  • Topic: a smoked sierra what did I do wrong?
    Back To Topics
    (0 rates)
    • November 11, 2017 6:57 PM EST
      • Cape Cod,
      • Posts
        2,815
      • Thanks
        77
      • Thanked
        110
        Yep I bought, went to test and promptly blew up a soundtraxx sierra board steam V 1.1 throttle up.  I have installed 3 of these for basic track power with no problems.  Two ride in tenders that are shared between my steamers.
      I'm still kicking myself and I don't know what I did wrong.
       I used the wiring diagram that has #9 to the positive side speaker and #10 to the negative, #8 and #7 went  directly to track.  I turned my test transformer on which is attached to a 24 " piece of track, applied power slowly and at about 1/4  throttle,  6-7 volts there was a pop and smoke.
       Any idea on what I did wrong and can this be repaired?
    • November 11, 2017 7:31 PM EST
      • Pittsburgh, Pennsylvania
      • Posts
        9,610
      • Thanks
        65
      • Thanked
        508
      If you can see what component blew then maybe, but maybe not. As I understand it, the Sierra uses a board with traces in-between the top face and bottom face of the board. So if the inside traces aren't damaged, and if you can carefully replace the damaged surface mounted component, then maybe it can be fixed.
      This is why there is a warning in the manual about "testing" the board without a locomotive on the track. Some power supplies can put out too much voltage, when there is no appreciable load on them.
      Shannon car Shops
      Home of the infamous leg lamp
      I.A.R.R.R. Member #12
      and King Butt Modeler
    • November 11, 2017 8:03 PM EST
      • Prescott Valley, AZ
      • Posts
        622
      • Thanks
        6
      • Thanked
        32
      Hi Todd........   That's a bummer...   The Sierra boards are such good boards but when they blow, there is just no way to get them fixed.  Soundtraxx stopped repairing them many years ago...  They just couldn't get the components they originally used....
      Sounds like there was as voltage spike as David mentioned.  The boards are so very sensitive to spikes and will not tolerate voltages much over 14 volts.  Not sure what the top end is but I blew one using an 18 volt battery.  I should have used the power resistor but got "lazy"....
      In May 2015, the PCSRR in Dewey, AZ became a Fallen Flag
      But, we're still quite active in the Model Railroading Community
    • November 11, 2017 8:40 PM EST
      • Santa Ana, CA
      • Posts
        1,378
      • Thanks
        1
      • Thanked
        66
      If that is the only wiring that was connected, there is no way anything should have blown, regardless of polarity.
      That said, I have a Sierra Board where for no apparent reason one of the two lighting circuits just stopped working.  This did work but now puts out no voltage and everything else still works fine.
      Perhaps you had a wire strand creating a short at adjacent terminals or somewhere on the board itself.
      This post was edited by Todd Brody at November 11, 2017 8:41 PM EST
    • November 12, 2017 8:15 AM EST
      • Eastern Massachusetts
      • Posts
        894
      • Thanks
        3
      • Thanked
        49
      I have 2 diesels with  Sierra boards and run them from a 24 volt supply.  These are the old ones made for large scale.
      Batteries are long dead in these and I should convert to super caps.
    • November 12, 2017 9:14 AM EST
      • Ottawa/Nepean, Ontario, Canada
      • Posts
        4,350
      • Thanks
        75
      • Thanked
        144
      Another "Magic Smoke" lesson...
    • November 12, 2017 4:32 PM EST
      • Spokane Valley, Washington St.
      • Posts
        5,234
      • Thanks
        160
      • Thanked
        102
      When you strip wires, hold the wire and striping tool away from your project. A hair of a wire can fall onto your board and cause total melt down. Ask me, I know. :-)
      I toasted a Phoenix board that way.
    • November 12, 2017 5:17 PM EST
      • Cape Cod,
      • Posts
        2,815
      • Thanks
        77
      • Thanked
        110
      This is the wiring diagram I used.    The bit that blew is the small rectangle block in the middle between 2 similar blocks that are between terminals 4 and 13.
      I don't know if that can be fixed.  It looks like it is soldered right to the board.?
      This post was edited by Todd Haskins at November 12, 2017 5:26 PM EST
    • November 12, 2017 8:58 PM EST
      • Saint Johns, Florida
      • Posts
        3,707
      • Thanks
        212
      • Thanked
        279
      That's called a surface soldered component. from the diagram I can't tell what it's function is. It looks like you wired it correctly. Like others have said I think you had an over voltage spike.
    • November 13, 2017 4:08 AM EST
      • Posts
        2
      • Thanks
        0
      • Thanked
        0
      Can you post a picture of the burnt board and a picture or a working board ?
    • November 13, 2017 10:27 AM EST
      • Cape Cod,
      • Posts
        2,815
      • Thanks
        77
      • Thanked
        110
      It is such a small component that I don't think it would show up in a photo John K.    Under a magnifying glass it appears crusty and burnt.
      Is this something that can be fixed?  Would any of you electronic wizards want to take a stab at it?
      This post was edited by Todd Haskins at November 13, 2017 10:28 AM EST
    • November 13, 2017 1:43 PM EST
      • Santa Ana, CA
      • Posts
        1,378
      • Thanks
        1
      • Thanked
        66
      If you blew the black rectangle, the part # (written on the case) is C02M 2D.  It connects to the left socket pin and has a line toward the pin side, so I believe is a diode.
      If you blew the yellow rectangle, the # is 1560 R0601 (this last bit tiny and very hard to read and may not be correct) and the line is away from the socket.  If it's one of the other parts, let me know and I'll try to read the #.  But they are even smaller.
    • November 17, 2017 2:19 PM EST
      • Posts
        2,389
      • Thanks
        9
      • Thanked
        154
      Todd, I've got some spare Sierra boards I'm looking to sell if you're in need of replacements. Two working boards, two non-working boards whose chips can be removed and placed in the working boards. (4 separate sound files total--EBT and three others, but I forget exactly which ones.)
    • November 18, 2017 11:09 AM EST
      • Cape Cod,
      • Posts
        2,815
      • Thanks
        77
      • Thanked
        110
      I'm always on the look out for affordable sound.
      I also have another non working Sierra so maybe I will try to replace that little blown square.  I will be sure to watch which side the lines are on if it is a diode.   It would be great to get this working and into a loco.
    • November 18, 2017 1:27 PM EST
      • Santa Ana, CA
      • Posts
        1,378
      • Thanks
        1
      • Thanked
        66
      You will need a hot air soldering station to remove/replace the SMDs.
    • November 20, 2017 9:39 AM EST
      • Cape Cod,
      • Posts
        2,815
      • Thanks
        77
      • Thanked
        110
      Well given that I had to look up what a hot air soldering station is I would say I'm not qualified to repair the board.   LOL
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
