  • Topic: 2018 Passaro Challenge: Stairway to Heaven
    Back To Topics
    (0 rates)
    • January 17, 2018 9:07 PM EST
      • Denver, Colorado
      • Posts
        1,875
      • Thanks
        192
      • Thanked
        310
          Okay, you racehorses want to see some progress, I'm gonna show you some progress....NOT!
          Well, here's the project anyway. It's a while back, but someone may remember that two years ago I modelled a mine for the challenge; well, that mine is in place, along with the hoist that I built right after the challenge was over. The first picture is the mining district which I want to work on--I almost said "finish," but that's too much pressure: I saw what happened to Devon!
          The bridge is supposed to be the skeleton foundation for the Glenfinnan Viaduct. This next picture is the gap I need to bridge between the mining office (red) and the wall of the viaduct; it has to be bridged so that a freight car an be unloaded. So that's one part of the challenge. The second picture shows the size of the gap that needs to be bridged.
          You can see here what disrepair the office is in:
         I need an auto ramp, also part of the challenge, to go from the dock of the office to the auto/truck/delivery tunnel you see on the left (it's a hole in the rock wall):
          I need to build out a system of ramps and "sluices" (not really sluices, just channels) to get the raw ore from the mine to the ore cars that get placed on the tracks in the tunnel that goes through the mountain. The first picture shows the tracks and the second picture shows the area that needs to be gapped. All of this is part of the challenge.
         Now for the stairways and ladders. The workers have to be able to get from the trucks/freight cars/and office up to the level of the hoist, and from there they have to be able to get to the level of the mine, and from there to the area above the retaining wall, and from there to the two mines that will be in the rock wall above the retaining wall (still to be built).
          And finally, the stairway to heaven will ascend to the upper corner of the rock wall above the mine.
         So here's my big progress to far: I cleared off the work table, which was no mean feat to get that accomplished, not to mention work up the courage to even get started clearing it, and I found a 2x4, actually two 2x4s bolted together that I used as one of the legs in my first layout, of which there are no pictures, and cut them down to 21" because two times 21 is 42 and I'm working in 1:24 scale. (Don't ask why I have five plastic school rulers?!?)
          So here's what's ominously staring at me waiting for something to happen:
    • January 17, 2018 10:10 PM EST
      • Waverly, Alabama
      • Posts
        1,070
      • Thanks
        138
      • Thanked
        208
      C'mon John.  Sit down, relax and the creative juices will start to flow and you will turn out a masterpiece just like you always do.  I'm curious to see how you incorporate that bolt hole in the 2x4 into the build
    • January 23, 2018 3:59 PM EST
      • Denver, Colorado
      • Posts
        1,875
      • Thanks
        192
      • Thanked
        310
          Talk about being off to a slow start. I feel like Carlos Gonzalez, our Rockies outfielder.
          So I tore down the mining office because it needed to be lowered to the level of the deck of the bridge to which it will connect, and it needed repainting, so I needed to decide on a color (I tried a few and decided on a dark green with grey):
         THEN, I set up my table saw, on the floor, it's too cold outside...my daughter's King Charles Cavalier wasn't too impressed...and started making some cuts.
         There's a possibility that there is no way in hell I can cut anything under 3/8" and I'll have to use scale lumber I have laying around. I might try one more time, but I don't seem to have enough control of the saw, whether it's the quality of the saw or the coarse blade, but I'm not risking my fingers over tiny pieces of wood. I have my fine-blade chop saw for cuts, but not for ripping. I may use the 2x4s and table saw to make all the scale 2x4s, 4x4s, and 6x6s, and whatever else comes up that's over 3/8" but not the thinner stuff. I don't know if this is in the spirit of the challenge or not.
      So I started making the ramp from the office warehouse to the bridge (started with two posts, but it's got to start somewhere!), the doors for the office, and the front porch of the office. And that's as far as I've gotten. I need to get a move on!
           I made the ramp way way way too wide, so I improvised and cut out side ramp to the ground...
         Thanks for looking and if you have any ideas let me know.
