Smart!
I had thought about screwing both frames together, laying one side out and machining both at the same time. But a little solder and then everything is nice and flat.
And using the drive rods to locate the axle centers, sure beats using a micrometer!
I see from the construction of your front frame that you, like I, must be running battery power. I was toying with the idea of insulating the left from the right side so I could also run this on someone else’s powered track without shorting everything out(https://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-surprised.gif)
But you know what, I have yet to run my trains on someone else’s layout. And if I decide to, I’ll just take something else.
This project is something I’ve been kicking around for a while, now I’m getting amped up about it.
Thanks for the good advice Pete, very helpful.
Adam
