Thanks, guys!
The metal work is the easiest part of the whole build.
I use K&S .016 x 1/4 for the pieces that need to be formed. It is hand formed with flat needle nosed pliers. The material is cut to length with simple side cutters. you grip the piece and bend it back and forth a few times and it snaps.
A few packs of cheap Harbor Freight 1/16" drill bits, a small smooth file, a dremel , and a scribe. A small vise clamped next to you can bend the heavier brass, if you use .132 for any thing. You can bend it with the hand tools, but it is a little harder to form.
After I finish my morning paper and coffee, I’ll go out in the shop and take some pics for you all.