    • January 23, 2018 4:13 PM EST
      • Vail, Az
      • Posts
        4,412
      • Thanks
        714
      • Thanked
        622
      Where are the ladders?
      Are you done yet?
      You need a zero clearance insert and a fine tooth blade after cutting the lumber into smaller finger chasers....
      We are allowed to use our scale lumber, but we must subtract all saw kerfs (width of cut) from the total....  so long ago you fergot?
      Use scrap wood as pushers to keep the fingers safe...
      Giddy up!
      John
    • January 23, 2018 4:24 PM EST
      • Denver, Colorado
      • Posts
        1,875
      • Thanks
        192
      • Thanked
        310
         Actually, I got that wrong...I'm good on the saw down to a little under 1/4" not 3/8" so there! But I'll give a fine tooth blade a try, John.
    • January 23, 2018 5:52 PM EST
      • Post Falls, Idaho
      • Posts
        6,894
      • Thanks
        1,137
      • Thanked
        448
      I can tell you part of you problem is that you so not have a zero clearance plate in that saw. oops john beat me too it.There is no way to safely do it without on. Anything smaller than your 3/8 Will want to fall through the plate. Then you need a real good push stick
      This post was edited by Devon Sinsley at January 23, 2018 5:54 PM EST
    • January 23, 2018 6:05 PM EST
      • Posts
        12,912
      • Thanks
        745
      • Thanked
        471
      I Have a very similar saw sold as a Craftsman.  I made my own zero clearance plate from a hunk of plywood, but I had to mill out spots for the mounts with my Dremel.  That is a project in itself, but yeah - you need one.
      www.cvsry.com www.cvsry.com
    • January 23, 2018 6:44 PM EST
      • Vail, Az
      • Posts
        4,412
      • Thanks
        714
      • Thanked
        622
      Wow! I've never seen a  Paint by Numbers that large!
      Nice ladders....
      John
    • January 23, 2018 7:12 PM EST
      • Pinon Hills, California
      • Posts
        4,051
      • Thanks
        9
      • Thanked
        41
         I like my 12-inch fine blade so much I use a carbide one that never gets changed.
    • January 23, 2018 9:19 PM EST
      • Denver, Colorado
      • Posts
        1,875
      • Thanks
        192
      • Thanked
        310
      Nice ladders....
         Well I need to be more careful about what's in the background, eh???? What you see there is the start of a portrait, at least how I start 'em. The other one you see peeking over the top is little further along, but not ready for prime time.
          I just got back from the hardware store where I bought a thin blade with 140 teeth on it for my table saw; it makes the old blade I took off look like something you'd use in the yard to dig trenches for sprinkler line!
         No distractions tonight so I hope to get a lot accomplished.
         One of the fellas sent me a message with a tip on how to do some ladders and I'm looking forward to trying it.
    • January 23, 2018 9:32 PM EST
      • Phippsburg, Maine
      • Posts
        1,046
      • Thanks
        27
      • Thanked
        219
      Gee 140 teeth seems kinda excessive  but good for fine stuff!  Your paintings look good!
    • January 23, 2018 9:41 PM EST
      • Waverly, Alabama
      • Posts
        1,070
      • Thanks
        138
      • Thanked
        208
      Nice progress John.  I will echo John and Devon's suggestion of a zero clearance insert.  It is a must have for cutting small or thin wood on the table saw.  It will make your scale lumber life much easier and more importantly, safer.
    • January 23, 2018 9:48 PM EST
      • Waverly, Alabama
      • Posts
        1,070
      • Thanks
        138
      • Thanked
        208
      I almost forgot .... well, I didn't forget, I just wanted to make 2 post so I could get to 667 posts for obvious reasons.  I love the paintings.  I am always amazed at how folks with talents like yours, John, can start with something that looks like finger painting by a 3 year old and end up with a fine portrait.  Not saying the first portrait looks like finger painting .... ahh heck, you know what I mean.  Good job.
    • January 24, 2018 6:46 AM EST
    • (Moderator)
      • Farmington, New Mexico
      • Posts
        2,306
      • Thanks
        20
      • Thanked
        279
      WOW John...  I thought that I was the only one that had Fine Art in the background of a challenge build.
