Finally have trolley contact wire in place
Yesterday and day before I got shelf down, worked on, and replaced without causing back trouble! Well, at least not immediate trouble in addition to that which was already occurring for a day or two. Perhaps it was borderline dumb to try it while having a broken foot and misbehaving back as it does at intervals - but I did get to drill holes and saw things apart, which I seem to like to do when frustrated with life, the universe, and everything.
The Process:
Took the 8ft shelf down. Glued and screwed blocks in; blocks are scrap bits from local lumber yard over by a pretty decent local diner. Trolley wire anchors are from 1/4 diameter by 3ft long brass rod from Orscheln Farm & Home and springs I’d gotten a while back from Browning Hardware, the owners of which have since retired and closed the store.
White tube over brass rod is to fix height of contact wire anchors. Intent is to use brass tube but it turned out I didn’t have the right size so the ages old plastic tube got drafted for the interim.
Rod was cut in half, has 3 inches planted in block under shelf
Wire does not follow centerline of track - is skewed so as to move across pantograph and not wear groove in contact shoe, as per the prototype.
If it were a pole contact like old trolleys had the wire would follow centerline.
Next thing to do is build catenary suspension wires.
That might be later in the year.
Drew the catenary template several years ago with intent to build catenary in sections, solder contact wire joins, then anchor wire ends. We shall see what eventually develops.
There is also a pole angle and wire height template made from lacquered matboard.
Eventually the contact wire will be live and trains can pull power in through pantographs.
Might even do one like I did with a couple HO and On30 and alter it to forever be usable only on live overhead and both rails return type wiring. Intent for that is to make a reverse loop to reverse loop display module for club open houses.
Track on shelf is temporary. Is from Bachmann ‘Big Hauler’ G scale train set and will eventually be replaced with aluminum rail bought secondhand on basswood ties.
Have the ties cut and stained, somewhere: have to get motivated to find them at some point. Rail lengths have been kept on this shelf.
Need to acquire rail joiners.
Wire anchor pole looks centered in track because track is not centered on roadbed and is shifted to viewers’ left
Gee, you’d think he’d never before seen someone plane tapers on dowels.
Georgie cat has gotten a bit bigger since I started this slow as continental drift project.
Pretty neat. Cute little kitten, too! A little minnie version of our big old red Maine Coon cat.
very cool to see real over head power on a track, even just a short one!
Thanks guys! And found the ties.
Some basswood, some balsa. Now remember the plan being to use basswood for every third tie or so with rail functionally anchored to it. Mix of woods was because they were what was on hand during a period of limited income and it being a 60 mile round trip or mail order to acquire such sticks.
Had forgotten about the blank dice for tie spacing. Alternate idea was to use two ties as spacer between ties for more of that ‘light railway’ look.
Tie stain is probably still in a jar under kitchen cabinet somewhere since I don’t remember disposing of it. Was/is a probably Superfund Site mix of isopropyl/rubbing alcohol, acrylic model paint, ink,shoe polish, and who now knows what else.
–> Need more of those rail joiners since that is the one on hand.
It would look better with tie plates, but, dang, two, four, six, eight, twelve, two hundred and forty …
And as an added bonus at no extra charge, except maybe for a minor fragment of bandwidth, some of the traction modeling books on hand. A couple were acquired way back in the 1980s. The Walthers one is a reprint of a 1950s or earlier book. And somewhere buried in a stack of books is a 1947 copy of Model Railroader Cyclopedia which has a nice section on traction modeling of the period.
Traction is my first love but I’ve done more steam and diesel modeling so as to fit in with groups and clubs.
Such is life.
That is looking good and I am following with interest. I dug out that very same traction book from the basement two days ago for ideas. I have 13’ of shelf waiting for trackwork.
Mike
Thanks! Remember that this project has multiple year breaks in between bits of progress.
I’ll be following this as well, as I have an Aristo PCC car that I want to run on overhead wire.
Kind of the way I work too!
Mike
Really like the devotion to ideas like this. Remember its the journey, not the conclusion. Looks like great ideas.
