Forum Sponsorsss
Forums Modeling Rolling stock
  • Topic: Aristo Heavyweight Diner Lighting ?
    Back To Topics
    (0 rates)
    • January 10, 2019 8:12 PM EST
      • Defending the State of Exile! ,
      • Posts
        13,535
      • Thanks
        1,670
      • Thanked
        1,078
      Greg Elmassian said:
      Sorry Pete, understand now.... you could have used that rectifiers that are used by the the table leds for the main led lighting should you have wanted to use track power.
      Greg said: "Rectifiers"
    • January 11, 2019 2:48 PM EST
      • Fort Myers Beach & Annapolis, Florida & Maryland
      • Posts
        2,003
      • Thanks
        47
      • Thanked
        241
      " Rooster " said:
      Pete Thornton said:
      As this thread is labelled "Diner Lighting" I will continue to add to it until I am finished with lighting.
      Yes ...but YOU did ask how to remove the roof ?
      Yep - first step in dealing with the lighting, right?
        Pete
    • January 14, 2019 2:08 PM EST
      • Posts
        2,003
      • Thanks
        47
      • Thanked
        241
      Final installment.  I test fit the battery before replacing the trucks, and it is a perfect fit between the ribs.
      I'll probably put a strap over the battery using the 2 screws into the pcb inside, as you can see.  Later.
      Footnote:
      While packing the coach back in its box, I picked up the Instruction Manual.  (Out dropped an order form for the 1991 Color Catalog.)  Two things in the manual were of interest.
       - the roof removal process was detailed (as always, read the manual first!) so you can fix the lights;
       - the interior lighting instructions indicate the table lamps are screw-base incandescents, not LEDs.
      Hmmm . .  another mystery to solve when I decide to fix the lighting.
        Pete
    • January 14, 2019 4:40 PM EST
      • Shut Up Rooster
      • Posts
        8,506
      • Thanks
        162
      • Thanked
        692
      Will be interested, I was always informed the table lamps were LEDs, but have never pulled them apart to check.
      Let us know when you do investigate.
    • January 18, 2019 7:48 PM EST
      • Posts
        13,535
      • Thanks
        1,670
      • Thanked
        1,078
      Just glue a piece of styrene across the ribs to hold the battery and call it done
    • January 18, 2019 8:09 PM EST
      • Shut Up Rooster
      • Posts
        8,506
      • Thanks
        162
      • Thanked
        692
      It's not rechargeable, needs replacement on occasion.
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