      New Mexico­ Northern ­Railroad
      D&RGW ­315 Crew ­member, Fireman
      RRR #4
      Board Memb­er, Durang­o Railroad­ Historica­l Society
    • January 24, 2018 9:10 AM EST
      • Posts
        12,912
      • Thanks
        745
      • Thanked
        471
      Now, with your new blade expect lots and lots of very fine sawdust that will float in the air and cover everything in the room, get stuck on your shoes and track all through the house.  Everything in my garage is coated with fine dust and it has worked it's way upstairs into the house. Wife not happy.
    • January 24, 2018 9:43 PM EST
      • Peoria, NW of Phoenix, Arizona
      • Posts
        1,092
      • Thanks
        157
      • Thanked
        151
      John , read Bob cope's post on this thread about saw safety, it will help you keep your painting fingers and eyes, years ago I got hit by a off cut that kicked back from my old table saw, I had a bruise of many colors on my stomach for a long time, and am lucky thats all that happened
      Butt Modeler #2
    • January 26, 2018 12:50 PM EST
      • Posts
        4,051
      • Thanks
        9
      • Thanked
        41
         Keep the sawdust off of your background art!
          I will do some looking today and see if I have a picture of the ladder they had to access the mine in Wall Street at Calico. You will be amazed!
      Keep up the good work and look forward to an update soon!
    • January 28, 2018 1:03 PM EST
      • Denver, Colorado
      • Posts
        1,875
      • Thanks
        192
      • Thanked
        310
         First off, I read and re-read that article on table saws, and as soon as this challenge is over, I'm trying some of those things, especially the zero guard and the guide. As far as Jon and others warning about sawdust, actually, my very first problem with my brand new wonderful 140-tooth fine sawblade was that I filled the house with smoke using it to cut the 2x4, and got some wicked saw burn effects, but now all is okay because I just feed the wood in more slowly. I appreciate everyone's advice and expertise.
        Now then I think I got the mining office finished, and, with it, the first part of my challenge. I continued with the back deck, making a deck and a roof, like this:
         And then I took time to paint the back of one of these ridiculous plastic school rulers I have....why? because you can't read the damn things.
         But now I can!
          So here's how the back deck started shaping up, and you can see the stairs and the front porch of the office taking shape. I forgot to take pictures of that, but I found some good ways to make the rises on the stairs, which I'll detail as I move along to the next part of this project.
         The next thing is that I needed to get this office on a 1/8" piece of untempered masonite as a base, and, also, so that I can place and remove the entire structure on the layout as needed. Once the base is covered up with the local dirt and rock and weed, no one will know it's on a base.
         Then I started weathering/painting my 2x4 wood. I don't know why, but I always paint the bottom of things even though no one will ever see them. It's goofy but I feel like I'm cheating if I don't!
         So here are some views of the  finished office starting with the back, and then the front (except I forgot to put plastic in the windows, man there is always some detail that needs more work, and this one has been a never-ending set of details that needed work).
         The deck leading to the freight part of the office on the right, the one with the barrels and the tire, will rest on the bridge...that's why it looks like it's hanging in the air!
         So there we go. All in all, I'm happy with the results, and I have to say that bringing something, anything, this close to being finished is satisfying, and confidence building really.
         Now I got to figure out which part of this project I'll tackle next. I think I need to go out there on the layout and see what the next logical part to finish should be.
         How many more weekends to we have? I still have a long way to go to get on that stairway to heaven.
    • January 28, 2018 1:25 PM EST
      • Waverly, Alabama
      • Posts
        1,070
      • Thanks
        138
      • Thanked
        208
      Its amazing how a few decks, walkways and steps will bring a scene alive.  The office looks completely different now ... yes, I know, that was the intent all along.  But I never realized it would make that big of a difference.  Now slide some old rail under it and the office will look lie it was originally supposed to be temporary but became permanent.  Great job, John.  You have an eye for the little details that matter.
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
