Forum Sponsorsss
Forums Modeling Rolling stock
  • Topic: Scratchbuilding a wooden tank car
    Back To Topics
    (0 rates)
    • July 31, 2017 7:33 PM EDT
      • Pleasanton, CA
      • Posts
        1,428
      • Thanks
        1,800
      • Thanked
        1,229
      Yeah the deck is at the right height with the Kadee mounted underneath it. I *could* remove some material and move the Kadee higher than the bottom of the deck, if the deck should be lower toward the wheels.
      The question is: should the deck be lowered down toward the wheels in order to "look right" ???
      It is also entirely possible this whole thing is a stupid question :-)
    • July 31, 2017 7:58 PM EDT
      • Missouri, It's like Floodsburg, man
      • Posts
        2,956
      • Thanks
        425
      • Thanked
        427
      That's why I linked to the pictures I did. Looking at where the side sill rides in relation to what can be seen of the wheels.
    • July 31, 2017 8:07 PM EDT
      • Pleasanton, CA
      • Posts
        1,428
      • Thanks
        1,800
      • Thanked
        1,229
      Ah, Forrest, I totally misunderstood the point of those pictures! My bad. It appears from looking at those that the spacing on my car is not out of bounds eh?
      Thanks for the historical photos, those are awesome!
    • August 1, 2017 5:56 AM EDT
      • Pittsburgh, Pennsylvania
      • Posts
        11,160
      • Thanks
        129
      • Thanked
        931
      Jim, the car may look high, because the car is basically a flat car. Cars with side sheathing, like boxcars and passenger cars, usually look lower on the trucks, because the sheathing usually extends below the frame of the car. Its an illusion, because the frame is at the same height, so that the couplers can mate up.
      My point, with my question, was that if the coupler is at the right height, the frame has to be at the right height.
      This post was edited by David Maynard at August 1, 2017 6:23 AM EDT
      Shannon car Shops
      Home of the infamous leg lamp
      I.A.R.R.R. Member #12
      and King Butt Modeler
    • August 1, 2017 10:15 AM EDT
      • Deer Park, Washington
      • Posts
        12,598
      • Thanks
        605
      • Thanked
        389
      What David said.
      It's a car that was built in the backshops of the railroad.  It's not supposed to look "storebought."
      This post was edited by Steve Featherkile at August 1, 2017 10:16 AM EDT
    • August 1, 2017 4:42 PM EDT
      • Pleasanton, CA
      • Posts
        1,428
      • Thanks
        1,800
      • Thanked
        1,229
      As long as it doesn't look like this I'm happy.  Thanks!
    • August 1, 2017 5:42 PM EDT
      • Posts
        11,160
      • Thanks
        129
      • Thanked
        931
      ewwew. That's bad.
      Shannon car Shops
    • August 19, 2017 8:01 PM EDT
      • Pleasanton, CA
      • Posts
        1,428
      • Thanks
        1,800
      • Thanked
        1,229
      Finally got to a milestone that justified posting again on this project. Just took the car out for its maiden voyage around the layout. So far so good :-).
      Progress since last update: undercarriage done (truss rods, trucks, couplers), first cut at using magnets to hold on the top filler cap, and have most of the work done to build a ladder and catwalk to give access to the filler cap. Glue is drying on the ladder.
      Still some stuff to do (another set of turnbuckles, stirrup steps, add battery and connector for power hookup to the Climax, possibly add a hose and associated pipe/valve, little details like a toolbox, etc.), but it now looks enough like the original inspiration car to make me happy.
      Cheers!
    • August 19, 2017 8:14 PM EDT
      • South Central , PA
      • Posts
        15,288
      • Thanks
        3,238
      • Thanked
        1,858
      Looks great !
      How do the truss rods coincide with the magnetic door opening? Do they just slide into the timber?
    • August 19, 2017 8:23 PM EDT
      • Pleasanton, CA
      • Posts
        1,428
      • Thanks
        1,800
      • Thanked
        1,229
      Rooster: Yes, they just slide into holes a bit. Seems to be no problem so far. I did ACC the truss rods where they intersect, and will probably need to glue the other end (and the turnbuckles I add there of course) so things don't move too much.
      Other than being a little fiddly to close (have to line up the truss rods with the holes on both sides), it isn't too bad. I don't anticipate opening this thing up ever, until I need to replace the battery pack or a fuse. So a little fiddly is ok by me.
      Thanks!
    • August 19, 2017 8:52 PM EDT
      • Saint Johns, Florida
      • Posts
        4,700
      • Thanks
        585
      • Thanked
        787
      Very nice job Jim!
