When are you coming back out?  All the switches are now functioning, well until someone comes to operate that is
    • January 15, 2019 3:29 AM EST
      • Posts
        10,568
      • Thanks
        386
      • Thanked
        568
      Your welcome, Ric. I think it's your turn to come East, (April would be nice, hint hint)
      Mine work great, too, until a crowd shows up...............
    • January 15, 2019 6:05 PM EST
      • Deer Park, Washington
      • Posts
        12,411
      • Thanks
        423
      • Thanked
        276
      Ain't that the truth!  Thirty minutes before the guests arrive, everything works fine, two minutes after they arrive, the place looks and works like no maintenance has ever been done.
    • January 15, 2019 7:59 PM EST
      • Defending the State of Exile! ,
      • Posts
        13,151
      • Thanks
        1,436
      • Thanked
        958
      Out of respect I edited most of a video I had of Ric Golding at Kens that day. If Rick Marty is coming in this year perhaps I can get a video of him as well.
      This post was edited by " Rooster " at January 15, 2019 8:03 PM EST
    • January 15, 2019 8:04 PM EST
      • Posts
        13,151
      • Thanks
        1,436
      • Thanked
        958
    • January 15, 2019 9:59 PM EST
      • Southern Oregon
      • Posts
        1,540
      • Thanks
        38
      • Thanked
        366
      That's a great idea Ken!!! When are you going to start the "GO Fund Me" page
    • January 16, 2019 3:49 AM EST
      • Posts
        10,568
      • Thanks
        386
      • Thanked
        568
      I will get on that as soon as I can..............
    • January 16, 2019 8:24 PM EST
      • Missouri
      • Posts
        2,463
      • Thanks
        214
      • Thanked
        251
      Indeed.
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
