  • Topic: Eric's Dizzy Loco Mik 2018 style
    Back To Topics
    (0 rates)
    • January 29, 2018 11:00 AM EST
      • Phippsburg, Maine
      • Posts
        1,046
      • Thanks
        27
      • Thanked
        219
      Toot! Toot!
    • February 2, 2018 11:42 AM EST
      • Phippsburg, Maine
      • Posts
        1,046
      • Thanks
        27
      • Thanked
        219
      I worked on the truss rods last night.  they required some metal work to make the fittings for the truss rod.  Unfortunately I didnt take any photos of the making of the parts, let me know and I can make another part and take some photos if you want to see how I did it.
      the tops of the posts need a metal cap which captures the truss rod and protects the wood from weather and truss rod forces.  the full size turntable has cast iron caps, I made mine from brass.  I made a simple flat box that fit over the ends of the posts.  Next I used my ball peen hammer to dome the middle of the box.  I sawed some 1/8" brass tubing in half the hard way, cut short lengths and bent them to fit the dome and silver soldered them in place.
      the ends of the truss rods needed a solid point that they would pull against on the table frame. the ends of the main beams needed an angular cut and a simple plate with a hole in it.
      the other truss rod catches the table some where in the middle.  making a secure termination was a little trickier here...Mind you the real deal used a cast iron bit but it more or less looked like this:
      on the real deal, turn buckles adjust the tension in the truss rods.  Mine are really fakes, both ends have right hand threads and turning them doesnt change the tension...real turnbuckles have left hand thread on one end and right hand thread on the other.  some day I'll have to get some left hand taps and dies!  They make em!
    • February 2, 2018 12:16 PM EST
      • Waverly, Alabama
      • Posts
        1,070
      • Thanks
        138
      • Thanked
        208
      Nice metal work. Very realistic. I learn something each time I visit this build. Thanks for sharing.
    • February 2, 2018 4:21 PM EST
      • Posts
        12,912
      • Thanks
        744
      • Thanked
        471
      Your attention to detail is just mind boggling. I love it!
      www.cvsry.com www.cvsry.com
    • February 2, 2018 5:31 PM EST
      • Pleasanton, CA
      • Posts
        478
      • Thanks
        268
      • Thanked
        212
      I'm with Dan and Jon: really impressively nice. I drool (which is not good for my keyboard!)...
    • February 3, 2018 1:40 PM EST
      • Denver, Colorado
      • Posts
        1,875
      • Thanks
        192
      • Thanked
        310
      Eric Schade said:
      ...the real deal, turn buckles adjust the tension in the truss rods.  Mine are really fakes, both ends have right hand threads and turning them doesnt change the tension...real turnbuckles have left hand thread on one end and right hand thread on the other.
         Well, then, I guess if you can't do any better than this we'll have to disqualify you from the Challenge.
    • February 3, 2018 4:16 PM EST
      • Phippsburg, Maine
      • Posts
        1,046
      • Thanks
        27
      • Thanked
        219
      last week I only made 4 turn buckles, I made 4 more today and relocated the inner truss rod termination out a bit.  I think it looks better and is more prototypical  I added two bits of brass tubing attached with home mead U-bolts to the end of each main beam so that a handle can be inserted for the crew to spin their engine.  the handles are brass rod to match the handles at the museum.  I also brushed on a wash of black and brown ink in alcohol, probably about 1 ink to 4 alcohol ratio I didnt want it too dark.
      by the way, my crazy locos should get quite dizzy on this table, if I give it a spin it will turn 3 complete rotations.  I tried it with the loco, it doesnt spin quite as far but still not bad, the scale crew should be able to handle the work of spinning their steed.
    • February 3, 2018 4:42 PM EST
      • Waverly, Alabama
      • Posts
        1,070
      • Thanks
        138
      • Thanked
        208
      That is just too cool.  I will send you my shipping address so that work of art can spend the winters here in the warm south and not in all that white stuff .  Great job Eric.
    • February 3, 2018 4:45 PM EST
      • Vail, Az
      • Posts
        4,412
      • Thanks
        714
      • Thanked
        622
      Once they learn to balance her loaded it should spin pretty well.
      Saw these and thought of Dizzy Miss Lizzy
      I see 2 variations; reversing posts and dual wheels on spider.
      Maybe you should start over, said Pooh hopefully.
      John
    • February 3, 2018 5:13 PM EST
      • Phippsburg, Maine
      • Posts
        1,046
      • Thanks
        27
      • Thanked
        219
      Good photos John!  I think both are of the Wiscsset turntable on the WW & F.  The top photo looks to be after abandonment.
      This is the turn table that was the prototype for the museum's.  Actually it was based on plans from the Portland Company which made a lot of the equipment used on the two footers here in Maine.
      This turntable is now the middle school ball field.  When it is dry, there is a ghost of the pit showing as dead grass.
      This post was edited by Eric Schade at February 3, 2018 6:15 PM EST
    • February 4, 2018 12:56 AM EST
      • Posts
        315
      • Thanks
        61
      • Thanked
        36
      Wow!
    • February 4, 2018 10:56 AM EST
      • Pleasanton, CA
      • Posts
        478
      • Thanks
        268
      • Thanked
        212
      That is so impressive. Great job. Did you make the snow too? :-)
    • February 4, 2018 11:32 AM EST
      • Phippsburg, Maine
      • Posts
        1,046
      • Thanks
        27
      • Thanked
        219
      Just like dollar bills, the snow falls from the sky around here!
    • February 6, 2018 2:19 AM EST
      • Kailua, HI
      • Posts
        286
      • Thanks
        103
      • Thanked
        119
      What is the "snow" of which you all speak?
      This is really cool!
    • February 6, 2018 8:17 AM EST
      • Phippsburg, Maine
      • Posts
        1,046
      • Thanks
        27
      • Thanked
        219
      It is kinda like white flower pedals after the fowers have gone by, coating the ground. Some times there are a lot of flowers, that the pedals are so thick on the ground that you can hardly walk through them, and your trains get buried.   Snow is kinda like that except cold like inside your freezer.
    • February 12, 2018 1:17 PM EST
      • Smoggy L.A., Left Coast
      • Posts
        7,381
      • Thanks
        35
      • Thanked
        124
      Awesome Eric! looks full size!
      Have fun with your trains
    • February 12, 2018 6:27 PM EST
      • Denver, Colorado
      • Posts
        1,875
      • Thanks
        192
      • Thanked
        310
         Honestly, Eric, it looks real. That's not easy to do.
      • Denver, Colorado
      • Posts
        1,875
      • Thanks
        192
      • Thanked
        310
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
