  • Topic: Mik 2018 - Outside the Box - Jon Radder
    Back To Topics
    (0 rates)
    • January 20, 2018 2:05 PM EST
      • Posts
        13,004
      • Thanks
        823
      • Thanked
        541
      Dan Hilyer said:
      Jon, I notice the far right sample is used motor oil. I like that color, not necessarily for what you are doing, but just in generaL. Did you just brush the oil on or did you soak them in the oil. If soaking, how long did you soak those samples and how long did it take for the wood to dry out once the oil had been applied?  Sorry for all the questions.
      Hi Dan - This was over two years ago and I didn't take any notes, so I'm just guessing here.  I believe they were soaked - possibly overnight, maybe less.  They were still oily a few days later which helped make the decision not to use it.  I think I still have all of this in a tub somewhere in the train room. If I can find them I'll heck and see if they are still oily.
      Korm & John - Thanks for the opinion. The India ink solution dries very fast too which would be good.  The Linseed Oil & Stain mix takes a few days.
      This post was edited by Jon Radder at January 20, 2018 2:08 PM EST
      www.cvsry.com www.cvsry.com
    • January 20, 2018 3:24 PM EST
      • Waverly, Alabama
      • Posts
        1,267
      • Thanks
        252
      • Thanked
        305
      Thanks, Jon. That is what I figured. I remember my dad having me mop burn motor oil on the wood flooring of his farm trailers as a kid and I don’t think it ever completely dried.
    • January 20, 2018 4:34 PM EST
      • Cape Cod,
      • Posts
        2,934
      • Thanks
        112
      • Thanked
        173
      I really like what you have built and how the framing extends into the tunnel.  It really adds to the illusion of the real deal.
      My vote is for the naturally weathered dull grey but I wonder if these portals were built with wood that was soaked in creosote?
      Of course natural with built up soot from emerging steam trains would be nice too.
    • January 20, 2018 10:55 PM EST
      • Posts
        13,004
      • Thanks
        823
      • Thanked
        541
      Thanks Todd.  I think using the suggested soot method I can get good looking smoke weathering over top of a grey ink wash.
      I finished all but a few details today. First I took some photos of the clearance issue. Just a little tight...
      I wonder what would happen if I framed around the bottom...
      Just enough!!!
      So I added 10x10 all the way around the bottom....
      Then corrected my error at the top corner - I thought I had an awesome fix and took progress pics, but in the end my cut was crooked so I needed to add a little trim piece to dress it up...
      Except for some horizontal 2x8 trim on the side I think I am about done...
    • January 21, 2018 12:08 PM EST
      • Holiday Inn Express, School of train repair
      • Posts
        739
      • Thanks
        762
      • Thanked
        521
      I'm stealing this design Jon..... and not paying you any royalties for it. (Rooster said I didn't have to)
      Boomer
      These Bachmann connies are great but you gotta hit'em jusssst rightttt!
    • January 21, 2018 9:33 PM EST
      • Posts
        13,004
      • Thanks
        823
      • Thanked
        541
      I got called in to work for a few hours today. Managed to get the last of the detail boards on this morning.  I deiced to continue around the corner and cover the exposed wall framing. This piece will stay attached to the wall and act as a retainer to the main section.  Sketch or photo when I get something to show.
      Thanks for the comments & suggestions.
    • January 22, 2018 6:56 PM EST
      • Right here 'X', Pa
      • Posts
        5,435
      • Thanks
        711
      • Thanked
        300
      As great as this looks and knowing you still need to cover it I can't help but be reminded of the discussion held over Devon's build and the need for wet walls inside the tunnel, knowing your area and felling that realism would dictate the need for icicles also. Will these be included in this build ?
    • January 22, 2018 7:08 PM EST
      • Post Falls, Idaho
      • Posts
        7,247
      • Thanks
        1,394
      • Thanked
        603
      I can offer some expertise on the subject.
    • January 22, 2018 8:04 PM EST
      • Defending the State of Exile! ,
      • Posts
        13,032
      • Thanks
        1,345
      • Thanked
        899
      Nice work Jon
    • January 22, 2018 10:57 PM EST
      • Posts
        13,004
      • Thanks
        823
      • Thanked
        541
      Thanks guys.  If it gets wet on it's own, then OK; but I'm not adding it!
      I'm finished with construction as of tonight. Still need to color and weather, but no more wood, pins or glue.   The last work done on the removable structure was to add the bracing detail along the right retaining wall...
      Attention was then turned to the exposed wall frame member and how to finish off the area. First I tacked on a couple of scraps from the build to continue the bench top to the paneling and covered it with the fake grass...
      I then built a matching section to cover the wall framing; continuing the retaining wall around the corner to the start of wall paneling...
      That last bit will be permanently attached to the wall framing. It serves as an alignment edge for the removable section that has a mating slot. Note to self: I need an overhead shot to show the interlocking parts.
      So here is a long shot and final look under the paint...
      Now it's off to the lab to test numerous dilutions of India ink and alcohol to find the shade of grey that I want.
    • January 22, 2018 11:16 PM EST
      • Waverly, Alabama
      • Posts
        1,267
      • Thanks
        252
      • Thanked
        305
      That turned out very well, Jon.  It really makes "Box" a focal point on the layout.  Great job.
    • January 24, 2018 8:16 AM EST
      • Posts
        13,004
      • Thanks
        823
      • Thanked
        541
      OK, now I need some advice.  I have decided on a simple India Ink and Alcohol wash for stain.  I did some tests last night at various dilutions and I think I have a winner. Pics will follow this evening.
      Because the interior framing is a bit complex,  I have decided to take it to work and spray the stain with my HVLP spray system.  I need to buy some alcohol and thus the advice.  Would 70% Alcohol be good, or should I go with 90% for quicker flash?  This will be my only cash outlay for this project so I have plenty of budget.
    • January 24, 2018 8:19 AM EST
      • Marysville, Kansas
      • Posts
        749
      • Thanks
        556
      • Thanked
        205
      That looks really nice.   Good idea to cover that spot.
      Chris
    • January 24, 2018 9:10 AM EST
      • Post Falls, Idaho
      • Posts
        7,247
      • Thanks
        1,394
      • Thanked
        603
      I use 90, never tried anything less. So can't say. But I know 90 works well. flashes off very fast. And really burns in fresh xacto cuts.
    • January 24, 2018 9:41 AM EST
      • Vail, Az
      • Posts
        4,520
      • Thanks
        834
      • Thanked
        701
      Avoid extra water, use the 90.
      We could dilute the ink in water, but we use alcohol because it doesn't warp as much.
      John
    • January 24, 2018 10:16 AM EST
      • Cape Cod,
      • Posts
        2,934
      • Thanks
        112
      • Thanked
        173
       I really like that portal, it looks very strong like it could hold up the mountain.
      Alcohol?  I prefer Jack Daniels...   whacka whacka ..
      Once it is aged will you be adding signs like "no trespassing"  or perhaps name the tunnel or number it?
    • January 24, 2018 6:14 PM EST
      • Posts
        5,435
      • Thanks
        711
      • Thanked
        300
      I'll drink to that but have you tried Larceny ?
    • January 24, 2018 6:38 PM EST
      • Pittsburgh, Pennsylvania
      • Posts
        10,210
      • Thanks
        84
      • Thanked
        647
      Name the tunnel?  Hi everyone, this is my tunnel, Jim. You must excuse Jim, he is a little bit of a stiff, and tends to get board.
      My vote is for the 90%
      Shannon car Shops
      Home of the infamous leg lamp
      I.A.R.R.R. Member #12
      and King Butt Modeler
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
