  • Topic: Mik's2018 BC Todd Haskins
    Back To Topics
    (0 rates)
    • January 26, 2018 10:00 AM EST
      • Peoria, NW of Phoenix, Arizona
      • Posts
        1,122
      • Thanks
        176
      • Thanked
        190
      What kind of blade are you using to get nice smooth cuts with your band saw? My band saw looks like bad chainsaw cuts
      Butt Modeler #2
    • January 26, 2018 5:06 PM EST
      • Vail, Az
      • Posts
        4,520
      • Thanks
        834
      • Thanked
        701
      https://www.highlandwoodworking.com/woodslicer-resaw-bandsaw-blades.aspx
      http://www.finewoodworking.com/2011/04/07/how-to-set-up-a-bandsaw
      This post was edited by John Caughey at January 26, 2018 7:11 PM EST
      John
    • January 26, 2018 9:09 PM EST
      • Cape Cod,
      • Posts
        2,934
      • Thanks
        112
      • Thanked
        173
      Nothing fancy just a regular band. Not too course and not too fine.   I set up a fence, lowered the wheel guides to their lowest setting then used a stick to press the wood tight so the blade wouldn't wander and pushed the length of wood through.   On the larger pieces, the 1/2x 1/2 I ripped those on my table saw.
      Believe me they are not as smooth as they appear in the photo. The uneven roughness should give the whole tipple a good look when it gets stained or given the ink treatment.
    • January 26, 2018 9:21 PM EST
      • Post Falls, Idaho
      • Posts
        7,247
      • Thanks
        1,394
      • Thanked
        603
      Here inam trying to figure out how to add saw marks and Pete is looking to eliminate them
    • January 26, 2018 11:19 PM EST
    • (Moderator)
      • Farmington, New Mexico
      • Posts
        2,369
      • Thanks
        20
      • Thanked
        350
      @RevDev  Two ways to get that re-sawn or ruff sawn look.
      1.  After set up of the guide just wack the back end ( out feed end) with a mallet towards the blade after barely loosing the rip fence, this will have the blade skimming the out feed end and scoring the wood.   You do get some saw dust thrown at the feed end.
      2.  Dedicate a blade to the re-sawn works.   Take and bend two teeth on the blade in the opposite directions, R & L,  from the normal set of the kerf. This will scuff the wood as it's cut.
      New Mexico­ Northern ­Railroad
      D&RGW ­315 Crew ­member, Fireman
      RRR #4
      Board Memb­er, Durang­o Railroad­ Historica­l Society
    • January 27, 2018 5:38 PM EST
      • Phippsburg, Maine
      • Posts
        1,068
      • Thanks
        27
      • Thanked
        239
      I always use a good carbide blade with a bunch of teeth.  it does a nice fine cut.  but I think it looks enough like rough sawn lumber when stained that it is close enough and if I do any texturing it is to weather it as with a wire brush with the grain.
    • January 29, 2018 8:58 PM EST
      • Cape Cod,
      • Posts
        2,934
      • Thanks
        112
      • Thanked
        173
      Good ideas on making rough cut lumber.
      A bit more work was done over the weekend and I am just about out of wood except for a couple of thin stringers that will be used as corner boards on the winch house and lower structure.
      I had to rip more lumber from the left over 2x4 and will use it to plank these parts.
      Here is a photo of how far along the tipple is prior to running out of wood.
    • January 30, 2018 10:57 AM EST
      • Post Falls, Idaho
      • Posts
        7,247
      • Thanks
        1,394
      • Thanked
        603
      that is coming out nice. . . Do you need my address?
    • January 30, 2018 12:36 PM EST
      • Denver, Colorado
      • Posts
        1,903
      • Thanks
        201
      • Thanked
        330
         Get in line.
    • January 30, 2018 4:46 PM EST
      • Cape Cod,
      • Posts
        2,934
      • Thanks
        112
      • Thanked
        173
      Address?    Would you like me to send you the official napkin sketch so you can build your own tipple ?   LOL
       A bit more progress has been made and the winch house is now cladded with planking.   The next step is to figure out a chute and then the roof line for the house below.
    • January 30, 2018 5:00 PM EST
      • Denver, Colorado
      • Posts
        1,903
      • Thanks
        201
      • Thanked
        330
         CHUTE...that's the word I was looking for. I keep calling them sluices but I knew something was wrong.
    • January 30, 2018 5:48 PM EST
      • Posts
        315
      • Thanks
        61
      • Thanked
        36
      That is looking great!
    • January 30, 2018 7:49 PM EST
      • Phippsburg, Maine
      • Posts
        1,068
      • Thanks
        27
      • Thanked
        239
      Looks like Devon got his Dibbs in this time!
    • January 30, 2018 8:50 PM EST
      • Defending the State of Exile! ,
      • Posts
        13,032
      • Thanks
        1,345
      • Thanked
        899
      Devon who?
      • Posts
        13,032
      • Thanks
        1,345
      • Thanked
        899
      Shire ?
    • January 31, 2018 10:48 AM EST
      • Cape Cod,
      • Posts
        2,934
      • Thanks
        112
      • Thanked
        173
      Yeah like in "chute"  I"m running out of time to finish this build!
      Speaking of chutes.. the one on my project was giving me a chute fit!   I'm still trying to decide whether to make this a working tipple as in dump stuff in the top, lower the chute and watch it spill out.  I think I will at least hinge the chute so it goes up and down and yesterday I made some progress in that department.
      The winch house is now planked and I have started on the lower.  What will bring this build together is paint/ stain/ ink and all that takes time !   Chute!
    • January 31, 2018 1:20 PM EST
      • Post Falls, Idaho
      • Posts
        7,247
      • Thanks
        1,394
      • Thanked
        603
      A chute fit, lol. Kinda like Devon Shite (alternative spelling of Shire?)
    • January 31, 2018 6:01 PM EST
      • Vail, Az
      • Posts
        4,520
      • Thanks
        834
      • Thanked
        701
      Todd I think you'd have to redo the slope inside your bin to make it function, unless you are mining ore balls . I was going to ask you earlier how much you paid the 2 shovels, stationed inside the bin, to keep the ore flowing...?
      All the bins I've seen are closer to 45degrees. Too much friction for much less.
      John
    • January 31, 2018 8:07 PM EST
      • Waverly, Alabama
      • Posts
        1,267
      • Thanks
        252
      • Thanked
        305
      Do I have to say it?  I might as well to save someone else from having to do it ..... Pictures or it didn't happen
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
