  • Topic: Calling All Air Wire Gurus
    Back To Topics
    (0 rates)
    • September 2, 2017 11:19 AM EDT
      • Northridge, Ca
      • Posts
        95
      • Thanks
        2
      • Thanked
        10
      Hi guys....thank you for all the helpful advice. Unfortunately, I dont have the loco here with me, it is at the owners house. He is going to pull the tender apart this weekend so we can get at the P8. Once I have it in front of me, I can call Kevin.
      Batteries - RC Car batteries (Ni Cad?) 2 x 7.2v packs.  (Owner is going to switch to Li-ion battery packs after seeing mine and how small they are)
      I may have had my terminology confused....we programmed?? the Loco address from the RF1300. This is the manual I was working off of, it does have limited programming.
      http://www.cvpusa.com/doc_center/AirWire_Throttle_Manual.pdf
      The owner isnt so concerned about the lights, but I want to get them working (small victory), he is more concerned about the sound. I think once I have access to the P8, we will know a bit more.
      Thanks again, I will keep you updated
    • September 2, 2017 11:37 AM EDT
      • Gig Harbor, WA
      • Posts
        401
      • Thanks
        12
      • Thanked
        116
      If this were my loco acting the way it does, the first thing I would do is get a voltmeter and check power.  He says no sound. When you turn the loco on it should power the G2 and the Phoenix P8 direct from the battery.   The green power leads going to the P8  are probably connected to the Airwire power input coming from the battery.  If that voltage is low then the P8 may not fire up.  If that voltage is good then there is an open in the power to the Phoenix P8 or like I mentioned before, there is a separate power switch to the Phoenix which is in the off position.     The lights are purely a G2 function.  There again, check with a voltmeter at the G2 light outputs.  The G2 will output battery voltage from the light outputs when on.
      This post was edited by Paul Burch at September 2, 2017 2:35 PM EDT
      Paul Burch
      Sierra Cascade & Pacific RR
    • September 2, 2017 10:32 PM EDT
      • Posts
        9,393
      • Thanks
        249
      • Thanked
        861
      I see the owner says the lights are low priority, but their non-working may be a clue to other problems, especially since the G2 appears working.
    • September 3, 2017 11:42 AM EDT
      • Northridge, Ca
      • Posts
        95
      • Thanks
        2
      • Thanked
        10
      Greg, I agree...I told the owner we are going to work on the lights first. Chase that down and then move onto the sound. He was fine with that.
      Bob
    • September 3, 2017 12:36 PM EDT
      • Gig Harbor, WA
      • Posts
        401
      • Thanks
        12
      • Thanked
        116
      Check the battery voltage first thing!   P8 will not work with less than 9V.  The G2 will work at 10v, but not well.
      Paul Burch
    • September 3, 2017 2:38 PM EDT
      • Pittsburgh, Pennsylvania
      • Posts
        11,035
      • Thanks
        123
      • Thanked
        885
      If the Airwire was reset, as stated earlier, would that reset how the lights work? I am asking, because I don't know, would the light functions need to be reprogrammed?
      Shannon car Shops
      Home of the infamous leg lamp
      I.A.R.R.R. Member #12
      and King Butt Modeler
    • September 3, 2017 3:11 PM EDT
      • Gig Harbor, WA
      • Posts
        401
      • Thanks
        12
      • Thanked
        116
      David, After a successful G2 reset, CV60 (headlamp mode) will be set to the default of 0, which is auto reverse. Forward = front on, reverse = rear on.  That is provided 0 has been pushed to turn them on.
      Paul Burch
    • September 3, 2017 6:00 PM EDT
      • Berkshire, Ma.
      • Posts
        758
      • Thanks
        154
      • Thanked
        49
      Paul should David also check and make sure that the throttle is in speed step 24 after reset of G2 for control of lights?
      Richard
    • September 3, 2017 7:25 PM EDT
      • Posts
        11,035
      • Thanks
        123
      • Thanked
        885
      I don't have the loco. I was merely asking out of curiosity. So if function 0 wasn't pressed, then the light would not come on. So should Bob try pressing the 0 before he trys troubleshooting the lights not on issue?
      Shannon car Shops
    • September 3, 2017 11:40 PM EDT
      • Gig Harbor, WA
      • Posts
        401
      • Thanks
        12
      • Thanked
        116
      David,
      Pushing 0 will turn the lights on or off in a properly working loco.
      Paul Burch
    • September 4, 2017 7:27 AM EDT
      • Posts
        11,035
      • Thanks
        123
      • Thanked
        885
      Yes. So if the lights are off, it just my be a simple matter of pressing 0.
      Shannon car Shops
    • September 4, 2017 8:33 PM EDT
      • Northridge, Ca
      • Posts
        95
      • Thanks
        2
      • Thanked
        10
      As I stated before, the owner took apart the tender and now has access to the P8. He says he was getting 15v at the P8 board. He did some more work on it without me since I cant get out there for another week or so. I did ask him to power up the unit and press the 0 button and see if the lights come on. He said he got nothing. Still, the bulbs could be burned out. Does it make sense that the throttle would work, but no other functions?
