ALCO C-855 3d printed train
and so it begins, the largesdt ALCO diesel ever built, 35.59" in length when completed
shes gonna be a big one
and it starts with a small number board piece
the motor block span bolster
the front pilot
the nose and battery boxes
the only problem with black plastic, photos are hard to see any details :frowning:
the cab was 5 hours on the printer
the cab roof
gluing on the number board and roof cap
rough sanded the nose and glued it to the cab
first frame section printed
only 4 more frame sections to go
second frame section done, catching up to the Mac in the background, tape measure is at 35.5"
didn’t take long to extend longer then the Mac
the 2 beast together, the Baldwin DR 6-4-2000 is much closer to the length of the ALCO C855 then the Mac
Currently reprint a longer pilot bolster piece, then the body sections can be done, the body sections will drop in over the frame
Plenty of room for sound and batteries…and a small family…(http://largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-laughing.gif)
Are you going to print all 3 of the 855s? Be cool to see the B version too.
Chris
I’m only making 1 a and 1 b for myself at 35.59" an aba set would be overkill for my point to point layout, lol
Test print of a long hood section to double check dimensions before starting the hood sections
first long hood section is a short one
and now on the frame
The next section should fit between the first section and the test print piece
This engine is going to be a lonnng build!
another 5.5" of the long hood, and 1 side of the middle section are done
my overnight print piece
3.5 major body pieces left for the long hood
after the main body pieces, the next largest pieces would be the fuel tank, then the smaller detail like vents and roof details can go on, i’d reckon this to be done and ready for paint Monday if not sooner
Progress??
(https://i.pinimg.com/564x/8d/46/f7/8d46f712deaf7f9201c9ec6f9f00e63b.jpg)
Won’t quite make a 4’rad curve :wink:
Overhang on 4’ rad is wicked, lol
Color
Mark Dashnaw said:
Progress??
Put a hinge in it? (http://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-tongue-out.gif)
Marc
I noticed that you’re doing it wrong .
Shane used green tape on his build , while you’re using blue … (https://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-yell.gif)
It looks huge/awesome … (https://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-tongue-out.gif)
Just take the blue tape and paint it green and you’ll be fine. And, yes, it does look awesome!
Awesome project. Looks nice. Later RJD
Hi Marc, the C855 looks great. A lot of work went into it. My question: would you trade or sell the STL files? I would like to build this locomotive in A and B unit in 1:48 scale. I would offer Krauss Maffei ML 4000cc; Krauss Maffei ML 4000 Hoodunit or GE U30CG or GE U50 cc
Greetings
Peter
