Forums Modeling Reference
  • Topic: Bachman C-19 Circuit Information
    Back To Topics
    (0 rates)
    • December 10, 2017 9:32 AM EST
      • Posts
        12,416
      • Thanks
        364
      • Thanked
        239
      • Reputation
        Well Respected
      Gathered from Stan Ames, Bachmann and my own circuit tracing.  All images are Hi Res - Use browser's View Image function for full size.
      Schematic Diagram from Bachmann via Stan Ames...
      From Bachmann - Tender Socket DCC Pin Assignment...
      From Bachmann - Circuit Interconnects...
      And finally, from the C.V.S.Ry Over Engineering Department - Tender Plug wire assignments...
       Regarding Note 4 - This wire only has +5V if +5V is being supplied on the VDD Input  (Note 1)
      This post was edited by Jon Radder at December 11, 2017 10:21 PM EST
      www.cvsry.com www.cvsry.com
    • December 10, 2017 11:22 AM EST
      • Berkshire, Ma.
      • Posts
        652
      • Thanks
        90
      • Thanked
        33
      • Reputation
        Well Respected
      Thank you Jon any way of making this a sticky? so it doesn't copied and posted some were else.
      Richard
    • December 10, 2017 11:50 AM EST
      • Posts
        12,416
      • Thanks
        364
      • Thanked
        239
      • Reputation
        Well Respected
      Bob can sticky it if he wants to, but in this forum (Reference) it doesn't make much sense because most threads in this category contain similar type of information. Would't keep anyone from copying and re-posting either.  All except my plug pin-out is available elsewhere already.
    • December 10, 2017 4:10 PM EST
      • Posts
        3,837
      • Thanks
        0
      • Thanked
        35
      • Reputation
        Well Respected
      Jon, would you kindly allow me to link this thread on my website "How To's"? Proper credit will be noted.
      Best wishes,
      Tony Walsham
    • December 10, 2017 4:42 PM EST
      • Posts
        12,416
      • Thanks
        364
      • Thanked
        239
      • Reputation
        Well Respected
      Sure Tony.  If you would rather have the original PDF of the pin-out I can email that to you. I can also remove the third column of how I am using the pins as that may not apply to your customers.
      This post was edited by Jon Radder at December 10, 2017 4:50 PM EST
    • December 10, 2017 9:20 PM EST
      • Posts
        3,837
      • Thanks
        0
      • Thanked
        35
      • Reputation
        Well Respected
      Thanks Jon.
      I was intending to just put it up as a resource for others who might be interested.
      Me, I never ever gut locos unless I really have to.
      I use my own PnP pcb in the tender to take advantage of the existing wiring.
      Best wishes,
      Tony Walsham
    • December 10, 2017 11:22 PM EST
      • Posts
        12,416
      • Thanks
        364
      • Thanked
        239
      • Reputation
        Well Respected
      Whatever you prefer Tony.
      Re gutting - I had a good install previously using the existing socket, but when upgrading the sound board I decided to upgrade the speaker and what I chose won't fit with the stock electronics so it and the weight has to go.
    • December 11, 2017 10:19 PM EST
      • Posts
        12,416
      • Thanks
        364
      • Thanked
        239
      • Reputation
        Well Respected
      I have updated my Tender Board Connector Pin-Out. I discovered a few dependencies once the board was out of the circuit.  I believe version 3 (above and here) is now correct. I have also added some notes regarding the 5V supply required to use the chuff circuits and LEDs if the tender board is removed.
      This post was edited by Jon Radder at December 11, 2017 10:50 PM EST
    • December 11, 2017 10:49 PM EST
      • Carlsbad, CA
      • Posts
        6,327
      • Thanks
        83
      • Thanked
        294
      • Reputation
        Respected
      Thanks Jon, started a page will enhance it shortly, probably an explanation of interfacing and powering the main board.
      https://elmassian.com/index.php?option=com_content&view=article&id=739:c-19-wiring&catid=14&Itemid=1175
    • December 11, 2017 10:53 PM EST
      • Posts
        12,416
      • Thanks
        364
      • Thanked
        239
      • Reputation
        Well Respected
      OK - Thanks for letting me know you are publishing it.  Please replace the one you have with Ver. 3 above. The one you have is not correct. V3 fixes errors and adds some detail.
    • December 12, 2017 12:41 AM EST
      • Carlsbad, CA
      • Posts
        6,327
      • Thanks
        83
      • Thanked
        294
      • Reputation
        Respected
      Done, thanks.
    • December 12, 2017 12:32 PM EST
      • Posts
        2,356
      • Thanks
        8
      • Thanked
        122
      • Reputation
        Well Respected
      Thanks, Jon. These are great! You were correct--I didn't have the wiring schematic when I tore into mine.
      With regard to your question about which speaker, I'm doing an LGB mogul right now with one of these in the smokebox. Don't laugh, but the steam dome off of a Bachmann Big Hauler makes a fantastic enclosure for it! It's a 4-ohm speaker, so I'm pairing it in series with another 4-ohm speaker in the tender. I had a 2.5" Visaton speaker in there at first, but the Visaton drowned out the smokebox speaker. I switched to a 1 3/4" 4-ohm speaker that was in the tender from its original owner, built an enclosure from a plastic baby food container, and the combination of those two speakers sounds fantastic. I've got a Tsunami2 decoder in this loco, so I was able to adjust the EQ to really get the most (to my ears) out of these.
      The TCS decoder I'll be putting in my C-19 has two speaker outputs, so I'll likely go with the 2" Visaton speakers I've used in some other projects. I'll probably do the same thing as with the mogul--one speaker in the boiler, one in the tender.
    • December 13, 2017 2:13 PM EST
      • Carlsbad, CA
      • Posts
        6,327
      • Thanks
        83
      • Thanked
        294
      • Reputation
        Respected
      On the speakers, you might be able to/want to use the lower profile FRS7's, which while a 2.5" speaker, often will fit in less space.
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
