Forum Sponsorsss
Forums General Indoor and Micro
  • Topic: The Schmatterhorn
    Back To Topics
    (0 rates)
    • January 8, 2017 1:48 PM EST
      • Smoggy L.A., Left Coast
      • Posts
        7,268
      • Thanks
        24
      • Thanked
        82
      • Reputation
        Well Respected
      The Schmatterhorn
      The Schmatterhorn...or, you can't keep a good lunatic down.
      Underway ...basic foam work finally done. This is a 2'x2' ish micro using Gargraves flextrack this time as an experiment. 2" thick pink foam from Home Despot, sunlight gives it a wierd silver sheen. This one also splits into two sections, upper and lower. Got a ways to go, but as the Costa Mesa show looms, I was getting a little desperate that I only have one layout, Heckawe Junction, readily accessible. This layout has been in the works since I sold the Angry Beaver but I haven't been able to do it any justice until now.
      So far so good, I'll be taking this to Costa Mesa, warts and all, if just to show how it's done.
      This post was edited by Vic Smith at January 9, 2017 1:45 PM EST
      Have fun with your trains
    • January 8, 2017 3:04 PM EST
      • Tolland County, Ct.
      • Posts
        1,429
      • Thanks
        13
      • Thanked
        16
      • Reputation
        Well Respected
      Love it.
      RRR#2...........Linville Jct. RR
       Live steam.
    • January 8, 2017 3:20 PM EST
      • Denver, Colorado
      • Posts
        1,658
      • Thanks
        125
      • Thanked
        199
      • Reputation
        Well Respected
         Yes, Vic, that qualifies as lunacy. And I love it. Never would have thought of that!
    • January 8, 2017 4:42 PM EST
      • Salt Lake City, Utah
      • Posts
        29
      • Thanks
        6
      • Thanked
        1
      • Reputation
        Neutral
      So cool to watch another layout come together!
    • January 8, 2017 6:46 PM EST
      • Posts
        7,268
      • Thanks
        24
      • Thanked
        82
      • Reputation
        Well Respected
      Thanks, my biggest problem is pacing myself. I've added some texture via hot knife and wire brush but pieces keep moving. I really need to let it set for 24-36 hrs so the adhesive can dry. I'm hoping to get the base coats of paint down and dry before Friday.
    • January 8, 2017 7:20 PM EST
      • Holley, NY
      • Posts
        75
      • Thanks
        2
      • Thanked
        6
      • Reputation
        Well Respected
      I really like that Vic,
            It's inspiration for the circle of 45mm track I've had for years.   Which adhesive do you use for the foam?
      Have fun,
      Tom
    • January 8, 2017 10:28 PM EST
      • Posts
        7,268
      • Thanks
        24
      • Thanked
        82
      • Reputation
        Well Respected
      Found a way to help keep everything fixed, unfolded a wire coat hanger, straighten and cut in half, form a small hook one end, use an icepick to start a hole then jamb it down with a pliers until it's pushed all the way into the foam. Need to make a couple more to tie alot of parts together. I use long drywall screws for some parts but they just aren't long enough for the big pieces. During summer this isn't an issue but in winter the cold weather hampers the adhesive curing.
    • January 8, 2017 10:30 PM EST
      • Posts
        7,268
      • Thanks
        24
      • Thanked
        82
      • Reputation
        Well Respected
      Have fun,
      Tom
      Tom I'm using Loctite Power Grab construction adhesive caulking.
    • January 8, 2017 11:43 PM EST
      • Post Falls, Idaho
      • Posts
        6,556
      • Thanks
        812
      • Thanked
        292
      • Reputation
        Well Respected
      Hey Vic,
      I know I have asked this before but I don't feel like looking for the answer. How wide is your tunnel portal? What do you allow for clearances on the sides? My snow shed is a 15"radius and I am making it 5" wide. Seems like it is wide enough when I put my micro logger in it.
    • January 9, 2017 9:03 AM EST
      • Chaco, Paraguay
      • Posts
        2,319
      • Thanks
        96
      • Thanked
        114
      • Reputation
        Well Respected
      don't waste hangers! (and save yourself the work of straightening them)
      i use toothpicks and/or shashlick (brochette) sticks, depending on the thickness of the foam layers.
      pushing two sticks in at slightly opposed angles, and the instant fixation is done.
      My Chaosplace ->
    • January 9, 2017 9:41 AM EST
      • East Brunswick, N J RRR#22
      • Posts
        1,571
      • Thanks
        91
      • Thanked
        38
      • Reputation
        Well Respected
      You could use the long bamboo skewers used for shish-ka-bob. They are about a foot long.
    • January 9, 2017 10:33 AM EST
      • Easton , Massachusetts
      • Posts
        3,461
      • Thanks
        546
      • Thanked
        126
      • Reputation
        Well Respected
      In canada they have they their own version of  dollar and they had some skews for marshmallows  3' long
       My u-tube
    • January 9, 2017 11:54 AM EST
      • Posts
        7,268
      • Thanks
        24
      • Thanked
        82
      • Reputation
        Well Respected
      Devon Sinsley said:
      Hey Vic,
      I have a basic way of creating my clearances, I take the largest car/engine I plan to run on it, and then as I'm laying out foam run it back and forth until I'm reasonably sure it will clear, however sometimes that doesn't work and outcome the razor knifes and hot tools to adjust the passageway, as long as I have a few mm of clearance I'm good.
    • January 9, 2017 12:32 PM EST
      • Posts
        3,461
      • Thanks
        546
      • Thanked
        126
      • Reputation
        Well Respected
      Keep arms inside of car at all times!
       My u-tube
    • January 9, 2017 11:22 PM EST
      • Post Falls, Idaho
      • Posts
        6,556
      • Thanks
        812
      • Thanked
        292
      • Reputation
        Well Respected
      OK then. Lol basically how I figured I would do it.
    • April 15, 2017 12:18 AM EDT
      • Denver, Colorado
      • Posts
        1,658
      • Thanks
        125
      • Thanked
        199
      • Reputation
        Well Respected
      Vic..............how's this coming along? I haven't seen any updates lately? Have I missed something?
    • April 15, 2017 12:38 PM EDT
      • Posts
        7,268
      • Thanks
        24
      • Thanked
        82
      • Reputation
        Well Respected
      Dbl post
      This post was edited by Vic Smith at April 15, 2017 1:30 PM EDT
      • Posts
        7,268
      • Thanks
        24
      • Thanked
        82
      • Reputation
        Well Respected
      Stalled, I am moving my workbench from the small room it's in to our back bedroom which means boxing everything to be stored in the garage and the garage is already badly impacted with too much stuff. So work on the layout is on hold until we sort out the house. On the plus side last show I picked up a box full of large scale trees for cheap.
      This post was edited by Vic Smith at April 15, 2017 12:40 PM EDT
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