    • August 19, 2017 11:10 PM EDT
      • Pleasanton, CA
      • Posts
        1,428
      • Thanks
        1,800
      • Thanked
        1,229
      Thanks Joe!
      And here's the ladder and a better view of the catwalk, for what it's worth.
      Cheers!
    • August 20, 2017 12:29 AM EDT
      • Streamwood, IL
      • Posts
        459
      • Thanks
        1,182
      • Thanked
        70
      Beautiful Jim, great work!
    • August 20, 2017 7:22 AM EDT
      • Hendersonville, North Carolina
      • Posts
        311
      • Thanks
        89
      • Thanked
        117
      Jim,
      Your tank car turned out really, really nice.  Enjoyed your build.
      Doc Watson
    • August 20, 2017 7:30 AM EDT
      • Not one of the WannaBe's,
      • Posts
        6,072
      • Thanks
        1,946
      • Thanked
        880
      Well done Jim. I always enjoy seeing a new twist from the norm.
    • August 20, 2017 8:55 AM EDT
      • Mount Vernon, Missouri
      • Posts
        985
      • Thanks
        101
      • Thanked
        456
      Great build Jim
      Dennis
    • August 20, 2017 11:54 PM EDT
      • Pleasanton, CA
      • Posts
        1,428
      • Thanks
        1,800
      • Thanked
        1,229
      Thanks, all!
      I will admit, though, that I thought building the tank car was going to be the hardest part of this.  But now I'm in the middle of Airwire, sound, battery conversion of the Climax. Sheesh!
      This post was edited by Jim Rowson at August 20, 2017 11:57 PM EDT
    • September 5, 2017 6:47 PM EDT
      • Pleasanton, CA
      • Posts
        1,428
      • Thanks
        1,800
      • Thanked
        1,229
      Well, I'm still not quite done here yet since the whole point of this was to do a battery conversion of my Climax. I've got the electronics working with the battery so all that stuff is good. It turns out though that the Airwire receiver/motor driver is a tight fit in the Climax tender (like, it is too long). With that and my own harebrained desire to convert the Climax to be a wood burner, I decided to nuke the existing tender and build a wooden one.
      I am going to guess this is not prototypical. Oh well.
      Here's where I am right now:
      • Electronics seem to fit (after some finagling!)
      • Test fit on the locomotive is ok
      • Weathered to match the tank car (still need to re-weather the loco to fit that paint scheme - it came weathered already...)
      Still to do
      • Need to find/split some firewood to fill the tender with a fake load
      • Install electronics
      • Attach tender to loco
      • Figure out a way to hide the attachment (this one has me temporarily a bit stumped)
      • Waiting for shorty kadee couplers (#1917's) to be installed below the rear wood "bumper"s
      • Am planning to follow John Caughey's (and others) idea of using shoelaces to hide the battery power wiring between tank car and loco
      • Details (grab irons, some bolt castings, etc.)
      Any suggestions to improve this?
      This post was edited by Jim Rowson at September 5, 2017 7:19 PM EDT
    • September 5, 2017 7:26 PM EDT
      • Southern Oregon
      • Posts
        2,113
      • Thanks
        811
      • Thanked
        1,192
      Jim,
      Love your wooden tender tank, I don't think I have ever seen one on a class B but that doesn't mean it wasn't done somewhere.  A tree fell on the tender tank and punched multiple holes or it was all rusted out and not fixable.  To far to go or to expensive for a replacement, have to get the loco back in service.  Wooden tank very plausible.
      If your talking about attaching the tender tank to the loco deck my suggestion would be;  If you have room in the inside front corners of the tank clue a small block in each corner and run a small hidden screw up through the deck.  For the back attach an angle bracket (metal) and bolt it to the tender then screw it to the wood end beam, very prototypical even for metal tanks.
      Just a suggestion if your going wood burner perhaps changing the stack to a wood burner stack with cinder trap would be something to consider.
      Looks great.
      Rick
    • September 5, 2017 7:38 PM EDT
      • Pleasanton, CA
      • Posts
        1,428
      • Thanks
        1,800
      • Thanked
        1,229
      Thanks Rick. Glad to hear this doesn't look too weird :-).
      As to attaching the tender, your idea of screws from below seems just fine. I was starting to think that way myself and you just helped me solidify the decision. Certainly the first thing to try.
      Yeah, should go with a wood burner stack. Sadly this was a used loco and only came with the stack you see. I'll have to see what I can find.
      Cheers!
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
