Yard Office
Haven’t posted a building here in a while, so here is my yard office. Or I guess that’s what it is. It’s actually mostly from the scrap bin, I had some depot side panels I didn’t use so I cut those down. Also had a left over end-part and some spare black roof styrene so I stuck em together. The windows are all cut out on the router this time, no resin castings. It’s wired with LEDs and CL2N-3 drivers so I can run 12v to it. Since I have decided it’s a yard office, now I need a yard. Time to make more turnouts :slight_smile:
Very nice use of left-overs, looks great!
Martin
That looks great. You said you cut your windows on the router. Do you have pics of that to post?
Boomer, I may, I’ll have to look when I get home this evening. I can post the files I used if you want them. They are flat svg files. The panes are two parts, upper and lower. The trim is strip styrene.
