Forums Modeling Technical Modeling
  • Topic: USAT truck mount repair
    Back To Topics
    (0 rates)
    • October 12, 2017 1:54 PM EDT
      • Kittery, ME
      • Posts
        509
      • Thanks
        36
      • Thanked
        179
      A quick lunchtime project today.  I bought a few USAT tank cars a while back, and two of them had damage where the truck mounts to the body, making them pretty wobbly.  I filed the area clean, and printed a new mount point.  Works great.
      Original:
      Replacement:
    • October 12, 2017 2:18 PM EDT
      • Bremerton, Washington
      • Posts
        1,028
      • Thanks
        2
      • Thanked
        5
      Eric:  You may get some requests for your little fix.  Paul
    • October 12, 2017 2:31 PM EDT
      • Kittery, ME
      • Posts
        509
      • Thanks
        36
      • Thanked
        179
      https://www.thingiverse.com/thing:2582616
    • October 12, 2017 8:41 PM EDT
      • Carlsbad, CA
      • Posts
        7,405
      • Thanks
        104
      • Thanked
        476
      Eric, the bolster was wider side to side and thinner fore and aft for a reason... you have changed it to a flat platform. I wonder your reasoning on this.
      This post was edited by Greg Elmassian at October 12, 2017 8:42 PM EDT
    • October 12, 2017 8:50 PM EDT
      • Kittery, ME
      • Posts
        509
      • Thanks
        36
      • Thanked
        179
      I didn’t give that much thought. The Kadee truck that I’m using flexes on its mount point, so I think it will work. I could easily curve the top of the mount, though. My motivation was primarily surface area for strength.
    • October 12, 2017 9:05 PM EDT
      • Kittery, ME
      • Posts
        509
      • Thanks
        36
      • Thanked
        179
      Thinking more about this, I see how the original design interacts with the stock truck. The truck is loose on the mount when the screw is tightened so the shape of the mount determines its freedom in each axis.  The Kadee truck comes with its own center pin that clamps tightly to the original mount, defeating this functionality, and the truck itself is designed to flex on its own mount instead. This is all I was thinking about when I drew this up, but you’re right that it wouldn’t work well for a stock truck.
      This post was edited by Eric Reuter at October 12, 2017 9:10 PM EDT
    • October 12, 2017 11:17 PM EDT
      • San Mateo, California
      • Posts
        193
      • Thanks
        34
      • Thanked
        56
      Eric, Are you using the factory USAT plastic Bettendorf truck with projecting ribs on its bolster - like the one shown in the middle of the below illustration?   (The small contact area of the ribs would serve to reduce friction when the truck pivots, particularly if rubbing against a rounded, thinner fore-aft  area type car bolster)
      Selected Freight Trucks
      -Ted
    • October 13, 2017 5:43 AM EDT
      • Pittsburgh, Pennsylvania
      • Posts
        9,860
      • Thanks
        73
      • Thanked
        548
      Ted, he said he was using KaDee trucks.
      Shannon car Shops
      Home of the infamous leg lamp
      I.A.R.R.R. Member #12
      and King Butt Modeler
    • October 13, 2017 6:10 AM EDT
      • Kittery, ME
      • Posts
        509
      • Thanks
        36
      • Thanked
        179
      I think there may still be an issue with friction as it rotates.  Maybe I'll try this instead.
    • October 13, 2017 1:25 PM EDT
      • Posts
        193
      • Thanks
        34
      • Thanked
        56
      David, you are correct - I missed that.
      As to using a Kadee Truck,
      For the cars I mount Kadee trucks on, I chose not to the use of the adaptor kit base plate intended by Kadee because I want keep a car's height from the railhead to a minimum for more prototypical appearance since cars tend to be too high from the railhead. This also reduces the height of the coupler box spacer when body mounting Kadees centerset couplers.
      Kadee Truck
      Many USA Trains and AML cars have a rounded floor bolster from which a truck pivots against (thereby minimizing rubbing area) so when the Kadee truck's side frames twist by design for equalization (while truck pivots on twisted track) there should less friction and minimal affect on operational dynamics.
      -Ted
    • October 13, 2017 3:26 PM EDT
      • Kittery, ME
      • Posts
        509
      • Thanks
        36
      • Thanked
        179
      I went with the new, rounded design, and used the USAT bushing without the accompanying shim.  The car seems to have an appropriate amount of motion in each axis relative to the truck, with little friction.  Each coupler required a single 1/16" shim, which is less that they required with the original trucks.  I'm happy.
      I updated the file on the thingiverse link.
      Thanks for the suggestions.
    • October 13, 2017 8:34 PM EDT
      • Post Count ,PA ,
      • Posts
        12,610
      • Thanks
        938
      • Thanked
        665
      Eric...
      With what I have seen from your posts I think you should take you hand at scratching up some cars instead of modding what is available unless you have other intentions
    • October 13, 2017 8:56 PM EDT
      • Kittery, ME
      • Posts
        509
      • Thanks
        36
      • Thanked
        179
      I'd like to try that!  I bought these tank cars on eBay, and they were damaged when they arrived.  I got my money back, but the seller didn't want them returned.  So I'm just trying to get them rolling.  I do have some ideas for whole cars.
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