      We did check the volume switch for the P8, tried the volume all the way up and down and no sound either way.
      The owner made up this sheet with notes from what we have found. Take a look if interested.
      Mogul Repair Notes
      Thanks again for all the help
    • September 4, 2017 11:21 PM EDT
      • Berkshire, Ma.
      • Posts
        758
      • Thanks
        154
      • Thanked
        49
      Bob you say he got 15v on the p8 board does that mean on the 2 green wires and the gray and orange wires. If he has power on the gray and orange wires have him carefully unplug the sound toggle switch and just push 7 on the transmitter.
      Richard
      This post was edited by Richard at September 5, 2017 7:52 AM EDT
    • September 5, 2017 1:52 AM EDT
      • Elverta, CA
      • Posts
        399
      • Thanks
        3
      • Thanked
        58
      Bob
      Pictures and diagrams help see the installation. Looks like NiMh battery packs.
      Michael
      This post was edited by Michael Glavin at September 5, 2017 1:59 AM EDT
    • September 5, 2017 7:49 AM EDT
      • Berkshire, Ma.
      • Posts
        758
      • Thanks
        154
      • Thanked
        49
      Bob, Michael started to bring up a good point why did Alan post a pic. of a diagram of a P9 not the same as a P8. But the P8 does look wired right. IMO
      Richard
    • September 5, 2017 8:57 AM EDT
      • Penacook, New Hampshire
      • Posts
        201
      • Thanks
        0
      • Thanked
        35
      Hi Bob, I noticed from the photo the speaker is a .5 watt. That is a very low wattage to handle the P8. Did you check to see if the speaker is blown? The standard round 3" Phoenix is rated 1-2 watt at 8 ohms.
      To test the speaker use only a 1.5V battery and connect wires from each end and touch the wires at the speaker contacts. You should hear a momentary buzz  sound. If you do, then you will know the speaker is receiving a signal.
      Did you try calling Kevin?  If not, Kevin will be in my shop all day tomorrow so call him. We are working on an AirWire install.
      Don
    • September 6, 2017 8:19 AM EDT
      • Northridge, Ca
      • Posts
        95
      • Thanks
        2
      • Thanked
        10
      Richard
      I believe on the green, not sure if he tried the orange and gray wires. I hope to get over there next week and will try what you have suggested. I believe he posted the P9 as that was only one that had a diagram connected to a G2.
      Thank You
      This post was edited by Bob Frein at September 6, 2017 8:22 AM EDT
    • September 6, 2017 8:25 AM EDT
      • Northridge, Ca
      • Posts
        95
      • Thanks
        2
      • Thanked
        10
      Don
      I have not checked for a blown speaker yet. That was the speaker the installer put in at the time. I have a 3 inch 2w 8ohm speaker that I will connect up and see if that is the problem. I have not called Kevin as I dont have the loco in front of me. When I do, I can call him then.
      Thank You
    • September 6, 2017 3:42 PM EDT
      • Berkshire, Ma.
      • Posts
        758
      • Thanks
        154
      • Thanked
        49
      Bob when you do this, it is just between gray and orange wire pin 1 and 2 need some kind of power to work even if real low I checked mine i had 1/4 volt. if no power do a reset of the G2 like Paul said. and while you are there check for voltage between pin 5 and 7 or 8 if no lights hooked up or burnedout could be as high as 10 volts but if hooked up and good should be 0 volts till you hit 0 on controller. You could do this to pin 6 also.
      Richard
      I verified this on my G2
      This post was edited by Richard at September 6, 2017 3:44 PM EDT
    • September 11, 2017 4:57 PM EDT
      • Northridge, Ca
      • Posts
        95
      • Thanks
        2
      • Thanked
        10
      Update 9/11/17
      I was able to spend an hour or so with the owner this morning trying a few of the suggestions you all listed previously. I took an old speaker I had laying around to test. I hooked it up to the P8 and I got static, we started the throttle and we got chuff, we pressed 1 and got the bell and pressed 2 and got the whistle. WooHoo!!!!  It turns out the speaker was bad....order new speaker...check!  I did notice that the momentary volume switch did not seem to be working as I tried in both directions and the volume didnt change. I think the volume switch is bad and that may have blown the .05w speaker the owner had in there.  Order new momentary volume switch...check!
      Lights...still dont work. We were getting 10v on both the front and rear light terminals on the G2 board. We did get access to the front headlight bulb and it appears to be burned out. We did get a 10v reading at the socket. Owner wants to upgrade to LED lights at this point. A strange thing happened, when the loco was running on the rollers, when I pressed the 0, there seemed to be a voltage drop as the loco wheels slowed down until I pressed 0 again.
      Anyway...we are making progress and the owner is very happy.
      To be continued...
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
