I thought that a stone pump house would make a nice contrast with the timber water tank. I started with a sheet of decorative stone wall tiles from Lowe’s and removed some of the individual stones from the backing. Each stone is approximately 3/8” x 3/8” x ¾” I figured I would need about 150 stones, so I peeled off 200 just to be sure. I tinted about 1/3 of the stones with yellow ochre ink; another 1/3 with brown ink; and the remaining 1/3 with black ink. After they dried I went back and coated all of the stones with black ink. Here is what they look like when dry.
I made a shell from thin plywood and coated it inside and out with a sealer. I made the length and width multiples of the stone length to minimize the number I would need to cut.
I applied the individual stones with construction adhesive.
I left an opening in the front for a doorway.
I sanded the top of the walls to get a smooth angle for the roof.
I framed the doorway with heavy timbers.
I made a pair of doors by gluing pieces of scale 1” x 6” boards to pieces of thin plywood. I applied the boards at a 45 degree angle.
I installed the doors into the opening and framed the door panels with scale 2” x 4” boards.
Tomorrow I’ll add the door handles, hinges and latch, and start on the rafters and roof sheathing. I’m thinking I’ll probably go with a corrugated metal roof but I’m not sure yet.
More to follow,
Bob
