Forums Modeling Motive Power
  • Topic: LGB Forney Cab Removal
    Back To Topics
    (0 rates)
    • October 6, 2018 6:00 PM EDT
      • Reedley, CA
      • Posts
        372
      • Thanks
        2
      • Thanked
        31
      Looking for some words of wisdom and experience with removing the cab of an LGB Forney.  I've removed the screws underneath and the rear lifts a bit, but it seems still attached to the boiler.  Playing it very gently as I do not wish to break or snap anything...
      Richard
    • October 7, 2018 8:35 PM EDT
      • Hilton, New York
      • Posts
        8
      • Thanks
        14
      • Thanked
        0
      Digging up an LGB parts manual for you engine on the web will be helpful, if you have not done so.  They are pretty good at helping reverse engineer it.     I recall screws under bunker, then cab screws as well as screws for boiler backhead are also underneath. Ashpan. Tender bunker should “jiggle” out.   Smokebox and attached handrails will partially “slide“ out of boiler tube once two tiny screws on either side of smokebox are removed.  Only go as far as to disengage the handrails from the cab, which should free cab (theres a small nipple on top of boiler that “locks” the cab to it) and allow disconnecting of smoke unit and headlight etc should further disassembly be required. (hence why you cannot remove smokebox completely in previous steps) This sequence may not be spot on but best that I can remember off hand.  I hope this helps.
      Good luck,
      glenn
    • October 7, 2018 9:20 PM EDT
      • Reedley, CA
      • Posts
        372
      • Thanks
        2
      • Thanked
        31
      Thanks Glenn...I did manage to find and print the parts manual.  I've gotten everything quite loosened up but am at the point where I'm not sure how to remove the cab from the boiler...it seems like one piece, however I know it is not. There seems to be a tiny screw in the cab just under where the boiler meets the cab...not sure how I'm supposed to get in there...
      Richard
    • October 7, 2018 9:41 PM EDT
      • Reedley, CA
      • Posts
        372
      • Thanks
        2
      • Thanked
        31
      Whew!!.. Got the boiler and cab removed from the chassis...now I can take a look at the electronics in the hopes of wiring this dude with RC/Battery...and taking the screening logos of so I can put Stan's "Santa Fe and Disneyland" logos in their place.
      Richard
    • October 8, 2018 11:49 AM EDT
      • Carlsbad, CA
      • Posts
        7,958
      • Thanks
        124
      • Thanked
        593
      Could you share what the magic trick is?
      This post was edited by Greg Elmassian at October 8, 2018 1:30 PM EDT
    • October 8, 2018 4:13 PM EDT
      • Reedley, CA
      • Posts
        372
      • Thanks
        2
      • Thanked
        31
      Greg...I started with Glenn's suggestions below.
      Good luck,
      glenn
      That was the easy part though...you have to gently raise the cab over the little character glued there...I did it ever so gently but once it was clear the boiler and cab together slipped right off.  I then unplugged all of the wiring from the pc board behind the weight.  Although I haven't done it yet there is a single screw in the roof of the cab at the point where the boiler meets...I believe you unscrew that the boiler and cab will be separated.
      Hope this helps.
      Richard
    • October 8, 2018 9:43 PM EDT
      • Carlsbad, CA
      • Posts
        7,958
      • Thanks
        124
      • Thanked
        593
      Thanks, I had a page on my web site:
      https://elmassian.com/index.php/large-scale-train-main-page/motive-power-mods-aamp-tips/lgb-motive-power/forney
      Perhaps while it is fresh in your mind, you could review my disassembly instructions and help me fine tune it or correct it.
      Thanks, Greg
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
