Forum Sponsorsss
Forums General Track and Trestles
  • Topic: Building a New Bridge
    Back To Topics
    (0 rates)
    • August 10, 2017 9:36 PM EDT
      • Mount Vernon, Missouri
      • Posts
        573
      • Thanks
        14
      • Thanked
        40
      • Reputation
        Well Respected
      Cutting one side one my new bridge
      10foot long and 2 track wide 42" tall
      In the middle, the engineering dept calculated all the factors, length, possible weight of two heavy
      Engines with loaded cars, the weight of the bridge and weight of the track, all was calculated and the wind factor of 80 mph was added to the numbers.
      All the above sounds impressive, the truth is this is what I drew up one nite in my recliner and sent to plasma cutter files.
      Loaded a sheet of 11 gauge 4' x 10' steel on plasma, plotted drawing, pushed the button, and away it goes. I love CNC equipment.
      More to Follow
      IMG_0759[1] by Dennis Rayon, on Flickr" alt="">
      IMG_0764[1] by Dennis Rayon, on Flickr" alt="">
      Placing a 1" strap on the top edge of the bridge side, this makes it appear to be larger beams
      spot welded in here and sanded down in picture Below
      IMG_0765[1] by Dennis Rayon, on Flickr" alt="">
    • August 11, 2017 3:14 PM EDT
      • San Mateo, California
      • Posts
        113
      • Thanks
        6
      • Thanked
        29
      • Reputation
        Well Respected
      Dennis,
      That's an outstanding bridge!
      How much will it weigh as completed, and how will it be moved and supported in the garden railway? Do you have a picture as to where it will be located?
      Thank you,
      -Ted
    • August 11, 2017 4:09 PM EDT
      • Norris City, Il.
      • Posts
        790
      • Thanks
        58
      • Thanked
        69
      • Reputation
        Well Respected
      WOW!
    • August 12, 2017 10:52 AM EDT
      • Cape Cod,
      • Posts
        2,651
      • Thanks
        32
      • Thanked
        64
      • Reputation
        Well Respected
      That is one impressive structure.   Did you design it on your own or is it based on a real bridge somewhere?
    • August 12, 2017 8:44 PM EDT
      • Posts
        573
      • Thanks
        14
      • Thanked
        40
      • Reputation
        Well Respected
      Ted Doskaris said:
      Dennis,
      Thank you,
      -Ted
      Thanks Ted
      Weight? don't know , will weigh before I get ready to set, I will carry to RR with tractor and loader. Don't have picture of where it will set, Yet, thanks for the reminder, I usually think about pictures after the job is done, and I say,CRAP, wished I would have taken pictures.
    • August 12, 2017 9:19 PM EDT
      • Posts
        573
      • Thanks
        14
      • Thanked
        40
      • Reputation
        Well Respected
      Tod Thanks for the compliments
      My design, drawn in sketchup
      Dennis
    • August 12, 2017 9:48 PM EDT
      • Posts
        573
      • Thanks
        14
      • Thanked
        40
      • Reputation
        Well Respected
      Below are a few pictures of how the 1" strap was applied to the top of the side, all in one piece.
      IMG_0768[1] by Dennis Rayon, on Flickr" alt="">
      IMG_0771[1] by Dennis Rayon, on Flickr" alt="">
      The strap is welded along the edge, at the joints, i use a cutoff wheel to cut about 1/2 way through and bent at the joint.
      Using visegrip clamp to hold tight and in place then welded.
      I was asked on FB if i only welded  the short welds or came back and welded all the way through.
      No way to weld all the way, waste of weld and time, and then the heat would twist the frame like a piece of spaghetti .
      Welding all the way can be done without twisting but requires lots of time and skill on how to prevent the twisting.
      I will not get into how to prevent the twisting, quite complicated.
      The unwelded crack at the joint gets body puddy to prevent moisture from entering and dripping rust down the sides.
      The inside is sealed  with silicone caulking to prevent moisture entering on the inside. The caulking will not be seen, and in covers with paint very good.
    • August 16, 2017 9:29 AM EDT
      • Easton , Massachusetts
      • Posts
        3,304
      • Thanks
        468
      • Thanked
        101
      • Reputation
        Well Respected
      I want to know is that a hovering welder.....
       My u-tube
    • August 16, 2017 4:28 PM EDT
      • Pittsburgh, Pennsylvania
      • Posts
        9,030
      • Thanks
        50
      • Thanked
        406
      • Reputation
        Well Respected
      Looks like it. Anti-gravity can be very useful.
      Shannon car Shops
      Home of the infamous leg lamp
      I.A.R.R.R. Member #12
      and King Butt Modeler
    • August 16, 2017 11:29 PM EDT
      • Posts
        573
      • Thanks
        14
      • Thanked
        40
      • Reputation
        Well Respected
      I own a antigravity making business, we float everything, LOL LOL  i designed a double folding arm that holds the welder on the end
      and a plasma cutter behind it. It it 17ft long then the welder, now that requires a lot counter balance weight to hold that up.
      we have two of these back to back, with a 12" pipe between them, that has a 2000lb 16ft long jib crane, mounted in the floor and welded to 3 heavy  roof trusses it swings 360 degrees serving 2 welding stations. So the welder support arms will move in 180 degree arc, making it quite handy
      Dennis
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
