Finished building up a heavy disconnect using plans I found in one of my books. I scaled it to 1:20.3 The prototype uses very heavy timbers and usually hauled only one or 2 logs. (Big logs.)
This is the first one in a string of several I will build. I wanted to make sure I liked it before I cut the wood for all the rest.
It has removable couplers so you can use knuckles if you wish to.
Journals and coupler pocket from Wiseman, other bits from Ozark’s and some brass strips, pins, etc.
