Forums Modeling Modeling
  • Topic: Leona Timber Co. gets a Depot
    Back To Topics
    (0 rates)
    • December 7, 2017 8:11 AM EST
      • Marysville, Kansas
      • Posts
        744
      • Thanks
        543
      • Thanked
        199
      Ken Brunt said:
      2 thumbs up on that one. (BTW, you need to change your calendar)................
      I can't, that's how far behind I am on this.....
    • December 7, 2017 6:53 PM EST
      • West Grove, Pennsylvania
      • Posts
        10,496
      • Thanks
        360
      • Thanked
        531
      "Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." --Martin Luther King Jr
    • January 8, 2018 9:46 PM EST
      • Posts
        744
      • Thanks
        543
      • Thanked
        199
      Doing the tedious work that takes time for not much results.  But I did get all of the paint work touched up and water sealed the shingles and platform decks.  Water sealer really brought out the redwood shingle color.   I have some of my LEDs collected so I can start to wire the clock tower back lighting and finish the roof up on it.
      Chris
    • January 8, 2018 10:07 PM EST
      • Denver, Colorado
      • Posts
        1,872
      • Thanks
        191
      • Thanked
        309
         I wouldn't be ashamed to put that on my layout.  I see you moved to the big city!
    • January 8, 2018 10:11 PM EST
      • Missouri
      • Posts
        2,378
      • Thanks
        167
      • Thanked
        208
      Living through the roofing tedium has been well rewarded.
      • Sherwood Park, Alberta
      • Posts
        335
      • Thanks
        39
      • Thanked
        201
      That's looking real good Chris.
      Shane
    • January 9, 2018 8:03 PM EST
      • Mount Vernon, Missouri
      • Posts
        619
      • Thanks
        16
      • Thanked
        59
      Looking very good Chris, The ole roof is almost done
      Dennis
    • January 9, 2018 10:29 PM EST
      • Posts
        744
      • Thanks
        543
      • Thanked
        199
      I added 3 of my 3d printed stacks to the depot tonight.  Some blocking for mounting LEDs is starting to go in as I am beginning to work on lighting.
    • January 9, 2018 10:50 PM EST
      • Posts
        619
      • Thanks
        16
      • Thanked
        59
      Chris the stacks looks really good too
      Dennis
    • May 27, 2018 5:06 PM EDT
      • Posts
        744
      • Thanks
        543
      • Thanked
        199
      Still working on the detail work on the depot.  I'm getting to the point of adding the porch post and decided to make 3d printed iron posts.  I printed the upper and lower sections and installed a tube in between so I can adjust the height.  First test set I used a 3/16" tube.   Here is that test set made up and in primer.  To me they look just a tad bit small.  I'm considering changing to a 1/4" tube.  What do you guys think?
    • May 27, 2018 5:29 PM EDT
      • Saint Johns, Florida
      • Posts
        3,977
      • Thanks
        291
      • Thanked
        440
      I think they look just fine.
    • May 27, 2018 5:34 PM EDT
      • Posts
        10,496
      • Thanks
        360
      • Thanked
        531
      Looks OK to me, too.
    • May 27, 2018 7:33 PM EDT
      • Vail, Az
      • Posts
        4,398
      • Thanks
        701
      • Thanked
        611
      I think you'd better go with what makes you happy.
      John
    • May 27, 2018 7:43 PM EDT
      • Chaco, Paraguay
      • Posts
        2,519
      • Thanks
        169
      • Thanked
        188
      the tube must have a diameter of 4 or 5 scale-inches.
      seems to be more than enough to me.
      My Chaosplace ->
    • May 27, 2018 7:53 PM EDT
      • Defending the State of Exile! ,
      • Posts
        12,928
      • Thanks
        1,233
      • Thanked
        826
      Since you are asking "what I think" !
      POSTS LOOK GREAT .... but the header is way to heavy/big and short as well from the pic. Raise the posts and lighten the header, then extend to outside edges and balance the roof with 1:1 12" overhang. Unless you are going to continue around the parameter with brackets,corbels and crown molding or running trim . Make sense?
      You asked ?
      Only my thoughts !
    • May 27, 2018 8:17 PM EDT
      • Posts
        744
      • Thanks
        543
      • Thanked
        199
      The header does look to big (1/2" tall), but I can't change that without building all new porch roofs.  Those were part of the building when i bought it.  I think that might be part of the reason I believe the post look small.  I was thinking of making a laser piece to look like iron scroll work for the front of the headers to break them up.  Once I get the posts the way I want, I will be making iron brackets to come off them to the headers.
    • May 27, 2018 9:23 PM EDT
      • Posts
        619
      • Thanks
        16
      • Thanked
        59
      the post looks fine
      The header will not be noticed on the layout as you will be looking down a little
      Dennis
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
