Forums General Gardening
  • Topic: Stream crossing path
    Back To Topics
    (0 rates)
    • August 30, 2018 6:33 PM EDT
      • Roseburg, OR
      • Posts
        18
      • Thanks
        9
      • Thanked
        9
      I am planning a water feature, and the stream needs to cross two paths. Any ideas for how to make this attractive?
    • August 30, 2018 9:03 PM EDT
      • Sylvester, Ga
      • Posts
        470
      • Thanks
        8
      • Thanked
        23
      Do  you want the water to flow over the path (slip and fall hazard) or go under the path?
      When we had a pond at our previous house we acquired a large roughly flat stone to place over the water running underneath.  We used stone as that matched our pathway
    • August 30, 2018 10:30 PM EDT
      • Vail, Az
      • Posts
        4,693
      • Thanks
        968
      • Thanked
        805
      How much grade separation?
      Big or little stream?
      Got a pic of the area?
      John
    • August 30, 2018 11:41 PM EDT
      • Torrance , CA
      • Posts
        22
      • Thanks
        0
      • Thanked
        1
      Do you have any plans drawn I suggest getting a priliminary drawing of what you want to do how big or deep you want to do it and what do you mean cross 2 paths how wide are those paths?  Do you have a height elevation and or surveyed of the property to establish a stable elevation?  It’s usuall a 2 to 3percentage grade and also depends if the lenght and with I am currently working at a Civil enginerring company and they alway recommen a 2% grade slope. You need to find the elevaction finish de multiply by the distance and that’s how you find the slope persantmage I will find out more information tomorrow bare with me.
    • August 31, 2018 12:50 AM EDT
      • Roseburg, OR
      • Posts
        18
      • Thanks
        9
      • Thanked
        9
      I'm looking for ideas for the crossing being non-slip and safe. Right now, the plan is somewhat flexible. My thought is a PVC pipe tunnel under the pavers/flagstones that make up the path. My wife and I have thought about having the water flow between flat and thick stepping stones making up the path, but that makes the path difficult for older people with walking disabilities.
    • August 31, 2018 2:10 PM EDT
      • Roseburg, OR
      • Posts
        18
      • Thanks
        9
      • Thanked
        9
      The stream will be small - no more than a foot wide. Since nothing has been built, the rest can be determined by what works. For instance, if a good solution requires the path to be 12" above the stream, that's how it will be done.
    • August 31, 2018 4:14 PM EDT
      • Vail, Az
      • Posts
        4,693
      • Thanks
        968
      • Thanked
        805
      I'd suggest appeasing the wife with cute arches...
      Adjust to suit your needs.
      John
    • August 31, 2018 5:46 PM EDT
      • Burke, Virginia
      • Posts
        7,177
      • Thanks
        177
      • Thanked
        630
      I can HIGHLY recommend this idea...
      Bruce
      http://jbrr.com/
    • August 31, 2018 6:05 PM EDT
      • Missouri
      • Posts
        2,518
      • Thanks
        229
      • Thanked
        267
      Okay, but adjust which one, the arch or the wife?
    • August 31, 2018 6:48 PM EDT
      • Burke, Virginia
      • Posts
        7,177
      • Thanks
        177
      • Thanked
        630
      Good luck with THAT idea...
      Bruce
      http://jbrr.com/
    • August 31, 2018 8:08 PM EDT
      • Defending the State of Exile! ,
      • Posts
        13,341
      • Thanks
        1,524
      • Thanked
        1,011
      Honestly without a picture of the area it's very hard for me personally to determine a "suggestion" if any ?
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
